ArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2010-10-20T21:42:50+02:00 https://brainmodular.org/forums/app.php/feed/topic/2506 2010-10-20T21:42:50+02:00 2010-10-20T21:42:50+02:00 https://brainmodular.org/forums/viewtopic.php?t=2506&p=16452#p16452 <![CDATA[Usine vst question - load only piano roll?]]>
http://www.tradlessons.com/iJammer.html
Statistics: Posted by sunhome — 20 Oct 2010, 21:42
2010-10-20T20:49:12+02:00 2010-10-20T20:49:12+02:00 https://brainmodular.org/forums/viewtopic.php?t=2506&p=16451#p16451 <![CDATA[Usine vst question - load only piano roll?]]>
LOL, I probably won't use the piano roll as much as the add on sequencers ... as the add ons look like more fun :) However the answer for the piano roll would be the same for the add-ons, so again thanks for the help.
Also I am starting to consider the possibility that of a Usine add-on like http://matrixsynth.blogspot.com/2010/06 ... -midi.html would really make my setup fun.
Regards, James
Welcome aboard James, cool link it reminds me of a software Synderphonics Manta :)
Statistics: Posted by caco — 20 Oct 2010, 20:49
2010-10-20T20:07:03+02:00 2010-10-20T20:07:03+02:00 https://brainmodular.org/forums/viewtopic.php?t=2506&p=16450#p16450 <![CDATA[Usine vst question - load only piano roll?]]> However the answer for the piano roll would be the same for the add-ons, so again thanks for the help.
Regards, James
Statistics: Posted by sunhome — 20 Oct 2010, 20:07
2010-10-20T20:03:08+02:00 2010-10-20T20:03:08+02:00 https://brainmodular.org/forums/viewtopic.php?t=2506&p=16449#p16449 <![CDATA[Usine vst question - load only piano roll?]]> Image
Statistics: Posted by nay-seven — 20 Oct 2010, 20:03
2010-10-20T19:53:19+02:00 2010-10-20T19:53:19+02:00 https://brainmodular.org/forums/viewtopic.php?t=2506&p=16448#p16448 <![CDATA[Usine vst question - load only piano roll?]]>
Statistics: Posted by sunhome — 20 Oct 2010, 19:53
2010-10-20T19:45:27+02:00 2010-10-20T19:45:27+02:00 https://brainmodular.org/forums/viewtopic.php?t=2506&p=16447#p16447 <![CDATA[Usine vst question - load only piano roll?]]> Statistics: Posted by nay-seven — 20 Oct 2010, 19:45
2010-10-20T19:15:00+02:00 2010-10-20T19:15:00+02:00 https://brainmodular.org/forums/viewtopic.php?t=2506&p=16446#p16446 <![CDATA[Usine vst question - load only piano roll?]]> Statistics: Posted by nay-seven — 20 Oct 2010, 19:15
2010-10-20T19:08:03+02:00 2010-10-20T19:08:03+02:00 https://brainmodular.org/forums/viewtopic.php?t=2506&p=16445#p16445 <![CDATA[Usine vst question - load only piano roll?]]> in cantabile next the piano , on the left you have 4 button , right click on one and choose customize / choose the midi controller number you want
in Usine add a switch to the visible inlet of the piano roll
right click on it choose remote mode toggle and then midi learn it with the cantabile button..et hop
you have a button in cantabile who open the piano roll...
Statistics: Posted by nay-seven — 20 Oct 2010, 19:08
2010-10-20T18:57:07+02:00 2010-10-20T18:57:07+02:00 https://brainmodular.org/forums/viewtopic.php?t=2506&p=16444#p16444 <![CDATA[Usine vst question - load only piano roll?]]>
Statistics: Posted by sunhome — 20 Oct 2010, 18:57
2010-10-20T18:55:33+02:00 2010-10-20T18:55:33+02:00 https://brainmodular.org/forums/viewtopic.php?t=2506&p=16443#p16443 <![CDATA[Usine vst question - load only piano roll?]]>
you mean : Usine pro standalone 5.25xx/files/demo...?
Ok - I am gald there are sample projects to learn from. It seems in the Usine browser I do not see the demo files to load thus my question; In windows explorer as you mentioned in the Demo folder I see lots of I see there are lots of .pat projects to workthrough.
Regards, James
Statistics: Posted by sunhome — 20 Oct 2010, 18:55
2010-10-20T18:43:58+02:00 2010-10-20T18:43:58+02:00 https://brainmodular.org/forums/viewtopic.php?t=2506&p=16442#p16442 <![CDATA[Usine vst question - load only piano roll?]]> Statistics: Posted by nay-seven — 20 Oct 2010, 18:43
2010-10-20T18:38:24+02:00 2010-10-20T18:38:24+02:00 https://brainmodular.org/forums/viewtopic.php?t=2506&p=16441#p16441 <![CDATA[Usine vst question - load only piano roll?]]>
Regards, James
Statistics: Posted by sunhome — 20 Oct 2010, 18:38
2010-10-20T18:28:14+02:00 2010-10-20T18:28:14+02:00 https://brainmodular.org/forums/viewtopic.php?t=2506&p=16440#p16440 <![CDATA[Usine vst question - load only piano roll?]]>
edit: I'm half asleep, there's a better way. Assuming this is what you were trying to do?
Statistics: Posted by gurulogic — 20 Oct 2010, 18:28
2010-10-20T18:28:07+02:00 2010-10-20T18:28:07+02:00 https://brainmodular.org/forums/viewtopic.php?t=2506&p=16439#p16439 <![CDATA[Usine vst question - load only piano roll?]]> Statistics: Posted by nay-seven — 20 Oct 2010, 18:28
2010-10-20T18:26:41+02:00 2010-10-20T18:26:41+02:00 https://brainmodular.org/forums/viewtopic.php?t=2506&p=16438#p16438 <![CDATA[Usine vst question - load only piano roll?]]> the piano roll is a module of Usine so you have to run Usine to use it..
but welcome in the gold members world...:)
Statistics: Posted by nay-seven — 20 Oct 2010, 18:26
2010-10-20T18:22:56+02:00 2010-10-20T18:22:56+02:00 https://brainmodular.org/forums/viewtopic.php?t=2506&p=16437#p16437 <![CDATA[Usine vst question - load only piano roll?]]>
Regards, James
Statistics: Posted by sunhome — 20 Oct 2010, 18:22
2010-10-20T18:19:33+02:00 2010-10-20T18:19:33+02:00 https://brainmodular.org/forums/viewtopic.php?t=2506&p=16436#p16436 <![CDATA[Usine vst question - load only piano roll?]]>
Can I just load the Usine Piano roll when uisng the vst version? I am using Cantabile as my host; The one thing I have been wanting for Cantabile is just a piano roll.
Using Usine as a vst, I have learned how to add the paino roll module and then setup the midi out so it does work. But I am a bit curious, since I have to go through a few steps is there any way to only get the piano roll to open instead of going through the Usine main screen?
Regards, James
Statistics: Posted by sunhome — 20 Oct 2010, 18:19
Regards, James
Regards, James
Regards, James
Regards, James
Regards, James
Regards, James
