ArrayArrayArrayArrayArrayArrayArray
BrainModularBrainModular Users Forum2010-10-04T03:56:38+01:00https://brainmodular.org/forums/app.php/feed/topic/24652010-10-04T03:56:38+01:002010-10-04T03:56:38+01:00https://brainmodular.org/forums/viewtopic.php?t=2465&p=16171#p16171 Usine needs to know where to look for them surely??? I don't see a place to specify this. I always just give up on these because there are hundreds of them in the folder, and I never have bothered to dig my own out.
I guess I could sort by date, and mine would all be at the end....
I migrated the jpegs to my library, and that works okay, because I specify where the file goes.....
I'll try it, and if I have problems, I'll do the rest of the install.
A FR would be an easier upgrade process. Especially with Usine's fast development process!!
Statistics: Posted by woodslanding — 04 Oct 2010, 04:56
]]>2010-10-04T03:50:06+01:002010-10-04T03:50:06+01:00https://brainmodular.org/forums/viewtopic.php?t=2465&p=16170#p16170 Usine needs to know where to look for them surely??? I don't see a place to specify this. I always just give up on these because there are hundreds of them in the folder, and I never have bothered to dig my own out.
Statistics: Posted by woodslanding — 04 Oct 2010, 04:50
]]>2010-10-03T08:38:50+01:002010-10-03T08:38:50+01:00https://brainmodular.org/forums/viewtopic.php?t=2465&p=16163#p16163Statistics: Posted by nay-seven — 03 Oct 2010, 09:38
2010-10-03T04:51:29+01:002010-10-03T04:51:29+01:00https://brainmodular.org/forums/viewtopic.php?t=2465&p=16162#p16162Statistics: Posted by woodslanding — 03 Oct 2010, 05:51
]]>2010-10-02T19:46:41+01:002010-10-02T19:46:41+01:00https://brainmodular.org/forums/viewtopic.php?t=2465&p=16161#p16161what kind of files you have in the files section..? you know that user modules, for example, can be in your personal library....
Statistics: Posted by nay-seven — 02 Oct 2010, 20:46
]]>2010-10-02T18:47:33+01:002010-10-02T18:47:33+01:00https://brainmodular.org/forums/viewtopic.php?t=2465&p=16157#p16157 I have a lot of custom items in 'files', so just wondering.....
Statistics: Posted by woodslanding — 02 Oct 2010, 19:47
]]>2010-09-30T12:59:08+01:002010-09-30T12:59:08+01:00https://brainmodular.org/forums/viewtopic.php?t=2465&p=16120#p16120This version fixes several details in the sequencer and the conductor. [large]fixed bugs[/large] - [global Synchro] sometime the first notes of a sequence are not played when the Auto Restart option is enabled. - [conductor] sometime the last line can't be recalled - [conductor] the paste bank command doesn't work - [sequencer] the SendAllNotesOff sent at the beginning of a patch can cause troubles.
]]>BrainModularBrainModular Users Forum2010-10-04T03:56:38+01:00https://brainmodular.org/forums/app.php/feed/topic/24652010-10-04T03:56:38+01:002010-10-04T03:56:38+01:00https://brainmodular.org/forums/viewtopic.php?t=2465&p=16171#p16171 Usine needs to know where to look for them surely??? I don't see a place to specify this. I always just give up on these because there are hundreds of them in the folder, and I never have bothered to dig my own out.
]]>2010-10-03T04:51:29+01:002010-10-03T04:51:29+01:00https://brainmodular.org/forums/viewtopic.php?t=2465&p=16162#p16162Statistics: Posted by woodslanding — 03 Oct 2010, 05:51
