2010-07-27T02:26:36+01:002010-07-27T02:26:36+01:00https://brainmodular.org/forums/viewtopic.php?t=2304&p=14903#p14903Now I figured out what it is the moon combo thing. Just load any Vst inside a track, then clic on the left mouse button over the inlet called *program* from the vst:
select the moon combo option. Then see for yourself
]]>2010-07-27T02:09:51+01:002010-07-27T02:09:51+01:00https://brainmodular.org/forums/viewtopic.php?t=2304&p=14902#p14902 Any other hidden gems you can point me at in the new version? I have to admit I haven't had any luck finding this either:
Statistics: Posted by Clearscreen — 27 Jul 2010, 03:09
]]>2010-07-26T08:13:53+01:002010-07-26T08:13:53+01:00https://brainmodular.org/forums/viewtopic.php?t=2304&p=14891#p14891 it's a template , not a module try a wire from a program inlet of a VST/VSTI....
Statistics: Posted by nay-seven — 26 Jul 2010, 09:13
Statistics: Posted by nay-seven — 23 Jul 2010, 23:47
]]>2010-07-22T01:23:32+01:002010-07-22T01:23:32+01:00https://brainmodular.org/forums/viewtopic.php?t=2304&p=14833#p14833Statistics: Posted by 23fx23 — 22 Jul 2010, 02:23
]]>2010-07-21T22:23:14+01:002010-07-21T22:23:14+01:00https://brainmodular.org/forums/viewtopic.php?t=2304&p=14830#p14830Statistics: Posted by senso — 21 Jul 2010, 23:23
]]>2010-07-21T19:43:08+01:002010-07-21T19:43:08+01:00https://brainmodular.org/forums/viewtopic.php?t=2304&p=14820#p14820 HSLColor and RGBColor are now array compatible
i have updated the wiki
Statistics: Posted by martignasse — 21 Jul 2010, 20:43
]]>2010-07-20T09:25:12+01:002010-07-20T09:25:12+01:00https://brainmodular.org/forums/viewtopic.php?t=2304&p=14790#p14790Statistics: Posted by soundmind — 20 Jul 2010, 10:25
]]>2010-07-20T08:54:15+01:002010-07-20T08:54:15+01:00https://brainmodular.org/forums/viewtopic.php?t=2304&p=14788#p14788I guess it's probably better to proceed with the tools I already have...
Statistics: Posted by gurulogic — 20 Jul 2010, 09:54
]]>2010-07-20T08:17:55+01:002010-07-20T08:17:55+01:00https://brainmodular.org/forums/viewtopic.php?t=2304&p=14783#p147831) master container: yes probably very soon. 2) XY for container: not easy to implement, but I have to take a deeper look.
For example you can put a preset in a sub-patch which stores data's of the parent patch.
Yes, this is very usefull. For example you can have a preset manager in a sub patch with preset isolate enabled and set the preset manager to control the parent patch. This way only the parent patch is affected by the preset manager.
Thanks for the new features!
(p.s., any chance in the near future that we will see a master container for all tracks and movable XY for container? Fingers crossed....)
Statistics: Posted by gurulogic — 19 Jul 2010, 19:49
the current patch (and all its sub-patches) the parent patch (and all its sub-patches) the top parent patch (and all its sub-patches)
It means that you can have more accuracy on what you want to store in your preset manager. For example you can put a preset in a sub-patch which stores data's of the parent patch.
For the Mouse message it's the same idea, you can send mouse messages in a container, control panel. it's very useful...
- new 'target' parameter in the preset module - new 'target' parameter in the send mouse message
I'm intrigued by this... what does it mean, more specifically?
Statistics: Posted by runagate — 19 Jul 2010, 17:44
]]>2010-07-19T13:34:00+01:002010-07-19T13:34:00+01:00https://brainmodular.org/forums/viewtopic.php?t=2304&p=14769#p14769Statistics: Posted by grego mondo — 19 Jul 2010, 14:34
]]>2010-07-19T01:39:49+01:002010-07-19T01:39:49+01:00https://brainmodular.org/forums/viewtopic.php?t=2304&p=14757#p14757
Statistics: Posted by Clearscreen — 19 Jul 2010, 02:39
]]>2010-07-18T21:41:57+01:002010-07-18T21:41:57+01:00https://brainmodular.org/forums/viewtopic.php?t=2304&p=14755#p14755 I download it to work with tomorow !
Thanks a lot
Statistics: Posted by multiphone — 18 Jul 2010, 22:41
Statistics: Posted by nay-seven — 18 Jul 2010, 16:51
]]>2010-07-18T15:29:17+01:002010-07-18T15:29:17+01:00https://brainmodular.org/forums/viewtopic.php?t=2304&p=14750#p14750Statistics: Posted by 23fx23 — 18 Jul 2010, 16:29
]]>2010-07-18T15:19:46+01:002010-07-18T15:19:46+01:00https://brainmodular.org/forums/viewtopic.php?t=2304&p=14749#p14749Statistics: Posted by 23fx23 — 18 Jul 2010, 16:19
]]>2010-07-18T15:15:55+01:002010-07-18T15:15:55+01:00https://brainmodular.org/forums/viewtopic.php?t=2304&p=14748#p14748 i really like the 'examples guided tour', hope it will convince some potential new users
will matrix comes apart Martin?
now the 5.20 is out, i'll update the matrix pack with the 1.2 version... i just have one or two details to see with senso before that happen.
Statistics: Posted by martignasse — 18 Jul 2010, 16:15
]]>2010-07-18T14:41:29+01:002010-07-18T14:41:29+01:00https://brainmodular.org/forums/viewtopic.php?t=2304&p=14747#p14747, re dl pro .. will matrix comes apart Martin?
]]>2010-07-18T13:42:08+01:002010-07-18T13:42:08+01:00https://brainmodular.org/forums/viewtopic.php?t=2304&p=14746#p14746Statistics: Posted by ethnix73 — 18 Jul 2010, 14:42
]]>BrainModularBrainModular Users Forum2010-07-27T02:51:01+01:00https://brainmodular.org/forums/app.php/feed/topic/23042010-07-27T02:51:01+01:002010-07-27T02:51:01+01:00https://brainmodular.org/forums/viewtopic.php?t=2304&p=14904#p14904Statistics: Posted by Clearscreen — 27 Jul 2010, 03:51
]]>2010-07-27T02:26:36+01:002010-07-27T02:26:36+01:00https://brainmodular.org/forums/viewtopic.php?t=2304&p=14903#p14903Now I figured out what it is the moon combo thing. Just load any Vst inside a track, then clic on the left mouse button over the inlet called *program* from the vst:
Thanks a lot
