ArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArray
BrainModularBrainModular Users Forum2010-08-26T20:05:45+02:00https://brainmodular.org/forums/app.php/feed/topic/23802010-08-26T20:05:45+02:002010-08-26T20:05:45+02:00https://brainmodular.org/forums/viewtopic.php?t=2380&p=15336#p15336Statistics: Posted by nay-seven — 26 Aug 2010, 20:05
2010-08-26T19:55:31+02:002010-08-26T19:55:31+02:00https://brainmodular.org/forums/viewtopic.php?t=2380&p=15334#p15334 Thanks Senso !! And Nay for your advices.
I dont know wath apend but it works... i enderstand the valid osc adress now.
Thanks a lot.
Statistics: Posted by multiphone — 26 Aug 2010, 19:55
if not , can you try to make a screen capture of you osc console here mine ( i've disable osc here to stop message, click on one message to see details in the lower window and be careful you don't have adress like /2/accxyz or something like this...
Statistics: Posted by nay-seven — 26 Aug 2010, 18:46
]]>2010-08-26T18:33:43+02:002010-08-26T18:33:43+02:00https://brainmodular.org/forums/viewtopic.php?t=2380&p=15326#p15326 no effect !
Strange !?
Statistics: Posted by multiphone — 26 Aug 2010, 18:33
]]>2010-08-26T18:18:30+02:002010-08-26T18:18:30+02:00https://brainmodular.org/forums/viewtopic.php?t=2380&p=15325#p15325 first ,don't worry with ip and try to just to replace /usine/ by /accxyz/ must be enough
Statistics: Posted by nay-seven — 26 Aug 2010, 18:18
]]>2010-08-26T18:01:33+02:002010-08-26T18:01:33+02:00https://brainmodular.org/forums/viewtopic.php?t=2380&p=15324#p15324 But as allway i feel i'm a big nozzle
So,
The info get in the console from 169.254.137.220:/accxyz (fff)
so i type 169.254.137.220 and remplace /usine/ ???
i'm lost in OSC
Statistics: Posted by multiphone — 26 Aug 2010, 18:01
]]>2010-08-26T17:42:18+02:002010-08-26T17:42:18+02:00https://brainmodular.org/forums/viewtopic.php?t=2380&p=15323#p15323the adress for osc is what you see in the console , by default , it's Usine , depending from what device you send OSC here an example : about the port , it's the same problem: your device ( for example an ipod )must send OSC on the same port than Usine ( by default in the osc setup window = 8000
Statistics: Posted by nay-seven — 26 Aug 2010, 17:42
]]>2010-08-26T17:34:22+02:002010-08-26T17:34:22+02:00https://brainmodular.org/forums/viewtopic.php?t=2380&p=15322#p15322 Thaks for reaction.
The right adress in the module ? If i have 0.0.0.0. or 169.254.137.125 is the same : No entry...
In port in the OSC Setup is...???
Thanks in advance.
Statistics: Posted by multiphone — 26 Aug 2010, 17:34
]]>2010-08-26T17:13:35+02:002010-08-26T17:13:35+02:00https://brainmodular.org/forums/viewtopic.php?t=2380&p=15321#p15321Statistics: Posted by 23fx23 — 26 Aug 2010, 17:13
]]>2010-08-26T16:58:34+02:002010-08-26T16:58:34+02:00https://brainmodular.org/forums/viewtopic.php?t=2380&p=15320#p15320 i have a simple question about OSC conection.
I see the OSC info enter in the console of Usine but i dont see this infos in the OSC receive module...
I forget something ?
Statistics: Posted by multiphone — 26 Aug 2010, 16:58
]]>BrainModularBrainModular Users Forum2010-08-26T20:05:45+02:00https://brainmodular.org/forums/app.php/feed/topic/23802010-08-26T20:05:45+02:002010-08-26T20:05:45+02:00https://brainmodular.org/forums/viewtopic.php?t=2380&p=15336#p15336Statistics: Posted by nay-seven — 26 Aug 2010, 20:05
]]>2010-08-26T19:55:31+02:002010-08-26T19:55:31+02:00https://brainmodular.org/forums/viewtopic.php?t=2380&p=15334#p15334 Thanks Senso !! And Nay for your advices.
Thanks a lot.
Strange !?
So,
i'm lost in OSC
Thanks in advance.
