btw I've test one button to 2 different load patch module , one who send , one who receive..no problems here apparently..? any other factor..?
Statistics: Posted by nay-seven — 20 Jul 2010, 16:54
]]>2010-07-20T15:06:21+01:002010-07-20T15:06:21+01:00https://brainmodular.org/forums/viewtopic.php?t=2310&p=14795#p14795For each bus name there's only one send and one receive, and of course they're set to global. The problem is I have to reload one or two of the patches to have them working together, without modifying anything in the patches... Sometimes I have to delete the receive module and recreate another with the same bus name... I was wondering if the order in which the send and the receive are created was important... Otherwise it just looks like a bug or my laptop is a wreck ! by the way I'm using version 5bet7
Statistics: Posted by oxyredox — 20 Jul 2010, 16:06
]]>2010-07-20T08:20:25+01:002010-07-20T08:20:25+01:00https://brainmodular.org/forums/viewtopic.php?t=2310&p=14784#p14784if you use global and have the same name for different buses , could have some conflict..?
Statistics: Posted by nay-seven — 20 Jul 2010, 09:20
]]>2010-07-19T23:18:40+01:002010-07-19T23:18:40+01:00https://brainmodular.org/forums/viewtopic.php?t=2310&p=14781#p14781I'd like to mention a problem I've encountered several times. I have several sets of two patches on different tracks that need to communicate through a MIDI bus. I use "patch loaders" contained in a third patch to load each pair. And most of the times, they don't communicate, so I have to reload each patch (the one that sends, and the one that receives) to make it works and get the MIDI flowing.
Is there a solution or an explanation (apart from making one patch instead of two...) ?
Statistics: Posted by oxyredox — 20 Jul 2010, 00:18
