ArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2007-02-16T23:49:26+01:00 https://brainmodular.org/forums/app.php/feed/topic/254 2007-02-16T23:49:26+01:00 2007-02-16T23:49:26+01:00 https://brainmodular.org/forums/viewtopic.php?t=254&p=1219#p1219 <![CDATA[Building a compressor]]>
Thanks, Olivier.
Statistics: Posted by Guest — 16 Feb 2007, 23:49
2007-02-15T08:56:20+01:00 2007-02-15T08:56:20+01:00 https://brainmodular.org/forums/viewtopic.php?t=254&p=1209#p1209 <![CDATA[Building a compressor]]>
Is it possible (and useful) to put a Bypass on heavy patches?
There is a new module in the next version to bypass the current patch.
Statistics: Posted by senso — 15 Feb 2007, 08:56
2007-02-15T00:16:46+01:00 2007-02-15T00:16:46+01:00 https://brainmodular.org/forums/viewtopic.php?t=254&p=1206#p1206 <![CDATA[Building a compressor]]>
I was just thinking that a VST was using more CPU... except maybe when bypassed.
I'll try to find that "stupid compress" and talk with him.
Thank you Olivier.
Waiting for a recall-working "split-range module", but don't worry, take your time. I have also a lot to do on my side and it seems that I'm alone now to use it.
I hope that very soon I will not bother you every day!
Statistics: Posted by Guest — 15 Feb 2007, 00:16
2007-02-13T09:51:34+01:00 2007-02-13T09:51:34+01:00 https://brainmodular.org/forums/viewtopic.php?t=254&p=1184#p1184 <![CDATA[Building a compressor]]> Of course, the idea is very simple, but making one that sounds good is very difficult...
I suggest you to use your favourite VST.
Take a look on the 'stupid compress' patch somewhere in a sequencer demo songs (I can't remember which one...)
It's really a stupid compressor...
Statistics: Posted by senso — 13 Feb 2007, 09:51
2007-02-13T09:15:21+01:00 2007-02-13T09:15:21+01:00 https://brainmodular.org/forums/viewtopic.php?t=254&p=1182#p1182 <![CDATA[Building a compressor]]>
If you want to have a "real" compressor, I would think that you're better off patching in a VST one, but if you want to mess up the dynamics to create or control effects, you're on the right track!
Statistics: Posted by bsork — 13 Feb 2007, 09:15
2007-02-13T04:42:52+01:00 2007-02-13T04:42:52+01:00 https://brainmodular.org/forums/viewtopic.php?t=254&p=1179#p1179 <![CDATA[Building a compressor]]>
I suppose that to build a compressor, I have to use the Env Follower and a Vol audio.
But as I don't understand what indicate the Env and the Db outlets of the Env Follower, I'm creating very interesting effects, but not exactly what I want!
As you can see, I all have to learn!
Never too late.
Thanks for your help, guys, my work is in good progression with all your advices.
Statistics: Posted by Guest — 13 Feb 2007, 04:42
Thanks, Olivier.
Thank you Olivier.
Never too late.
