ArrayArrayArrayArrayArrayArrayArrayArray
BrainModularBrainModular Users Forum2010-11-13T20:29:02+02:00https://brainmodular.org/forums/app.php/feed/topic/25142010-11-13T20:29:02+02:002010-11-13T20:29:02+02:00https://brainmodular.org/forums/viewtopic.php?t=2514&p=16913#p16913Statistics: Posted by woodslanding — 13 Nov 2010, 19:29
2010-11-11T11:55:18+02:002010-11-11T11:55:18+02:00https://brainmodular.org/forums/viewtopic.php?t=2514&p=16897#p16897I'm not sure I can disable it.
]]>2010-11-11T00:00:21+02:002010-11-11T00:00:21+02:00https://brainmodular.org/forums/viewtopic.php?t=2514&p=16895#p16895 With setting visible items order: Is there a way to get the slider thumb to appear on top of the title for a fader??
Obviously it looks all wrong for the title to show over the thumb!
Statistics: Posted by woodslanding — 10 Nov 2010, 23:00
]]>2010-11-10T23:33:17+02:002010-11-10T23:33:17+02:00https://brainmodular.org/forums/viewtopic.php?t=2514&p=16894#p16894 im pretty sure it work for every other layout options, but i don't think it would work for bmp , as need to deal with files path. tried with a jpg on c: but the var was not found, when trying via send message in console we can see: "Bit map affectation is not allowed : BACK BITMAP" so i suppose it's a protection.
can use fader with frames as a workaround? (but will not work as Bg). also i found a trick if really need BG, is to set visible items in a certain order via iml, from behind to upper so the fader is always behind the other items, then can increment the fader to change the BG image of the sequence. ..but i reckon it's tricky, especially if lot of items to re-set on top, ...still a possible workaround..) i did a test and that worked, named all items exept the farder from 0 to n in order to make it easier then with the script iml set them all invisible, then back visible, so above the fader. a cool option to solve this pb would be a "force item to be under", or dynamically change all the layout preset. but maybe i did wrong and it's already possible. i guess only senso can answer that..
]]>2010-11-10T09:53:44+02:002010-11-10T09:53:44+02:00https://brainmodular.org/forums/viewtopic.php?t=2514&p=16888#p16888Statistics: Posted by woodslanding — 10 Nov 2010, 08:53
]]>2010-11-07T06:37:20+02:002010-11-07T06:37:20+02:00https://brainmodular.org/forums/viewtopic.php?t=2514&p=16794#p16794 It is still a bit awkward to use IML, but it does work.
Also I am trying not to use IML, as my cpu is right at the edge!
Statistics: Posted by woodslanding — 07 Nov 2010, 05:37
]]>2010-10-24T08:04:37+02:002010-10-24T08:04:37+02:00https://brainmodular.org/forums/viewtopic.php?t=2514&p=16524#p16524 if you speak of container or any usine interface item that have a backround color option avaible in edit layout, then now it's accessible since a few versions via iml and the SET_LAYOUT procedure. so if you place your items in a container, you can dynamically change the bacground, border or whatever avaible layout option via iml, that can be trig via sendusine message module or inside a script. if you speak of backrounf of patch i don't think it's possible, but just add a contenair will do the job. here an exemple with script:
note that if you make inputs that will trig differents colors codes, you have to disable their fastCallback in init procedure using SetFastCallback(input, FALSE);
SET_LAYOUT is awesome for that, i use it a lot, but do not abuse as it 's cpu hungry.
]]>2010-10-24T07:24:39+02:002010-10-24T07:24:39+02:00https://brainmodular.org/forums/viewtopic.php?t=2514&p=16523#p16523 Right now, it seems like the container object doesn't actuallyhave anything to do with the background object--but it seems like maybe you could put controls for the background into the container object???
Of course there may be a reason not to, which I don't understand.....
thanks, -eric
Statistics: Posted by woodslanding — 24 Oct 2010, 07:24
]]>BrainModularBrainModular Users Forum2010-11-13T20:29:02+02:00https://brainmodular.org/forums/app.php/feed/topic/25142010-11-13T20:29:02+02:002010-11-13T20:29:02+02:00https://brainmodular.org/forums/viewtopic.php?t=2514&p=16913#p16913Statistics: Posted by woodslanding — 13 Nov 2010, 19:29
]]>2010-11-11T11:55:18+02:002010-11-11T11:55:18+02:00https://brainmodular.org/forums/viewtopic.php?t=2514&p=16897#p16897I'm not sure I can disable it.
thanks, -eric
