ArrayArrayArrayArrayArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2007-02-26T09:07:51+01:00 https://brainmodular.org/forums/app.php/feed/topic/251 2007-02-26T09:07:51+01:00 2007-02-26T09:07:51+01:00 https://brainmodular.org/forums/viewtopic.php?t=251&p=1268#p1268 <![CDATA[Changing velocities]]> ---
I don't see why you would need two loops in your script. You could of course test whether there are any transposition or velocity scaling happening and, if not, just send the input array to the output array. Come to think of it, maybe you could use the same parameter for both input and output and just leave the data unaltered? I haven't tried this myself, so maybe there are some traps hidden doing it that way...
Just a wild guess, but..: One possible source of weird things happening in your script, might be that you're setting the array length before you're assigning any values to it. I've had best results with midi outputs when the length is first zeroed and the new length is set after assigning new values.
And yes, I like scripting - it satifies the geek in me, I think. In addition to give new musical possibilities, of course. I have some more or less finished patches that I'd like to put in Add-ons, but I'm waiting for the new version of Usine to be released.
Statistics: Posted by bsork — 26 Feb 2007, 09:07
2007-02-24T16:38:11+01:00 2007-02-24T16:38:11+01:00 https://brainmodular.org/forums/viewtopic.php?t=251&p=1264#p1264 <![CDATA[Changing velocities]]>
You like scripting, don't you?
Why two different outputs?
One for new velo and one for new note #?
Could it be often useful?
If not so often, just add a midi filter, no?
Velo and note # have nothing to do together, that's true.
The IF condition mixes them just to control if there is a modification in one of them. If both NO, skips the loop.
I could have do one loop for velo and one other for note #, but too slow (and generates weird things as soon as you play quickly or big chords) !
You could also save a (tiny) bit of CPU by doing the truncation of the transposition outside of the loop.
Absolutely right, Master!
Tiny bits of CPU are nothing to spare but stupid to waste!
I have to check this. My script "as changed" since I sent the one you have.
Thanks for your precious advices, Bj?rn!
Statistics: Posted by Guest — 24 Feb 2007, 16:38
2007-02-24T10:54:12+01:00 2007-02-24T10:54:12+01:00 https://brainmodular.org/forums/viewtopic.php?t=251&p=1263#p1263 <![CDATA[Changing velocities]]>
But why do you have that strange IF-test - surely the transposition value and the velocity scaling dosn't have anything to do with each other(?). You could also save a (tiny) bit of CPU by doing the truncation of the transposistion outside of the loop.
Statistics: Posted by bsork — 24 Feb 2007, 10:54
2007-02-21T16:57:32+01:00 2007-02-21T16:57:32+01:00 https://brainmodular.org/forums/viewtopic.php?t=251&p=1252#p1252 <![CDATA[Changing velocities]]>
Would it be possible to add a new Midi Filter module that where the opposite of the existing; ie removing the selected message type and let all other messages through?
I totally agree with Bj?rn!
My suggestion would be to give up with the old midi filter and to do a new one with two Outputs range :
- on the top, only the filtered signal and it's values (like now);
- on the bottom, the midi out that sends all except the filtered signal (like Bj?rn's suggestion).
Finally, as sophisticated sub-patches connections need a lot of CPU, I decided to develp by myself some midi patches or plugins that I cannot find on the Web.
Can someone suggest me some free C++ API and some tutos?
Waiting for me to be good enough, here is a script for transposition (half-steps and octaves) and velocity compressor/expander:
CODE:
// Vincent MICHEL// 20-02-2007// Note transposition and velocity compressor/expander// parameters declaration//var LLimit &#58; TParameter; // those parameters for further developments//var RLimit &#58; TParameter; // will be used to filter note range between two limits &#40;ie&#58; split keyboard&#41;var Input  &#58; Tparameter;var Oct    &#58; TParameter;var Trans  &#58; TParameter;var Vel    &#58; TParameter;var Output &#58; Tparameter;// initialisation &#58; create parametersprocedure init;begin  // LLimit &#58;= CreateParam&#40;'Left Limit',ptDataFader&#41;; // those inlets for further developments// RLimit &#58;= CreateParam&#40;'Right Limit',ptDataFader&#41;; Input  &#58;= CreateParam&#40;'In',ptMidi&#41;; Trans  &#58;= CreateParam&#40;'Transpo',ptDataFader&#41;; Oct    &#58;= CreateParam&#40;'Octave',ptDataFader&#41;; Vel    &#58;= CreateParam&#40;'Velo',ptDataFader&#41;; Output &#58;= CreateParam&#40;'Out',ptMidi&#41;; SetIsOutPut&#40;Input,false&#41;;// further