ArrayArrayArrayArrayArrayArrayArrayArrayArrayArray
BrainModularBrainModular Users Forum2010-08-18T12:11:45+01:00https://brainmodular.org/forums/app.php/feed/topic/23632010-08-18T12:11:45+01:002010-08-18T12:11:45+01:00https://brainmodular.org/forums/viewtopic.php?t=2363&p=15250#p15250Statistics: Posted by 23fx23 — 18 Aug 2010, 13:11
2010-08-18T04:01:43+01:002010-08-18T04:01:43+01:00https://brainmodular.org/forums/viewtopic.php?t=2363&p=15246#p15246Statistics: Posted by gurulogic — 18 Aug 2010, 05:01
]]>2010-08-18T03:49:15+01:002010-08-18T03:49:15+01:00https://brainmodular.org/forums/viewtopic.php?t=2363&p=15245#p15245do you make a contest with Nay
Statistics: Posted by waolelaid — 18 Aug 2010, 04:49
]]>2010-08-16T11:08:30+01:002010-08-16T11:08:30+01:00https://brainmodular.org/forums/viewtopic.php?t=2363&p=15195#p15195 I should probably remove pianoroll from the sub patch too. I wanted to test another way, instead of using array, that have the problem to overide parameters bloxking mouse on vsti gui,
using iml that set wireless would let other param move ( but is it recommended/not too cpu hog, what do you think?) or using iml that creates wires (but tricky to un-rewire if learn changed as iwould need either to keep a strong map of what was linked to delete without scanning all vst pins...
im more about testing iml, so instead if constantly setiing the whole array, would set only 4x params, but as really often updated, iw onder if iml is recommended for that...
]]>2010-08-16T07:35:39+01:002010-08-16T07:35:39+01:00https://brainmodular.org/forums/viewtopic.php?t=2363&p=15194#p15194 Why do you upload a .wkp file? I think it could be easier with .pat file because it contains a single patch?
]]>2010-08-16T00:31:16+01:002010-08-16T00:31:16+01:00https://brainmodular.org/forums/viewtopic.php?t=2363&p=15192#p15192 yes the pianoroll was just for instant testing
btw I've delete the piano roll to use with other sequences and buses and discover your help text who was hidden by it...
Statistics: Posted by nay-seven — 16 Aug 2010, 00:26
]]>2010-08-15T23:09:48+01:002010-08-15T23:09:48+01:00https://brainmodular.org/forums/viewtopic.php?t=2363&p=15190#p15190didn't test with other vst ohh seems tricky
but cool if found a way that works..
yup tomorow evening ill make a wiki .
I didn't yet because i imagine a better way with iml wiring instead of arrays, that would allow to tweak others params while automations are running. i think it's not possible via actual arrayIn technique...or other hand this one is more handy to deal, soo..ill make a wiki first for this one promise ;, then i i find a secure way to deal with IML wiring, ill post a V2, maybe that ill update to 8 params then... i also have to test all your recent baby's
]]>2010-08-15T22:44:41+01:002010-08-15T22:44:41+01:00https://brainmodular.org/forums/viewtopic.php?t=2363&p=15189#p15189now , at first it won't work directly for me ,so I've add a combo box to the program inlet of the vsti and look for a preset who works , then it's ok ( I've often this problem with Helios II, first programs don't receive midi note the same way ..? )
it's also seems that to use it with others vsti , there's an order to respect :
switch to edit vst mode connect the new vst/vsti switch to learn/block mode and choose your 4 parameters then unswitch edit vst and learn/block
if not all parameters are set to 0..
a wiki page..?:D
Statistics: Posted by nay-seven — 15 Aug 2010, 23:44
Provides a quick and easy way to rec 4 vst automations, without searching and wiring.
features:
_Vst Learn function: move a parameter on vst gui to assign to selected automation lane. _directly rec selected automation via a fader or edit lines. _from 1 to 8 bars, each loop with independant duration but all synced. _roll individal automations. _16 presets.
]]>BrainModularBrainModular Users Forum2010-08-18T12:11:45+01:00https://brainmodular.org/forums/app.php/feed/topic/23632010-08-18T12:11:45+01:002010-08-18T12:11:45+01:00https://brainmodular.org/forums/viewtopic.php?t=2363&p=15250#p15250Statistics: Posted by 23fx23 — 18 Aug 2010, 13:11
]]>2010-08-18T04:01:43+01:002010-08-18T04:01:43+01:00https://brainmodular.org/forums/viewtopic.php?t=2363&p=15246#p15246Statistics: Posted by gurulogic — 18 Aug 2010, 05:01
a wiki page..?:D
features:
