(I have toyed with the idea of a program running through the files to increase/decrease the size of UI objects by X%. Maybe as a way of getting into C++. Haven't done anything concrete with the idea, though...)
]]>2010-05-10T17:15:26+01:002010-05-10T17:15:26+01:00https://brainmodular.org/forums/viewtopic.php?t=2188&p=13881#p13881 the first 4 digits of the 16 digit code for an object refers to its type.
Maybe somebody has a list?
Good for turning data outs to sends, etc.
Haven't figured out what the other 12 digits are for, but I'm guessing some of them refer to position.
Statistics: Posted by woodslanding — 10 May 2010, 18:15
]]>2010-05-10T16:13:09+01:002010-05-10T16:13:09+01:00https://brainmodular.org/forums/viewtopic.php?t=2188&p=13880#p13880Not all data can be modified with notepad in a workspace or patch. some are binary or Hexa coded (like presets contents...) and some are just ascii coded (so it's readable and editable).
Just a proposal : Until the day we can have a format specification of the .wkp and .pat file, it could be good to create a trick and tips page on the wiki for notepad manipulation, with what is working and what is impossible to do.
Statistics: Posted by martignasse — 10 May 2010, 17:13
]]>2010-05-10T05:33:45+01:002010-05-10T05:33:45+01:00https://brainmodular.org/forums/viewtopic.php?t=2188&p=13874#p13874Statistics: Posted by woodslanding — 10 May 2010, 06:33
2010-05-09T18:37:48+01:002010-05-09T18:37:48+01:00https://brainmodular.org/forums/viewtopic.php?t=2188&p=13872#p13872Statistics: Posted by 23fx23 — 09 May 2010, 19:37
]]>2010-05-09T05:13:18+01:002010-05-09T05:13:18+01:00https://brainmodular.org/forums/viewtopic.php?t=2188&p=13863#p13863 oh wait--I'm trying to change a bunch of data ins and sends to audio ones (from before there was a difference!) Names are easy to edit, but it seems very hard to figure out and edit the TYPE of object--it looks like it is stored as a 16 digit number, but the same objects have different numbers, so there is obviously other info stored that way.
Any tips?
And to make this into a request
It would be nice to (someday) implement an XML or similar dataformat that would make it possible to build/edit wkps from a text or XML editor.
Thanks!! -eric
Statistics: Posted by woodslanding — 09 May 2010, 06:13
]]>2010-05-05T15:13:48+01:002010-05-05T15:13:48+01:00https://brainmodular.org/forums/viewtopic.php?t=2188&p=13784#p13784note pad is a good alternative in this case.
]]>2010-05-05T02:16:47+01:002010-05-05T02:16:47+01:00https://brainmodular.org/forums/viewtopic.php?t=2188&p=13776#p13776Statistics: Posted by 23fx23 — 05 May 2010, 03:16
]]>2010-05-05T00:23:51+01:002010-05-05T00:23:51+01:00https://brainmodular.org/forums/viewtopic.php?t=2188&p=13775#p13775 It is in a human readable format, right??
Statistics: Posted by woodslanding — 05 May 2010, 01:23
]]>2010-05-03T21:48:28+01:002010-05-03T21:48:28+01:00https://brainmodular.org/forums/viewtopic.php?t=2188&p=13752#p13752 i figure i wrongly named my busses from start, i got a scrollYneg wich is in fact positive and a scrollY positive. (totally my fault and not drastic,), as i could go and rename all busses manually I would be afraid to make mistakes, thought one handy function could be to choose a buss name in a list, and rename all receive buss same named, a bit like "search and replace" of notepad, (wich also could be handy on script, by the way)... just in case not vital at all..
]]>2010-05-09T18:37:48+01:002010-05-09T18:37:48+01:00https://brainmodular.org/forums/viewtopic.php?t=2188&p=13872#p13872Statistics: Posted by 23fx23 — 09 May 2010, 19:37
Any tips?
Thanks!! -eric
