ArrayArrayArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2010-09-23T21:37:36+01:00 https://brainmodular.org/forums/app.php/feed/topic/2449 2010-09-23T21:37:36+01:00 2010-09-23T21:37:36+01:00 https://brainmodular.org/forums/viewtopic.php?t=2449&p=16009#p16009 <![CDATA[conductor lite all visible]]> I prefer this solution than hard coding into Usine itself.
It's more flexible even if it's can be harder.
Statistics: Posted by senso — 23 Sep 2010, 22:37
2010-09-23T20:43:47+01:00 2010-09-23T20:43:47+01:00 https://brainmodular.org/forums/viewtopic.php?t=2449&p=16004#p16004 <![CDATA[conductor lite all visible]]> Statistics: Posted by Alain Vankenhove — 23 Sep 2010, 21:43
2010-09-22T05:35:23+01:00 2010-09-22T05:35:23+01:00 https://brainmodular.org/forums/viewtopic.php?t=2449&p=15943#p15943 <![CDATA[conductor lite all visible]]>
But aside from what Senso has already mentioned: As you can create your own personal interface for just about anything in Usine, is there really any need for customizing the standard GUI?
probably not ;)
Although somebody just asked for it.....
For me, I wish I could change the conductor layout. I write presets in live performance, and the lettering is so VERY small..... and there is no other place or way to name presets, right?
Until we get an 'EditableTextfield' module and a 'current preset name' input on the conductor module.....
Statistics: Posted by woodslanding — 22 Sep 2010, 06:35
2010-09-21T20:46:29+01:00 2010-09-21T20:46:29+01:00 https://brainmodular.org/forums/viewtopic.php?t=2449&p=15928#p15928 <![CDATA[conductor lite all visible]]>
like the sequencer is annoying if you don't use it??
Point taken - sorry...:/
Statistics: Posted by bsork — 21 Sep 2010, 21:46
2010-09-21T18:03:22+01:00 2010-09-21T18:03:22+01:00 https://brainmodular.org/forums/viewtopic.php?t=2449&p=15919#p15919 <![CDATA[conductor lite all visible]]>
I think a nice suggestion would be to allow the toolbar to be customized, like most other software (word, photoshop, etc)......
On my monitor, there would be plenty of room for the conductor. But I don't really need it either.
-e
Statistics: Posted by woodslanding — 21 Sep 2010, 19:03
2010-09-21T18:00:29+01:00 2010-09-21T18:00:29+01:00 https://brainmodular.org/forums/viewtopic.php?t=2449&p=15916#p15916 <![CDATA[conductor lite all visible]]> also the window position is memorized.
I'm sure it will do the trick!
Statistics: Posted by senso — 21 Sep 2010, 19:00
2010-09-21T13:10:30+01:00 2010-09-21T13:10:30+01:00 https://brainmodular.org/forums/viewtopic.php?t=2449&p=15902#p15902 <![CDATA[conductor lite all visible]]> Statistics: Posted by bsork — 21 Sep 2010, 14:10
2010-09-21T12:59:58+01:00 2010-09-21T12:59:58+01:00 https://brainmodular.org/forums/viewtopic.php?t=2449&p=15900#p15900 <![CDATA[conductor lite all visible]]> my suggestion is simple. What do you think to place conductor lite on the right of the console, all the time visible,
Alain,
Trumpet player
A7C
TC Konnekt 24 D
MPD 24
AXIOM 25
BCR 2000
FCB 1010
Statistics: Posted by Alain Vankenhove — 21 Sep 2010, 13:59
probably not ;)
-e
Alain,
Trumpet player
A7C
TC Konnekt 24 D
MPD 24
AXIOM 25
BCR 2000
FCB 1010
