ArrayArrayArray BrainModular BrainModular Users Forum 2010-08-24T10:48:49+01:00 https://brainmodular.org/forums/app.php/feed/topic/2361 2010-08-24T10:48:49+01:00 2010-08-24T10:48:49+01:00 https://brainmodular.org/forums/viewtopic.php?t=2361&p=15308#p15308 <![CDATA[Rhombusine]]> I've correct the clear button who don't work and add a O button which open /close an option window to set the synchro and lenght of the note
Statistics: Posted by nay-seven — 24 Aug 2010, 11:48
2010-08-15T22:20:31+01:00 2010-08-15T22:20:31+01:00 https://brainmodular.org/forums/viewtopic.php?t=2361&p=15188#p15188 <![CDATA[Rhombusine]]> by default this reset also the value toon for the 2 rhombus and the forward direction for them too
Statistics: Posted by nay-seven — 15 Aug 2010, 23:20
2010-08-14T22:57:21+01:00 2010-08-14T22:57:21+01:00 https://brainmodular.org/forums/viewtopic.php?t=2361&p=15179#p15179 <![CDATA[Rhombusine]]>
so, here it is :
the Rhombusine ( for non English users , rhombus is the name of this form <> )
you'll need the last 1.2 matrix pack for this one
A minimal rhombus sequencer , with 2 sequences ( 19 and 27 steps ( i know ....not usual..) ) , 2 directions for each one , and a random function for the steps , central cell is the play button..
Here a little schematic of his minimals functions
if you want to use it with an other vsti , just delete the heliosII inside the patch and use a midi bus named vsti
This add-on is also a door to monome like patch , where some cells can be used as function and more...;-)
This addon has nothing new in the concept but i have always think that when we change our practices , it wake up our creativity..
Statistics: Posted by nay-seven — 14 Aug 2010, 23:57
so, here it is :
