ArrayArrayArray
BrainModularBrainModular Users Forum2010-08-18T14:29:17+01:00https://brainmodular.org/forums/app.php/feed/topic/23692010-08-18T14:29:17+01:002010-08-18T14:29:17+01:00https://brainmodular.org/forums/viewtopic.php?t=2369&p=15252#p15252Statistics: Posted by damstraversaz — 18 Aug 2010, 15:29
2010-08-18T10:18:03+01:002010-08-18T10:18:03+01:00https://brainmodular.org/forums/viewtopic.php?t=2369&p=15248#p15248the piano roll send midi information, no 0-1 values ( what is waiting the direct inlet of the HeliosII) the Helios II don't have midi learn built in , so you can send direct CC midi but here a work around : use the module send midi to usine( modules/input-outputs) and assign the same CC number to your knob ( via the remote panel in your patch ), works better this way..
( with others VSTI , at least those who have midi learn or midi assign , you can send CC directly by the midi in )
ask if any question
Statistics: Posted by nay-seven — 18 Aug 2010, 11:18
]]>2010-08-18T09:50:36+01:002010-08-18T09:50:36+01:00https://brainmodular.org/forums/viewtopic.php?t=2369&p=15247#p15247first sorry for my poor english... I begin to use usine for midi and have a small question about cc curve from the piano roll. I try to make a cc curve for the filter of helios , like a automation enveloppe ( ableton live, reaper, cubase etc...)
but it seems to be not possible to do smooth curve ( I try with normal and log scale for the fader) the filter jump to the maximum very quick. and the fader is on the "1" position, although the cc curve is just on 64. can somebody help me ? thanks a lot for reading
damien
Statistics: Posted by damstraversaz — 18 Aug 2010, 10:50
]]>BrainModularBrainModular Users Forum2010-08-18T14:29:17+01:00https://brainmodular.org/forums/app.php/feed/topic/23692010-08-18T14:29:17+01:002010-08-18T14:29:17+01:00https://brainmodular.org/forums/viewtopic.php?t=2369&p=15252#p15252Statistics: Posted by damstraversaz — 18 Aug 2010, 15:29
]]>2010-08-18T10:18:03+01:002010-08-18T10:18:03+01:00https://brainmodular.org/forums/viewtopic.php?t=2369&p=15248#p15248the piano roll send midi information, no 0-1 values ( what is waiting the direct inlet of the HeliosII) the Helios II don't have midi learn built in , so you can send direct CC midi but here a work around : use the module send midi to usine( modules/input-outputs) and assign the same CC number to your knob ( via the remote panel in your patch ), works better this way..
ask if any question
damien