developments///////////// SetIsOutPut&#40;LLimit,false&#41;;// SetFormat&#40;LLimit,'%.0f'&#41;; SetMin&#40;LLimit,0&#41;; SetMax&#40;LLimit,127&#41;; SetValue&#40;LLimit,36&#41;;// SetIsOutPut&#40;RLimit,false&#41;;// SetFormat&#40;RLimit,'%.0f'&#41;; SetMin&#40;RLimit,0&#41;; SetMax&#40;RLimit,127&#41;; SetValue&#40;RLimit,72&#41;;////////////////////////////////// SetIsOutPut&#40;Oct,false&#41;; SetFormat&#40;Oct,'%.0f'&#41;; SetMin&#40;Oct,-4&#41;; SetMax&#40;Oct,4&#41;; SetDefaultValue&#40;Oct,0&#41;; SetIsOutPut&#40;Trans,false&#41;; SetFormat&#40;Trans,'%.0f'&#41;; SetSymbol&#40;Trans,' ?T'&#41;; SetMin&#40;Trans,-11&#41;; SetMax&#40;Trans,11&#41;; SetDefaultValue&#40;Trans,0&#41;; SetIsOutPut&#40;Vel,false&#41;; SetFormat&#40;Vel,'%.0f'&#41;; SetSymbol&#40;Vel,'%'&#41;; SetMin&#40;Vel,0&#41;; SetMax&#40;Vel,400&#41;; SetDefaultValue&#40;Vel,100&#41;;  SetIsInput&#40;Output,false&#41;;end;// Global variablesvar i            &#58; integer;var nbOfMidi     &#58; integer;var ReceivedMidi &#58; TMidi;var TranspoVal   &#58; single;var VeloVal      &#58; variant;// main procbegin nbOfMidi &#58;= GetLength&#40;input&#41;;  // get the number of incoming midi codes   if nbOfMidi = 0  then begin    SetLength&#40;outPut,0&#41;; // nothing received, set out length to 0 end  else begin    SetLength&#40;outPut,nbOfMidi&#41;;// set the number of output codes    TranspoVal &#58;= getValue&#40;Trans&#41;+&#40;getValue&#40;Oct&#41; * 12&#41;;// calculate the total transpo value    VeloVal &#58;= getValue&#40;Vel&#41; / 100;// calculate the velocity factor    for i &#58;= 0 to nbOfMidi-1// loop for all input codes of polyphonic data    do begin       GetMidiArrayValue&#40;Input,i,ReceivedMidi&#41;;// get each midi data         if &#40;TranspoVal - VeloVal&#41; <> -1// only if transpo or velo <> 0         then begin            ReceivedMidi.data1 &#58;= trunc&#40;ReceivedMidi.data1&#41; + trunc&#40;TranspoVal&#41;; // transposes notes            ReceivedMidi.data2 &#58;= trunc&#40;ReceivedMidi.data2 * VeloVal&#41;; // sets compressed/expanded velo         end       SetMidiArrayValue&#40;Output,i,ReceivedMidi&#41;; // set output value         end; endend.
Check it before trust it!
Statistics: Posted by Guest — 21 Feb 2007, 16:57
2007-02-21T08:28:04+01:00 2007-02-21T08:28:04+01:00 https://brainmodular.org/forums/viewtopic.php?t=251&p=1250#p1250 <![CDATA[Changing velocities]]>
it was late when I wrote the last message and I didn't really check how the gain parameter affected the velocity; it isn't really "velocity scaling".
Not surprisingly it behaves more like an audio fader, while velocity scaling - at least to me - works in a way similar to compressors and expanders: input * ratio = output.
To Olivier: Another request for functionality...
Would it be possible to add a new Midi Filter module that where the opposite of the existing; ie removing the selected message type and let all other messages through? It would make it much simpler to create various types of midi manipulating patches. Filter the message type you want to do something with through the existing module and route another line through the new module. I know it's quite possible to this without a new module, but if you send a lot of different messages and want to make sure all them are passed, it becomes a bit clumsy. (I have a feeling that you'll have more work updating the manual than coding such a module...)
Statistics: Posted by bsork — 21 Feb 2007, 08:28
2007-02-21T00:08:28+01:00 2007-02-21T00:08:28+01:00 https://brainmodular.org/forums/viewtopic.php?t=251&p=1248#p1248 <![CDATA[Changing velocities]]>
Re your initial problem with changing velocities: It's maybe a little confusing that the velocity scaling input is called "gain" with a "db" caption. The min/max values are also typical of an audio fader, not velocity.
Statistics: Posted by bsork — 21 Feb 2007, 00:08
2007-02-20T23:44:17+01:00 2007-02-20T23:44:17+01:00 https://brainmodular.org/forums/viewtopic.php?t=251&p=1247#p1247 <![CDATA[Changing velocities]]>
Well, to change the velocities and many other things, the best solution is there : ndc Plugs
Statistics: Posted by Guest — 20 Feb 2007, 23:44
2007-02-13T04:27:44+01:00 2007-02-13T04:27:44+01:00 https://brainmodular.org/forums/viewtopic.php?t=251&p=1176#p1176 <![CDATA[Changing velocities]]> Thanxxx Olivier!
Statistics: Posted by Guest — 13 Feb 2007, 04:27
2007-02-12T08:35:24+01:00 2007-02-12T08:35:24+01:00 https://brainmodular.org/forums/viewtopic.php?t=251&p=1171#p1171 <![CDATA[Changing velocities]]> Statistics: Posted by senso — 12 Feb 2007, 08:35
2007-02-12T02:13:57+01:00 2007-02-12T02:13:57+01:00 https://brainmodular.org/forums/viewtopic.php?t=251&p=1168#p1168 <![CDATA[Changing velocities]]>
I want to be able to change velocities with a % fader.
I've tried with MIDI Filter and create midi message, but it's too complicated. Ther must be a simple way to do that, non?
Thanks.
Statistics: Posted by Guest — 12 Feb 2007, 02:13
CODE:
Thanks.
