ArrayArrayArrayArrayArrayArrayArrayArrayArray
BrainModularBrainModular Users Forum2010-10-25T11:19:55+02:00https://brainmodular.org/forums/app.php/feed/topic/25182010-10-25T11:19:55+02:002010-10-25T11:19:55+02:00https://brainmodular.org/forums/viewtopic.php?t=2518&p=16565#p16565 The midi learn is still only reading the midi data from the input, but we have a nice workaround.
]]>2010-10-25T10:42:02+02:002010-10-25T10:42:02+02:00https://brainmodular.org/forums/viewtopic.php?t=2518&p=16561#p16561i mean if your midi controller send on canal 3,filter the canal 3 in your midi in and use another canal to the midi to usine module, if not, the midi in module will also receive the transformed message..:
Statistics: Posted by nay-seven — 25 Oct 2010, 10:42
]]>2010-10-25T09:47:04+02:002010-10-25T09:47:04+02:00https://brainmodular.org/forums/viewtopic.php?t=2518&p=16560#p16560 Edit : i'm afraid entering the values manually in the remote panel does not change the issue, the "midi to usine" still seems to be interfering with the global midi input so basically it might work once, and it might not work the next time.
I'm just using : midi input > midi transf > midi to usine
If i monitor the values of the midi control change in the midi to usine module, they are not stable.
]]>2010-10-25T09:41:19+02:002010-10-25T09:41:19+02:00https://brainmodular.org/forums/viewtopic.php?t=2518&p=16559#p16559Statistics: Posted by nay-seven — 25 Oct 2010, 09:41
2010-10-25T09:00:28+02:002010-10-25T09:00:28+02:00https://brainmodular.org/forums/viewtopic.php?t=2518&p=16557#p16557Statistics: Posted by gurulogic — 25 Oct 2010, 09:00
]]>2010-10-25T08:41:57+02:002010-10-25T08:41:57+02:00https://brainmodular.org/forums/viewtopic.php?t=2518&p=16554#p16554send Midi to Usine module is designed exactly for that purpose.
]]>2010-10-25T08:21:06+02:002010-10-25T08:21:06+02:00https://brainmodular.org/forums/viewtopic.php?t=2518&p=16553#p16553midi in module and send midi to Usine module...?
Statistics: Posted by nay-seven — 25 Oct 2010, 08:21
]]>2010-10-25T07:45:50+02:002010-10-25T07:45:50+02:00https://brainmodular.org/forums/viewtopic.php?t=2518&p=16551#p16551Statistics: Posted by gurulogic — 25 Oct 2010, 07:45
]]>2010-10-25T06:08:26+02:002010-10-25T06:08:26+02:00https://brainmodular.org/forums/viewtopic.php?t=2518&p=16549#p16549 Maybe In the global setup, midi learn mode, a "learn from midi bus" feature could added. Thanks.
]]>BrainModularBrainModular Users Forum2010-10-25T11:19:55+02:00https://brainmodular.org/forums/app.php/feed/topic/25182010-10-25T11:19:55+02:002010-10-25T11:19:55+02:00https://brainmodular.org/forums/viewtopic.php?t=2518&p=16565#p16565 The midi learn is still only reading the midi data from the input, but we have a nice workaround.
]]>2010-10-25T09:00:28+02:002010-10-25T09:00:28+02:00https://brainmodular.org/forums/viewtopic.php?t=2518&p=16557#p16557Statistics: Posted by gurulogic — 25 Oct 2010, 09:00
