ArrayArrayArrayArrayArray
BrainModularBrainModular Users Forum2010-10-18T21:51:37+02:00https://brainmodular.org/forums/app.php/feed/topic/24962010-10-18T21:51:37+02:002010-10-18T21:51:37+02:00https://brainmodular.org/forums/viewtopic.php?t=2496&p=16410#p16410 here it is!
Statistics: Posted by manecante — 18 Oct 2010, 21:51
]]>2010-10-18T11:05:38+02:002010-10-18T11:05:38+02:00https://brainmodular.org/forums/viewtopic.php?t=2496&p=16394#p16394i've used the matrix to open the layout of each effect ( first row blue ) second row is to adjust each effect volume for the audio in third row is to adjust effect 2 re-inject in effect 1 ( but dangerous , i've limit but not sure it's enough)
Statistics: Posted by nay-seven — 18 Oct 2010, 11:05
]]>2010-10-17T20:12:28+02:002010-10-17T20:12:28+02:00https://brainmodular.org/forums/viewtopic.php?t=2496&p=16378#p16378Statistics: Posted by manecante — 17 Oct 2010, 20:12
Statistics: Posted by nay-seven — 17 Oct 2010, 19:38
]]>2010-10-17T19:07:32+02:002010-10-17T19:07:32+02:00https://brainmodular.org/forums/viewtopic.php?t=2496&p=16374#p16374i am having issues trying to make a matrix working like rackmode. Basically i would like to be able to route each cell corresponding to a FX to another. I started with a simple 2x2 matrix changing the matrix mixer example. But with this example you can only route one time one cell to another (corresponding to the mode all in grid mode) and i would like to do something like the rack mode, For example route the sound coming in to FX1, then from FX1 route to FX3, from FX3 route to FX2 and so on. So in my patch, the Column x and the Row x are corresponding to the same FX.I am aware it could create some trouble with feedback but avoing to route the colum and row having the same number, it should be possible, no?
Statistics: Posted by manecante — 17 Oct 2010, 19:07
]]>BrainModularBrainModular Users Forum2010-10-18T21:51:37+02:00https://brainmodular.org/forums/app.php/feed/topic/24962010-10-18T21:51:37+02:002010-10-18T21:51:37+02:00https://brainmodular.org/forums/viewtopic.php?t=2496&p=16410#p16410 here it is!
]]>2010-10-17T19:38:37+02:002010-10-17T19:38:37+02:00https://brainmodular.org/forums/viewtopic.php?t=2496&p=16376#p16376
