ArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArray
BrainModularBrainModular Users Forum2010-07-30T07:13:35+01:00https://brainmodular.org/forums/app.php/feed/topic/22992010-07-30T07:13:35+01:002010-07-30T07:13:35+01:00https://brainmodular.org/forums/viewtopic.php?t=2299&p=14917#p14917Statistics: Posted by senso — 30 Jul 2010, 08:13
2010-07-29T20:16:18+01:002010-07-29T20:16:18+01:00https://brainmodular.org/forums/viewtopic.php?t=2299&p=14915#p14915Would this make sense as a solution for the above situation?
Statistics: Posted by gurulogic — 29 Jul 2010, 21:16
]]>2010-07-26T08:16:46+01:002010-07-26T08:16:46+01:00https://brainmodular.org/forums/viewtopic.php?t=2299&p=14892#p14892Cause wasn't really easy to help without the plugin ! and yeah, have a good gig oxyredox !
Statistics: Posted by nay-seven — 26 Jul 2010, 09:16
Statistics: Posted by Clearscreen — 26 Jul 2010, 05:22
]]>2010-07-26T02:39:30+01:002010-07-26T02:39:30+01:00https://brainmodular.org/forums/viewtopic.php?t=2299&p=14888#p14888I dig the idea of a multi of bank, one channel per bank and one program change message per channel... Thank you clearscreen. of course the "load patch" worked for me as well (actually that's how I've been doing so far) but I don't like the idea of reloading a plug that's already loaded... anyway that's what I'll do for the gig tomorrow
My account has just been updated so I'll try the latest version and maybe my problem with preset manager via bus will be solved.
Statistics: Posted by oxyredox — 26 Jul 2010, 03:39
But you can build a multi of banks - ie your multi can consist of several banks, each of which respond to midi program changes. So in slot one of each bank you put each instrument you want in the multi for program change 1, in slot 2 of each bank you setup the instruments you want for program change 2, etc... works pretty well, but it'd be better to just be able to switch multi's vi program change really. I'll keep checking this out as it seems there should be a way for this to work in Kontakt.
I'm not sure this helps you, but I thought it was worth a mention just in case...
Statistics: Posted by Clearscreen — 26 Jul 2010, 03:04
]]>2010-07-26T01:30:42+01:002010-07-26T01:30:42+01:00https://brainmodular.org/forums/viewtopic.php?t=2299&p=14886#p14886 I also just tried out the "load patch" module with kontakt, and it works a treat... you can have as many multi's as you like and you can tell Usine where to load it (track/line), very cool!
Statistics: Posted by Clearscreen — 26 Jul 2010, 02:30
]]>2010-07-24T22:12:21+01:002010-07-24T22:12:21+01:00https://brainmodular.org/forums/viewtopic.php?t=2299&p=14870#p14870i suppose only senso can answer this.. and i 'm afraid the new version don't change anything about this..
Statistics: Posted by nay-seven — 24 Jul 2010, 23:12
]]>2010-07-24T19:03:55+01:002010-07-24T19:03:55+01:00https://brainmodular.org/forums/viewtopic.php?t=2299&p=14869#p14869-You can't build a bank with multis, -Kontakt doesn't allow me to build an .fxb file (just does'nt work I don't know why) -preset manager stops working when receiving instructions from a bus (whereas the same patching works with pianoteq or guitar rig)
--> I need to load an .fxp file directly
Is there a way to achieve that automatically ? I don't think there is any module for that, Hence my question about Internal Message Language..
Anyway I'll download version 5.20 as soon as my upgrade licence purchase will be registered. I hope as soon as possible, and maybe all my problems will be solved !
Statistics: Posted by oxyredox — 24 Jul 2010, 20:03
]]>2010-07-24T17:12:03+01:002010-07-24T17:12:03+01:00https://brainmodular.org/forums/viewtopic.php?t=2299&p=14868#p14868 but..i don't know if it's possible with kontakt and the demo version will certainly not let me save preset and so... that's why you first need to learn via native or others forum how to built a bank of multi and if it's possible..?
and I'm not even sure this will change the things for you in the way that kontakt have to load the samples anyway to built the multi..? don't know...
Statistics: Posted by nay-seven — 24 Jul 2010, 18:12
]]>2010-07-24T16:10:15+01:002010-07-24T16:10:15+01:00https://brainmodular.org/forums/viewtopic.php?t=2299&p=14867#p14867 BUT when I say real preset files, I'm talking about .fxp, created by Usine when you go to the menu item "File/Save preset" in the plug window. This menu does'nt belong to Kontakt but to Usine, so I thought there might be a way to tell Usine to load a .fxp file into the plugin, just like I do when I go to "File/Load preset". Maybe Internal Message Language is the key ?
Statistics: Posted by oxyredox — 24 Jul 2010, 17:10
Statistics: Posted by nay-seven — 24 Jul 2010, 16:24
]]>2010-07-24T15:14:59+01:002010-07-24T15:14:59+01:00https://brainmodular.org/forums/viewtopic.php?t=2299&p=14865#p14865I've saw that for Kontakt, at least for some version, there's .nki=single instrument .nkm = multi
i've download and read the manual vor version 4 ( btw which version do you use..?.) but they always talk about the browser and mouse operation, never use midi , except about the classic learn with knobs...
do you know if there's bank in the demo of 4..? i 'm ok to download it to test but is seems that the program stop each 20mn ...
Statistics: Posted by nay-seven — 24 Jul 2010, 16:14
]]>2010-07-24T12:53:02+01:002010-07-24T12:53:02+01:00https://brainmodular.org/forums/viewtopic.php?t=2299&p=14864#p14864But is there a way to tell usine to load a REAL preset FILE, one created when saving a preset in the menu of the plug window ? like some command lines ? That would be the best solution isn't it ?
Statistics: Posted by oxyredox — 24 Jul 2010, 13:53
]]>2010-07-20T15:51:40+01:002010-07-20T15:51:40+01:00https://brainmodular.org/forums/viewtopic.php?t=2299&p=14798#p14798about the preset manager , i suppose the architecture of kontakt is not " classic "..?
Statistics: Posted by nay-seven — 20 Jul 2010, 16:51
]]>2010-07-20T15:12:43+01:002010-07-20T15:12:43+01:00https://brainmodular.org/forums/viewtopic.php?t=2299&p=14796#p14796as far as I know, the problem is that bank can only contain "sounds" and no "multi", so it's gonna be a lot of work...
By the way, any idea why the preset manager won't work with Kontakt ?
Statistics: Posted by oxyredox — 20 Jul 2010, 16:12
yes..program change only work with a bank with several preset inside.. I've find this post about it ( not the same host but must be a start : here
Statistics: Posted by nay-seven — 20 Jul 2010, 09:16
]]>2010-07-19T23:12:06+01:002010-07-19T23:12:06+01:00https://brainmodular.org/forums/viewtopic.php?t=2299&p=14780#p14780thanks for your many answers, So I have as many answers to make !
first the fx23fx suggestion. I tried the preset manager and it works very fine with pianoteq and guitar rig. I load my sound, store a preset in the "preset manager" and when all the presets are stored I save the patch. But for a very strange reason I could not find out, it doesn't work with Kontakt...
Clearscreen. I thinks it's a good idea, 16 midi channels will do the the job for the set I'm building, but I would really like to be able to change programs in Kontakt. The time loss I was talking about is during the loading of the plugin itself rather than during the loading of the samples.
Nay seven & clearscreen. I've tried exactly what you describe, using a "create midi" module to send program change but it did'nt work. And a good reason for that is that there is no "sound"-"program number" table anywhere. I cannot think of a way to tell kontakt what program number is affected to what "multi instrument" (this how they call a set of several sounds). I would love to know how to do do it. Maybe I have to create a bank ?
by the way what is an "OP" ?
Statistics: Posted by oxyredox — 20 Jul 2010, 00:12
]]>2010-07-16T05:20:11+01:002010-07-16T05:20:11+01:00https://brainmodular.org/forums/viewtopic.php?t=2299&p=14723#p14723Statistics: Posted by Clearscreen — 16 Jul 2010, 06:20
]]>2010-07-15T08:49:49+01:002010-07-15T08:49:49+01:00https://brainmodular.org/forums/viewtopic.php?t=2299&p=14712#p14712
You're talking of the presets one can create using the menu in the window that embeds the plugins GUI, (File/Save preset...).
right ( but your plugins has ,maybe also , his own way to save program/bank..)
Then I put a "create midi" box in the patch and I connect it to the "program" input of the plug, is that correct ?
no, not the program inlet but the midi one, something like this: i don' t have kontakt or guitar rig myself , but i suppose that such a plugin accept program change message
Statistics: Posted by nay-seven — 15 Jul 2010, 09:49
]]>2010-07-15T02:38:07+01:002010-07-15T02:38:07+01:00https://brainmodular.org/forums/viewtopic.php?t=2299&p=14711#p14711 For Guitar Rig could you use the conductor with markers to set up different patches and jump/loop to each marker as neccessary? Is there a better way to switch patches vertically in the grid? I've thought about this before - maybe I'd better look in to it...
Statistics: Posted by Clearscreen — 15 Jul 2010, 03:38
]]>2010-07-15T00:59:38+01:002010-07-15T00:59:38+01:00https://brainmodular.org/forums/viewtopic.php?t=2299&p=14710#p14710 I'll try the preset manager Nay seven I'm interested in your fashion because it seems so close to what I think would be the way, but I'm not sure i got it right... You're talking of the presets one can create using the menu in the window that embeds the plugins GUI, (File/Save preset...). The I put a "create midi" box in the patch and I connect it to the "program" input of the plug, is that correct ? And how do I link a number (in the MIDI program change message) to the correct string (the name of the file) ? Are those files sorted alphabetically and then they become "program 1", "program 2", "program 3", "program 4"... ?
Statistics: Posted by oxyredox — 15 Jul 2010, 01:59
]]>2010-07-14T17:16:50+01:002010-07-14T17:16:50+01:00https://brainmodular.org/forums/viewtopic.php?t=2299&p=14707#p14707create midi module to recall this ( program change ) ones....?
Statistics: Posted by nay-seven — 14 Jul 2010, 18:16
]]>2010-07-14T17:02:05+01:002010-07-14T17:02:05+01:00https://brainmodular.org/forums/viewtopic.php?t=2299&p=14706#p14706 ie you drop a preset manager in your vst patch, tweak the vst, save on 0, then tweak it, save on 1, ect, it should recall when cliquing nb on the preset manager.
]]>BrainModularBrainModular Users Forum2010-07-30T07:13:35+01:00https://brainmodular.org/forums/app.php/feed/topic/22992010-07-30T07:13:35+01:002010-07-30T07:13:35+01:00https://brainmodular.org/forums/viewtopic.php?t=2299&p=14917#p14917Statistics: Posted by senso — 30 Jul 2010, 08:13
]]>2010-07-29T20:16:18+01:002010-07-29T20:16:18+01:00https://brainmodular.org/forums/viewtopic.php?t=2299&p=14915#p14915Would this make sense as a solution for the above situation?
