ArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2010-11-24T01:32:47+02:00 https://brainmodular.org/forums/app.php/feed/topic/2536 2010-11-24T01:32:47+02:00 2010-11-24T01:32:47+02:00 https://brainmodular.org/forums/viewtopic.php?t=2536&p=17144#p17144 <![CDATA[Matrix challenge part 2]]>
i'll work on it for the next release
Statistics: Posted by martignasse — 24 Nov 2010, 00:32
2010-11-05T12:00:56+02:00 2010-11-05T12:00:56+02:00 https://brainmodular.org/forums/viewtopic.php?t=2536&p=16774#p16774 <![CDATA[Matrix challenge part 2]]> Statistics: Posted by soundmind — 05 Nov 2010, 11:00
2010-11-05T11:04:48+02:00 2010-11-05T11:04:48+02:00 https://brainmodular.org/forums/viewtopic.php?t=2536&p=16772#p16772 <![CDATA[Matrix challenge part 2]]> ( i've also think about your scale sub patch , can be replace by multiply by 8 module..?)
but I'm sure martin will find a solution ...
Statistics: Posted by nay-seven — 05 Nov 2010, 10:04
2010-11-05T10:55:37+02:00 2010-11-05T10:55:37+02:00 https://brainmodular.org/forums/viewtopic.php?t=2536&p=16770#p16770 <![CDATA[Matrix challenge part 2]]> The instability i describe is sometimes the cells output value does not reflect its caption value which i thought may have been an error with the 0-1 vs 1-8 scale change but I think it may be related to the bug i reported in the matrix module thread because it happens when selecting a different preset with different matrix lengths than the previous. The bug seems very unpredictable so it is hard to pin point. But, basically I will have different events like a sample, etc. triggered by different matrix output values by the a=b module. But, when i switch from a preset with a 8 cell matrix to a different preset with a 16 cell matrix, the preset doesn't "remember" the values in the other half of the matrix length and as a result does not trigger the sampler but what is strange is that the cells will show the correct caption. I hope this all makes sense.
Statistics: Posted by soundmind — 05 Nov 2010, 09:55
2010-11-05T10:19:10+02:00 2010-11-05T10:19:10+02:00 https://brainmodular.org/forums/viewtopic.php?t=2536&p=16767#p16767 <![CDATA[Matrix challenge part 2]]> btw, nice workaround for the caption .i feel you'll quickly be a matrix master..;)
Statistics: Posted by nay-seven — 05 Nov 2010, 09:19
2010-11-05T05:24:53+02:00 2010-11-05T05:24:53+02:00 https://brainmodular.org/forums/viewtopic.php?t=2536&p=16763#p16763 <![CDATA[Matrix challenge part 2]]> Here is the pat for anyone who cares to have a look. Thanks.
Statistics: Posted by soundmind — 05 Nov 2010, 04:24
