ArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArray
BrainModularBrainModular Users Forum2012-01-11T07:53:52+01:00https://brainmodular.org/forums/app.php/feed/topic/22312012-01-11T07:53:52+01:002012-01-11T07:53:52+01:00https://brainmodular.org/forums/viewtopic.php?t=2231&p=22310#p22310i've test on a fresh install and it works
so,2 way here :
Create a dir wherever you want and give the path in the global setup/interface/patch library ( this solution is better to manage Usine updates) and you'll see the contents in the library tab of the browser. extract all the zip here
Or extract all the zip to the Usine library, something like D:Usine Pro StandAlone 5.70 035Usine LibrarySynthesis Pack v2.0 by Nay-Seven
you must see something like this :
Statistics: Posted by nay-seven — 11 Jan 2012, 07:53
]]>2012-01-11T05:10:24+01:002012-01-11T05:10:24+01:00https://brainmodular.org/forums/viewtopic.php?t=2231&p=22309#p22309Statistics: Posted by Asensory — 11 Jan 2012, 05:10
2011-08-14T21:07:26+01:002011-08-14T21:07:26+01:00https://brainmodular.org/forums/viewtopic.php?t=2231&p=20711#p20711im sooo glad i decided to get usine,and when i get my touchscreen overlay for my ekstra 22 inch lcd monitor it will be awesome
Statistics: Posted by nay-seven — 15 Mar 2011, 09:01
]]>2011-03-15T06:55:58+01:002011-03-15T06:55:58+01:00https://brainmodular.org/forums/viewtopic.php?t=2231&p=18644#p18644Statistics: Posted by joffo78 — 15 Mar 2011, 06:55
]]>2011-01-16T20:35:03+01:002011-01-16T20:35:03+01:00https://brainmodular.org/forums/viewtopic.php?t=2231&p=17761#p17761Statistics: Posted by nay-seven — 16 Jan 2011, 20:35
]]>2011-01-16T19:28:37+01:002011-01-16T19:28:37+01:00https://brainmodular.org/forums/viewtopic.php?t=2231&p=17759#p17759 Basic issue is that the VSTs in the pack are not scanned by Usine. They just need to be put wherever convenient & scanned (Usine Demo folder already contains some VSTs that I guess are useful, so I just dumped everything there and it works fine).
I think it just needs an additional line in the installation manual "copy the content of the DLL folder in your Usine VST folder (default is demo/VST)" , nothing more.
Statistics: Posted by Document02 — 16 Jan 2011, 19:28
]]>2011-01-16T18:53:35+01:002011-01-16T18:53:35+01:00https://brainmodular.org/forums/viewtopic.php?t=2231&p=17758#p17758install a fresh version of Usine, create a new folder "my library" outside Usine folder /put all the pack inside works fine...?
Statistics: Posted by nay-seven — 16 Jan 2011, 18:53
]]>2011-01-16T18:31:28+01:002011-01-16T18:31:28+01:00https://brainmodular.org/forums/viewtopic.php?t=2231&p=17757#p17757Statistics: Posted by nay-seven — 16 Jan 2011, 18:31
]]>2011-01-16T17:51:21+01:002011-01-16T17:51:21+01:00https://brainmodular.org/forums/viewtopic.php?t=2231&p=17752#p17752
[center]"Can't find the VST D:vst_UsineSynthesis Pack VST_V0.9Oscillator (Mono).dll"[/center] and then [center]"Can't find the VST D:vst_Usine__SYNTHESOSC3.dll".[/center]
Actually ran into the same problem on the newest version of Usine & synth pack (downloaded a couple of day ago). Finally solved it by moving all DLLs in Usine's filesdemovst folder. This is not a big issue, but should be addressed in the installation manual.
Statistics: Posted by Document02 — 16 Jan 2011, 17:51
]]>2010-10-29T13:45:12+01:002010-10-29T13:45:12+01:00https://brainmodular.org/forums/viewtopic.php?t=2231&p=16671#p16671With the 5.25i version, the Synthesis pack works fine.
Statistics: Posted by Gilles.D — 29 Oct 2010, 14:45
]]>2010-10-26T17:12:16+01:002010-10-26T17:12:16+01:00https://brainmodular.org/forums/viewtopic.php?t=2231&p=16609#p16609excuse me don't want to annoy you thanx
Statistics: Posted by waolelaid — 26 Oct 2010, 18:12
]]>2010-10-26T15:48:33+01:002010-10-26T15:48:33+01:00https://brainmodular.org/forums/viewtopic.php?t=2231&p=16600#p16600there's no "new " pack i don't have upload it yet.. if you 're looking for the old version , they 're always at the same place : http://www.sensomusic.com/download/
Statistics: Posted by nay-seven — 26 Oct 2010, 16:48
]]>2010-10-26T15:21:24+01:002010-10-26T15:21:24+01:00https://brainmodular.org/forums/viewtopic.php?t=2231&p=16598#p16598excuse me but i'm a bit destabilized my new config is dead in fact it's the motherboard so i'm annoyed but fortunately it's still under warranty but i don't understand why it happens it has only six months i'm disgusting all i touch goes wrong good evening in later :/
Statistics: Posted by waolelaid — 26 Oct 2010, 16:21
]]>2010-10-26T11:19:56+01:002010-10-26T11:19:56+01:00https://brainmodular.org/forums/viewtopic.php?t=2231&p=16593#p16593i suppose it's a version problem, cant remember right now but in old version you have to put the dll files in your vst dir so 2 solutions : if you want keep your old version put all dll in your vst/vsti dir or better : upgrade to latest version ,and just unpack the zip in you library , must work
btw glad you enjoy this pack, i've some upgrade to do soon , for the additive and spectra one..
