ArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArray
BrainModularBrainModular Users Forum2010-04-29T09:46:57+01:00https://brainmodular.org/forums/app.php/feed/topic/21762010-04-29T09:46:57+01:002010-04-29T09:46:57+01:00https://brainmodular.org/forums/viewtopic.php?t=2176&p=13698#p13698I relied on stereo vu meters out and that's stupid because the signals add. So -6dB when centered were ok (0dB when added) and your first solutions were good. The only issue that seems to remain for panner 1-2 is it boosts the signal of 6dB ?
I've modified my curve panner to make it work too, here it is, but it's now just another approach... Your explanation Gurulogic made me doubt about my patch and that was a really good thing !
Statistics: Posted by La Tenaille — 29 Apr 2010, 10:46
]]>2010-04-28T20:25:40+01:002010-04-28T20:25:40+01:00https://brainmodular.org/forums/viewtopic.php?t=2176&p=13688#p13688 I'm currently working on multiple delays with spatialization, and loosing gain when panning a delay distort the spatial image in that precise case.
Statistics: Posted by La Tenaille — 28 Apr 2010, 21:25
Gurulogic, I've tried your panner and same result : -6dB when centered if I tune the gain to have 0dB on 100% pans.
Hmm, yes. my patch seems to be losing -6db somewhere before the volume controller, but as I can tell it's is equal "perceived" gain through the entire pan width, which is what my goal was. If I increase the volume module +6db and then pan slowly from one side to the other, the output gain is equal to the input gain and to my ears, I hear an even volume all throughough the entire pan. I f I pan quick, my ears play tricks on me and I hear quiet spots at half pan but I think that has something to do with the way I blend one side of a stereo channel into the other when panning. But maybe I still need to do some tweaks, and perhaps even rebuild around your much simpler looking solution
Anyways, I am glad you have it working to your liking
Statistics: Posted by gurulogic — 28 Apr 2010, 20:20
]]>2010-04-28T16:29:26+01:002010-04-28T16:29:26+01:00https://brainmodular.org/forums/viewtopic.php?t=2176&p=13684#p13684 For real time panning the smoother avoids crackles, but I've noticed it costs CPU.
Statistics: Posted by La Tenaille — 28 Apr 2010, 17:29
]]>2010-04-28T15:57:00+01:002010-04-28T15:57:00+01:00https://brainmodular.org/forums/viewtopic.php?t=2176&p=13680#p13680well done la tenaille ! can i add this patch to the next Utils pack..?
Statistics: Posted by nay-seven — 28 Apr 2010, 16:57
Statistics: Posted by La Tenaille — 28 Apr 2010, 15:35
]]>2010-04-28T13:57:49+01:002010-04-28T13:57:49+01:00https://brainmodular.org/forums/viewtopic.php?t=2176&p=13674#p13674Statistics: Posted by 23fx23 — 28 Apr 2010, 14:57
2010-04-28T13:02:17+01:002010-04-28T13:02:17+01:00https://brainmodular.org/forums/viewtopic.php?t=2176&p=13672#p13672I've tried the crossfader but the trouble is nearly the same (the -6dB happens on centered position). Gurulogic, I've tried your panner and same result : -6dB when centered if I tune the gain to have 0dB on 100% pans.
... so I've tried to analyse the "panner 1-2" patch and found a partial solution :
I've added the selected modules, where b=4 and fader ranger 0>2. The fader range truncate the numbers above 2 when the panner crosses the center position. It works but the sound position isn't regular : it changes a few near 0 and a lot near 100...
I imagine a good curve would fix that but I don't have any idea of how to create the right curve...
Statistics: Posted by La Tenaille — 28 Apr 2010, 14:02
In stereo mode, each LR channel is brought to the other side and gain compensated -6db during panning, in mono mode, either or both inputs can be used and when panned is gain compensated -3db Also there is a unified gain fader that works in conjunction with the pan gain compensation..
Statistics: Posted by gurulogic — 27 Apr 2010, 23:19
]]>2010-04-27T21:56:14+01:002010-04-27T21:56:14+01:00https://brainmodular.org/forums/viewtopic.php?t=2176&p=13647#p13647 alternate solution, use a cross fade module this way..?:
Statistics: Posted by nay-seven — 27 Apr 2010, 22:56
]]>2010-04-27T20:47:39+01:002010-04-27T20:47:39+01:00https://brainmodular.org/forums/viewtopic.php?t=2176&p=13642#p13642I'm using the "panner 1-2" patch and I've noticed a +6dB difference between in and out volume when panning a signal 100% left or right. Is it a known issue ? Any way to fix that ? Thanks
Statistics: Posted by La Tenaille — 27 Apr 2010, 21:47
]]>BrainModularBrainModular Users Forum2010-04-29T09:46:57+01:00https://brainmodular.org/forums/app.php/feed/topic/21762010-04-29T09:46:57+01:002010-04-29T09:46:57+01:00https://brainmodular.org/forums/viewtopic.php?t=2176&p=13698#p13698I relied on stereo vu meters out and that's stupid because the signals add. So -6dB when centered were ok (0dB when added) and your first solutions were good. The only issue that seems to remain for panner 1-2 is it boosts the signal of 6dB ?
]]>2010-04-28T13:02:17+01:002010-04-28T13:02:17+01:00https://brainmodular.org/forums/viewtopic.php?t=2176&p=13672#p13672I've tried the crossfader but the trouble is nearly the same (the -6dB happens on centered position). Gurulogic, I've tried your panner and same result : -6dB when centered if I tune the gain to have 0dB on 100% pans.
