2010-04-25T11:35:04+01:002010-04-25T11:35:04+01:00https://brainmodular.org/forums/viewtopic.php?t=2170&p=13621#p13621I like the 'no-quantized' idea
]]>2010-04-24T08:49:17+01:002010-04-24T08:49:17+01:00https://brainmodular.org/forums/viewtopic.php?t=2170&p=13605#p13605Statistics: Posted by nay-seven — 24 Apr 2010, 09:49
]]>2010-04-24T04:45:26+01:002010-04-24T04:45:26+01:00https://brainmodular.org/forums/viewtopic.php?t=2170&p=13604#p13604 It generates triggers for midi notes and note offs when the playhead panel and the ball panel intersect X coordinates. Ball 1 is note on, ball 2 is note off, so to set the length of the note, move ball 1 and two apart. The coloured squares add or remove possible steps. It doesn't really always work as expected, I guess that's fun? Make sure you hit a preset 0-3 when you load the patch because for some reason the saved state is not recalling properly.
no wiki entry for this afternoons experiment...I probably won't refine this but maybe it can give some ideas?
(edit: Addon removed. Too broken for general use...will fix!)
-coloured squares each enable one of up to six steps per row -ball 1 is note on, ball 2 is note off -hight of ball above step grid determines note velocity -up to eight pages of separate values for ball (note) active, ball location, velocity, octave and step value -flatten seq when pressed will record all pages to the current ball (note) values as the page passes -flatten step does the same for step values -freeze allows focus on one page for editing, step position is not upset -resynch pages sets all pages in sequence to page 1 -everything else should be self explanitory....
Saving and recalling is not working reliably, possibly due to an incomplete script, so do not hope to recover any creations! Best bet is to store in a preset and then save a copy of the patch....
Statistics: Posted by gurulogic — 24 Apr 2010, 05:45
]]>BrainModularBrainModular Users Forum2010-04-25T20:39:52+01:00https://brainmodular.org/forums/app.php/feed/topic/21702010-04-25T20:39:52+01:002010-04-25T20:39:52+01:00https://brainmodular.org/forums/viewtopic.php?t=2170&p=13622#p13622Statistics: Posted by gurulogic — 25 Apr 2010, 21:39
]]>2010-04-25T11:35:04+01:002010-04-25T11:35:04+01:00https://brainmodular.org/forums/viewtopic.php?t=2170&p=13621#p13621I like the 'no-quantized' idea