about French , here it's the official forum and 80% of our users aren't French...but if needed , you can also use audiaufanzine french forum
one precision : it's not in Usine/files/usine library but in your library ( if you don't have create one yet you can also use Usine/files/demo dir for example) but could be any dir outside Usine ( better to manage updates ) just enter the path in the global setup/interface i 'm gone to be more precise in the how to install .txt, sorry
Statistics: Posted by nay-seven — 26 Oct 2010, 12:19
]]>2010-10-26T11:00:00+01:002010-10-26T11:00:00+01:00https://brainmodular.org/forums/viewtopic.php?t=2231&p=16592#p16592 But I have an issue installing the synthesis pack. I extracted the archive in my "Usine5.17FilesUsine Library" folder. When I first loaded the OSC patch, Usine told me [center]"Can't find the VST D:vst_UsineSynthesis Pack VST_V0.9Oscillator (Mono).dll"[/center] and then [center]"Can't find the VST D:vst_Usine__SYNTHESOSC3.dll".[/center] I found these files were in the subfolder [center]"C:Program FilesUsine5.17FilesUsine LibrarySynthesis Pack v1.0 by Nay-SevenDLL".[/center] I manually created the required folders on my D: drive, moved the files, rebooted Usine, reloaded the OSC patch, and it works fine. But when I load the FX_reverb patch, Usine looks for "S:VstPluginsSynthesis Pack VST_V0.8bFDN_Reverb.dll". As I haven't any S: drive, I cannot create that folder and move the right .DLL inside it... In conclusion, for all the patches contained in the synthesis pack, Usine seems to look for the .DLLs where they aren't meant to be.
Is my situation unique ? Is this a common bug ? Does anyone have any solution ? I have (not thoroughly) searched the Sensomusic and Nay Seven websites and found no information about that issue.
My configuration is : Windows XP Pro SP3 Usine 5.17 Free, stand alone, installed in C:program files Syntyhesis Pack 1.0 Matrix Pack 1.1 Old Dell Inspiron laptop. Pentium 3 (?) 1,4 GHz, 512 Mo RAM
Thanks again for making Usine and its additionnal packs and add-ons !!
Gilles. PS : ça ne me gênera pas si vous répondez en français.
Statistics: Posted by Gilles.D — 26 Oct 2010, 12:00
]]>2010-06-07T07:03:55+01:002010-06-07T07:03:55+01:00https://brainmodular.org/forums/viewtopic.php?t=2231&p=14156#p14156Statistics: Posted by nay-seven — 07 Jun 2010, 08:03
]]>2010-06-07T00:51:48+01:002010-06-07T00:51:48+01:00https://brainmodular.org/forums/viewtopic.php?t=2231&p=14151#p14151Statistics: Posted by Clearscreen — 07 Jun 2010, 01:51
]]>2010-06-06T17:00:24+01:002010-06-06T17:00:24+01:00https://brainmodular.org/forums/viewtopic.php?t=2231&p=14150#p14150 i love the look!
]]>2010-06-06T16:53:01+01:002010-06-06T16:53:01+01:00https://brainmodular.org/forums/viewtopic.php?t=2231&p=14149#p14149 Very nice and useful job.
Best
Statistics: Posted by multiphone — 06 Jun 2010, 17:53
]]>2010-06-03T14:20:58+01:002010-06-03T14:20:58+01:00https://brainmodular.org/forums/viewtopic.php?t=2231&p=14114#p14114Statistics: Posted by bsork — 03 Jun 2010, 15:20
]]>2010-06-03T14:02:11+01:002010-06-03T14:02:11+01:00https://brainmodular.org/forums/viewtopic.php?t=2231&p=14111#p14111Synthesis pack has been updated to 1.0[/center]
updates : 2 new Oscillator patches+ 1 big synthesizer patch :
OSC 3 :simple oscillator with 7 waveforms (sine, sawtooth, ramp, triangle, pulse, white noise, pink noise) and resonance parameter
OSC_Spectax32 :Spectral Oscillator with access to 32 harmonics
SYN_SYNTHAYAN patch example of synthesizer using this 2 new Oscillator ( don't except a classic one.. )
2 Oscillators: 4 modulation sources : 2 LFO, lines and sequencer route by a matrix 2 Effects : delay and Filter
Installation : Extract all the archive in your Usine /Files / Usine Library ( or better your "my library " folder )
Statistics: Posted by nay-seven — 03 Jun 2010, 15:02
]]>BrainModularBrainModular Users Forum2012-01-11T07:53:52+01:00https://brainmodular.org/forums/app.php/feed/topic/22312012-01-11T07:53:52+01:002012-01-11T07:53:52+01:00https://brainmodular.org/forums/viewtopic.php?t=2231&p=22310#p22310i've test on a fresh install and it works
so,2 way here :
]]>2011-08-14T21:07:26+01:002011-08-14T21:07:26+01:00https://brainmodular.org/forums/viewtopic.php?t=2231&p=20711#p20711im sooo glad i decided to get usine,and when i get my touchscreen overlay for my ekstra 22 inch lcd monitor it will be awesome
Best
