also looking for an auto_dectect of peaks by analisys of wavform array. if some has code idea for that 'amplitude over time ' detection (vs absolute detection) on array s let me know...
I am definitely looking forward to this. this would make the REX-like functionality complete.
Statistics: Posted by soundmind — 12 Oct 2010, 22:34
]]>2010-10-12T14:23:06+01:002010-10-12T14:23:06+01:00https://brainmodular.org/forums/viewtopic.php?t=2393&p=16332#p16332and it's a bit webby, ill make a more clean scripted V2.
....also looking for an auto_dectect of peaks by analisys of wavform array. if some has code idea for that 'amplitude over time ' detection (vs absolute detection) on array s let me know...
]]>2010-10-11T16:18:21+01:002010-10-11T16:18:21+01:00https://brainmodular.org/forums/viewtopic.php?t=2393&p=16300#p16300i got hard work on my livematrix for now, but next is grain thing tests, let me know if find interesting things.
]]>2010-10-11T08:22:45+01:002010-10-11T08:22:45+01:00https://brainmodular.org/forums/viewtopic.php?t=2393&p=16290#p16290Statistics: Posted by soundmind — 11 Oct 2010, 09:22
2010-09-14T07:29:37+01:002010-09-14T07:29:37+01:00https://brainmodular.org/forums/viewtopic.php?t=2393&p=15713#p15713Statistics: Posted by nay-seven — 14 Sep 2010, 08:29
]]>2010-09-14T06:09:48+01:002010-09-14T06:09:48+01:00https://brainmodular.org/forums/viewtopic.php?t=2393&p=15710#p15710Statistics: Posted by 23fx23 — 14 Sep 2010, 07:09
]]>2010-09-14T06:05:28+01:002010-09-14T06:05:28+01:00https://brainmodular.org/forums/viewtopic.php?t=2393&p=15709#p15709@23fx loop masher no preset works well doesn't uses lot of memory (about 30 % but i'm always at this rate even with 8 or 9 tracks) and 2 or 3 % cpu very good groove machine and i get it in full sight in IB very fine @ Nay morphusine is OK in IB i like it too in later
Statistics: Posted by waolelaid — 14 Sep 2010, 07:05
]]>2010-09-13T20:18:40+01:002010-09-13T20:18:40+01:00https://brainmodular.org/forums/viewtopic.php?t=2393&p=15699#p15699on another thread as i said just a thing in asio when i only have the internal sound card I find some audio from the graphic card ATI I also have USB audio and SPDIF I believe that all those audio derange the external sound card we tried the card on my daughter computer Mac in 5 minutes all goes right tested with logic I have contacted the technical support of presonus who explain me all the things to do as disable the internal sound card but i didn't disable all well i stop here i must gather all the manipulations I did and I open a new thread thank again i'm going to eat
Statistics: Posted by waolelaid — 13 Sep 2010, 21:18
]]>2010-09-13T19:20:36+01:002010-09-13T19:20:36+01:00https://brainmodular.org/forums/viewtopic.php?t=2393&p=15698#p15698be sure you download the v2b
about asio4all , this don't work only with your internal sound card , you can also choose your reel sound card in his panel here you can see my internal sound card + 2 others soundcard
Statistics: Posted by nay-seven — 13 Sep 2010, 20:20
]]>2010-09-13T18:39:30+01:002010-09-13T18:39:30+01:00https://brainmodular.org/forums/viewtopic.php?t=2393&p=15697#p15697i try to do short @Nay thank you for the patch but in fact i installed morphusine_demo2.zip and in it there is no "template" so it explains why i don't find "vst morph" and I tried with asio but i'm sure that it comes from the internal sound card @gurulogic thank you to try to help me I'm going to see the link you indicate but find a new fire wire card with texas instruments chip where ? i'll open a new thread in "general discussion" if it's the right place but before i'm going to have a look at your link thank you once again to all of you have good evening and night too Ho the one I forgot congratulation to olivier who programs faster than we can test In later
Statistics: Posted by waolelaid — 13 Sep 2010, 19:39
]]>2010-09-13T08:45:12+01:002010-09-13T08:45:12+01:00https://brainmodular.org/forums/viewtopic.php?t=2393&p=15680#p15680http://www.thesycon.de/deu/latency_check.shtml You might also consider purchasing a new firewire card, preferably one that uses a texas instruments chip. You shouldn't be having these types of audio problems even on a crappy computer. Feel free to start a new thread if you need any further troubleshooting help . I would be happy to help as much as I can.
Statistics: Posted by gurulogic — 13 Sep 2010, 09:45
]]>2010-09-13T07:35:39+01:002010-09-13T07:35:39+01:00https://brainmodular.org/forums/viewtopic.php?t=2393&p=15676#p15676download here about your click and drag problem , are you sure you have install the templates : Extract the archive and just copy the complete dir named templates by nay-seven in your Usine/files/templates dir.
about your asio problem , it's not easy to help you , have you try asio4all...?
