]]>2011-02-23T22:40:07+01:002011-02-23T22:40:07+01:00https://brainmodular.org/forums/viewtopic.php?t=2221&p=18150#p18150Statistics: Posted by moody33 — 23 Feb 2011, 22:40
2010-05-27T12:59:07+01:002010-05-27T12:59:07+01:00https://brainmodular.org/forums/viewtopic.php?t=2221&p=14027#p14027Statistics: Posted by ethnix73 — 27 May 2010, 13:59
]]>2010-05-27T09:59:50+01:002010-05-27T09:59:50+01:00https://brainmodular.org/forums/viewtopic.php?t=2221&p=14024#p14024thanks for this explanation !
Statistics: Posted by nay-seven — 27 May 2010, 10:59
]]>2010-05-27T09:40:33+01:002010-05-27T09:40:33+01:00https://brainmodular.org/forums/viewtopic.php?t=2221&p=14023#p14023 I'm still working on my FC300 SysEx patch which will need similar coding, so as it's not often that I program this kind of stuff I created a separate script to make debugging easier for myself. I made the Array Compare script first even though I actually don't need anything like it at the moment just because it's a simpler but similar program, and because I thought that as some other users do array trickery to handle strings and this kind of function is found in practically every standard programming library, it could be handy for them.
Also - if I've understood things correctly - some of the OSC patches created by others (I've only had a short test with OSC a long time ago myself) might benefit from something like this.
]]>2010-05-27T08:47:25+01:002010-05-27T08:47:25+01:00https://brainmodular.org/forums/viewtopic.php?t=2221&p=14021#p14021btw, any example of applications..?
Statistics: Posted by nay-seven — 27 May 2010, 09:47
]]>2010-05-27T03:38:26+01:002010-05-27T03:38:26+01:00https://brainmodular.org/forums/viewtopic.php?t=2221&p=14016#p14016Statistics: Posted by 23fx23 — 27 May 2010, 04:38
]]>2010-05-26T23:48:05+01:002010-05-26T23:48:05+01:00https://brainmodular.org/forums/viewtopic.php?t=2221&p=14014#p14014 -Array Compare -Array Find
You find them in the Data Tools section, or download from here:
]]>2010-05-27T12:59:07+01:002010-05-27T12:59:07+01:00https://brainmodular.org/forums/viewtopic.php?t=2221&p=14027#p14027Statistics: Posted by ethnix73 — 27 May 2010, 13:59
