ArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2010-11-03T15:41:46+02:00 https://brainmodular.org/forums/app.php/feed/topic/2529 2010-11-03T15:41:46+02:00 2010-11-03T15:41:46+02:00 https://brainmodular.org/forums/viewtopic.php?t=2529&p=16717#p16717 <![CDATA[some osc help]]> i've check the examples on their web site and use the max patch in the free max runtime 5.1
here what receive Usine :
Statistics: Posted by nay-seven — 03 Nov 2010, 14:41
2010-11-03T15:36:04+02:00 2010-11-03T15:36:04+02:00 https://brainmodular.org/forums/viewtopic.php?t=2529&p=16716#p16716 <![CDATA[some osc help]]>
you can't ie send a string followed by two float as above exemple, but you can send 3 floats.
Maybe Senso is cooking this possibility via script, i don't know, but im quasi sure it's not possible actually.
(yeah i know , it's very rare to say not possible ;) with usine ... im also surprised saying that)
according to me the send module would need either to detect wha't on individual input flows, or maybe
have a 'Types array' ie 3 2 2 would mean 'input1 is a string, input 2 and 3 are floats, ect. to make such exemple possible.
Statistics: Posted by 23fx23 — 03 Nov 2010, 14:36
2010-11-03T02:03:34+02:00 2010-11-03T02:03:34+02:00 https://brainmodular.org/forums/viewtopic.php?t=2529&p=16703#p16703 <![CDATA[some osc help]]> I've check the tutorial , work with pure data but can't find why not in Usine
I've test with different way to enter address , must be something like
layerpos/foreground but no...can't find..
maybe after a good night
Statistics: Posted by nay-seven — 03 Nov 2010, 01:03
2010-11-03T00:43:42+02:00 2010-11-03T00:43:42+02:00 https://brainmodular.org/forums/viewtopic.php?t=2529&p=16702#p16702 <![CDATA[some osc help]]>
sadldy i don't think it's actually possible since modules are set to one kind of data : integer, float or caption.
receive modules can spread differents kind of datas, but no emmit modules afaik , might be a good suggestion..
Statistics: Posted by 23fx23 — 02 Nov 2010, 23:43
2010-11-03T00:31:53+02:00 2010-11-03T00:31:53+02:00 https://brainmodular.org/forums/viewtopic.php?t=2529&p=16701#p16701 <![CDATA[some osc help]]>
i'm trying to connect usine to animata via osc.
http://animata.kibu.hu/
http://mansteri.com/2008/12/animata-osc/
so basically, i'm trying to output an osc message in the form of
/joint name x y
I would use the osc send - module with 3 data out..but how do i incorporate the "name" part in the osc message, as the module uses osc- float..or do i have to merge osc send text and osc send 2 data..
thanks in advance,
io
Statistics: Posted by iococoi — 02 Nov 2010, 23:31
/joint name x y
thanks in advance,
io