Statistics: Posted by nay-seven — 13 Sep 2010, 08:35
]]>2010-09-13T03:52:35+01:002010-09-13T03:52:35+01:00https://brainmodular.org/forums/viewtopic.php?t=2393&p=15668#p15668I don't know if it is 21 or 19 but the screen is 46.5cm x 29.5 cm but if i put on a higher resolution i can't read its too small i've a very bad sight i've installed the Latest Matrix Pack (1.2) at the same time that 5.25b8 another thing i discovered in morphusine when i click and drag from an inlet of helios (i didn't change the vsti) i have not in the menu "Vst Morph" as shown in the wiki doku i'm going to install the latest version but it's always a lot of difficulty because usine doesn't recognise the Asio and i must always stop the computer even disconnect it and after one hour reconnect and restart the computer and sometimes it works I bought a new sound card Presonus Fire Studio Mobile I installed it it works well while 30 minutes and when i start Usine the sound became very dirt as if i crush stones at 256,512 buffer i didn't go under I am tired I don't understand the functioning of the internal sound card in W7 (i have no audio in) only the micro in fact i don't know what to do I'm ready to give up !!! exuse me Regards
Statistics: Posted by waolelaid — 13 Sep 2010, 04:52
]]>2010-09-12T22:26:03+01:002010-09-12T22:26:03+01:00https://brainmodular.org/forums/viewtopic.php?t=2393&p=15660#p15660 Ive templ uploaded a new version where I cleared all the presets exept kept only page 3 for instant demo. the file droped down from 100megs to 38megs, maybe it will better load for you... be sure ya have matrix 1.2, and recommand usine beta10 or higher, even thougth it should work on beta8.
/addons/others.
@waleloid: try to increase your screen res, and maybe pressing IB to go in interface builder full screen mode can help ya see more? also can click on yellow circles of usine tracks to reduce them... hope it helps.. let me know guys how it works...
]]>2010-09-12T21:54:18+01:002010-09-12T21:54:18+01:00https://brainmodular.org/forums/viewtopic.php?t=2393&p=15658#p15658i will try to investigate tonight but no clues,...
waleloid: It's probably a screen resolution problem, i am in 1380x960 15' screen and nay probably in hi rez too, so if your screen resolution is lower, i feel it's 1024 or 800, there will be zoom and cliping as you mention. I can understand it's boring to rescale all items, even if hopefully matrix make it's easier than moving X buttons.
maybe you can try to increase your desktop resolution, are you on max? what's your screen size and resoluriob?
]]>2010-09-12T21:49:47+01:002010-09-12T21:49:47+01:00https://brainmodular.org/forums/viewtopic.php?t=2393&p=15657#p15657Statistics: Posted by nay-seven — 12 Sep 2010, 22:49
]]>2010-09-12T21:42:29+01:002010-09-12T21:42:29+01:00https://brainmodular.org/forums/viewtopic.php?t=2393&p=15655#p15655Does not even load completely even with engine off. When opening the patch it only shows a big white box before slowing to a halt. I'm assuming the box is the slicers control panel but for some reason can't see the graphics and usine stops responding. Maybe it is a RAM issue because I only have 512 Megs? Hi ,i have the same problem but with 3 Gb ram on W7 and another question which is not only for your patch why with morphusine,synthayan,loopmasher and other i don't remember I can't reach to have it entirely on my screen even when i open in an empty workspace ? it's very difficult to try to understand the functioning, of a patch when you can't have it in full sight I only see half of the patches i try to reduce but after I waste things of the paches I'm on the 5.25b8 why does those pathes are too big and how to reduce them without waste things of the interface thank for your answer good night
Statistics: Posted by waolelaid — 12 Sep 2010, 22:42
Statistics: Posted by gurulogic — 07 Sep 2010, 08:34
]]>2010-09-07T03:22:53+01:002010-09-07T03:22:53+01:00https://brainmodular.org/forums/viewtopic.php?t=2393&p=15485#p15485Does not even load completely even with engine off. When opening the patch it only shows a big white box before slowing to a halt. I'm assuming the box is the slicers control panel but for some reason can't see the graphics and usine stops responding. Maybe it is a RAM issue because I only have 512 Megs?
Statistics: Posted by soundmind — 07 Sep 2010, 04:22
]]>2010-09-06T21:33:31+01:002010-09-06T21:33:31+01:00https://brainmodular.org/forums/viewtopic.php?t=2393&p=15483#p15483mmm, it doesn't load with usine engine off? or it freeze when you swich on? Anyway there is a pb with the patch i have to fix, database is too big, but not sure how ill can save datas better way..i think i stored too many datas to pm than make it's heavy. Ill try to see how to corect that, but i guess it will loodse the presets, anyway, you will then be able to create yours..i need to find a way to clear or destroy presets maybe. ill try to check that tomorow.
@guru oh yeah, that's explain why i don't found it back im pretty sure i opened one of your patch that had steps to offset slice and was working not bad ne? maybe we exchanged a test on uploader..anyway no worries..
]]>2010-09-06T20:17:02+01:002010-09-06T20:17:02+01:00https://brainmodular.org/forums/viewtopic.php?t=2393&p=15482#p15482Statistics: Posted by soundmind — 06 Sep 2010, 21:17
]]>2010-09-06T19:47:34+01:002010-09-06T19:47:34+01:00https://brainmodular.org/forums/viewtopic.php?t=2393&p=15480#p15480
Statistics: Posted by gurulogic — 06 Sep 2010, 20:47
]]>2010-09-06T18:06:00+01:002010-09-06T18:06:00+01:00https://brainmodular.org/forums/viewtopic.php?t=2393&p=15477#p15477 if i well remember it'was ready to be converted to a 8x8. or 16x16. checking back my patch it's a bit messy hard wired complex to understand i guess, but don't hesitate if need help.
]]>2010-09-14T07:29:37+01:002010-09-14T07:29:37+01:00https://brainmodular.org/forums/viewtopic.php?t=2393&p=15713#p15713Statistics: Posted by nay-seven — 14 Sep 2010, 08:29
/addons/others.
