ArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArray
BrainModularBrainModular Users Forum2010-11-04T18:26:31+02:00https://brainmodular.org/forums/app.php/feed/topic/25302010-11-04T18:26:31+02:002010-11-04T18:26:31+02:00https://brainmodular.org/forums/viewtopic.php?t=2530&p=16751#p16751 like the soundtrack too
Statistics: Posted by martignasse — 04 Nov 2010, 17:26
]]>2010-11-04T10:03:48+02:002010-11-04T10:03:48+02:00https://brainmodular.org/forums/viewtopic.php?t=2530&p=16745#p16745a little idea here A wavefile triggering counters, random pitch, colors and colomn/row number of the matrix.......sixties visual effect....
Statistics: Posted by nay-seven — 04 Nov 2010, 09:03
]]>2010-11-03T22:11:33+02:002010-11-03T22:11:33+02:00https://brainmodular.org/forums/viewtopic.php?t=2530&p=16732#p16732yep, it's the power of scripting vs patching, make things really modular and expandable
@nay-seven: haha, can't imagine what you'll do with this script
@23fx23: ...when i'm not to short in time...
Statistics: Posted by martignasse — 03 Nov 2010, 21:11
]]>2010-11-03T21:39:36+02:002010-11-03T21:39:36+02:00https://brainmodular.org/forums/viewtopic.php?t=2530&p=16730#p16730Statistics: Posted by soundmind — 03 Nov 2010, 20:39
2010-11-03T21:31:29+02:002010-11-03T21:31:29+02:00https://brainmodular.org/forums/viewtopic.php?t=2530&p=16729#p16729Statistics: Posted by nay-seven — 03 Nov 2010, 20:31
]]>2010-11-03T21:30:07+02:002010-11-03T21:30:07+02:00https://brainmodular.org/forums/viewtopic.php?t=2530&p=16728#p16728
]]>2010-11-03T21:25:55+02:002010-11-03T21:25:55+02:00https://brainmodular.org/forums/viewtopic.php?t=2530&p=16727#p16727thanks for all the help. I have not tested the script yet but in your patch simplification I have gotten great results. Ive discovered that using the swap array i can fully rotate the matrix. For virtical "flip" I use the "get col" method and for horizontal "swap" use the "get row". I will check the script.
Statistics: Posted by soundmind — 03 Nov 2010, 20:25
]]>2010-11-03T21:17:38+02:002010-11-03T21:17:38+02:00https://brainmodular.org/forums/viewtopic.php?t=2530&p=16726#p16726 here it is
not fully tested, but work well for what you need.
Statistics: Posted by martignasse — 03 Nov 2010, 20:17
]]>2010-11-03T20:52:08+02:002010-11-03T20:52:08+02:00https://brainmodular.org/forums/viewtopic.php?t=2530&p=16725#p16725 im not the script boss lol, martin, bsork or senso are, but ive played for a while with matrix and scripts, as martignasse was right, scripting comes soon necessary with mx manipulations, as the example above. i run out of time for now, but maybe i can make a script that do this as exemple for tomorrow evening..could help?
]]>2010-11-03T20:38:15+02:002010-11-03T20:38:15+02:00https://brainmodular.org/forums/viewtopic.php?t=2530&p=16724#p16724Statistics: Posted by soundmind — 03 Nov 2010, 19:38
]]>2010-11-03T14:48:04+02:002010-11-03T14:48:04+02:00https://brainmodular.org/forums/viewtopic.php?t=2530&p=16715#p16715
Thanks for the interest,
Here is the wkp. My main concern is the amount of patches needed to accomplish this when it works perfectly fine when concating vertically.
Unfortunatly, datas are stored by row in the matrix array, resulting in more operation complex when manipulating row length. If it was stored by col, it would be more simple for row, but more complex for col
here a little simplification with same result
but this is clearly a job to do by script, witch can make this task easily modular and expendable in addition of eating less CPU.
hope it help
Statistics: Posted by martignasse — 03 Nov 2010, 13:48
]]>2010-11-03T12:23:23+02:002010-11-03T12:23:23+02:00https://brainmodular.org/forums/viewtopic.php?t=2530&p=16712#p16712thanks to share
Statistics: Posted by nay-seven — 03 Nov 2010, 11:23
]]>2010-11-03T12:01:56+02:002010-11-03T12:01:56+02:00https://brainmodular.org/forums/viewtopic.php?t=2530&p=16709#p16709 Here is the wkp. My main concern is the amount of patches needed to accomplish this when it works perfectly fine when concating vertically.
Statistics: Posted by soundmind — 03 Nov 2010, 11:01
Statistics: Posted by nay-seven — 03 Nov 2010, 10:53
]]>2010-11-03T11:49:42+02:002010-11-03T11:49:42+02:00https://brainmodular.org/forums/viewtopic.php?t=2530&p=16707#p16707Statistics: Posted by soundmind — 03 Nov 2010, 10:49
]]>2010-11-03T04:20:44+02:002010-11-03T04:20:44+02:00https://brainmodular.org/forums/viewtopic.php?t=2530&p=16704#p16704Statistics: Posted by soundmind — 03 Nov 2010, 03:20
]]>BrainModularBrainModular Users Forum2010-11-04T18:26:31+02:00https://brainmodular.org/forums/app.php/feed/topic/25302010-11-04T18:26:31+02:002010-11-04T18:26:31+02:00https://brainmodular.org/forums/viewtopic.php?t=2530&p=16751#p16751 like the soundtrack too
]]>2010-11-03T21:31:29+02:002010-11-03T21:31:29+02:00https://brainmodular.org/forums/viewtopic.php?t=2530&p=16729#p16729Statistics: Posted by nay-seven — 03 Nov 2010, 20:31
hope it help
