ArrayArrayArray BrainModular BrainModular Users Forum 2010-05-21T18:07:16+01:00 https://brainmodular.org/forums/app.php/feed/topic/2218 2010-05-21T18:07:16+01:00 2010-05-21T18:07:16+01:00 https://brainmodular.org/forums/viewtopic.php?t=2218&p=13977#p13977 <![CDATA[live mode disappeared]]>
You're to rapid to answer. In fact it works, and it's realy powerfull to.
Bye
Statistics: Posted by SylvainT — 21 May 2010, 19:07
2010-05-21T16:19:35+01:00 2010-05-21T16:19:35+01:00 https://brainmodular.org/forums/viewtopic.php?t=2218&p=13975#p13975 <![CDATA[live mode disappeared]]> first check your patch is set as visible in IB
then right click in IB mode /edit layout and set the re-organize to maximize if on
et hop live mode is here again !
Statistics: Posted by nay-seven — 21 May 2010, 17:19
2010-05-21T15:58:18+01:00 2010-05-21T15:58:18+01:00 https://brainmodular.org/forums/viewtopic.php?t=2218&p=13974#p13974 <![CDATA[live mode disappeared]]>
So, I wait a long time to try the V5, it looks so great and more and more powerfull.
I take time because it was not so easy to upgrade the last projects on V5.
But now I try to.
But I have a big problem, and nobody looks to have such problem on the forum.
Does anybody used the live mode?
I was using it a lot, the grid mode was for patches used all allong the wkp, the sequencer then sequenced the different patches and I was controling the patches with the live mode. Very, very powerfull. I could make a big wkp for all the session, but everything was very clear.
And now, the live mode disappeared. I can understand why, with the new presentation of Usine 5, you can organize your patches in the IB window very efficiently. But using it with the sequencer, I can't find the way to recreate the live mode, with the patches appear and disappear automatically with the sequence. Sequencer + conductor + live mode was for me one of the most powerfull thing of Usine, and I can't live without that!!!!!
Or I missed something?
It looks impossible.
Does anyboby have an idea?
Regards
Statistics: Posted by SylvainT — 21 May 2010, 16:58
Bye
But now I try to.
Regards
