ArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2010-05-02T18:28:18+01:00 https://brainmodular.org/forums/app.php/feed/topic/2162 2010-05-02T18:28:18+01:00 2010-05-02T18:28:18+01:00 https://brainmodular.org/forums/viewtopic.php?t=2162&p=13742#p13742 <![CDATA[Modifying Senso's Parameter update module--Intermittent success....]]> Statistics: Posted by woodslanding — 02 May 2010, 19:28
2010-05-02T12:33:45+01:00 2010-05-02T12:33:45+01:00 https://brainmodular.org/forums/viewtopic.php?t=2162&p=13741#p13741 <![CDATA[Modifying Senso's Parameter update module--Intermittent success....]]> i think it's some timing issue..IML is trycky cause it takes non mesurable time to update.
I added a second update in the script, to clearly order events:
first get value from param, set the scriptTMPin, then resend after a quick wait of 100ms wich is enough but needed (time for iml to get/set value), so get quick feedback working. (this is what will happen when you press "update".
Then instead of sending always back value of fader to param (as sentence was "else begin") that could lead to some feedback pb, moded to operate only if valinhaschgd
using n= paramvalin .
seems to work ok here but you might need to increase first timer relating on VST pgmchange timings i didn't test.
edit: tested yup here 100ms more on first timer and pgm are well rerouted (if a has chg out of vst trigger the update).
now think it's the average time for iml to operate when using one value, this musn't depend from VST.
here is the file:
http://sensomusic.com/forums/uploads.ph ... stBed3.wkp
Statistics: Posted by 23fx23 — 02 May 2010, 13:33
2010-05-02T07:08:39+01:00 2010-05-02T07:08:39+01:00 https://brainmodular.org/forums/viewtopic.php?t=2162&p=13739#p13739 <![CDATA[Modifying Senso's Parameter update module--Intermittent success....]]>
It's all set up to work with usine's included analog delay VST, modifying the cutoff. If I move the drawbar, the cutoff moves appropriately (i.e. inversely)
What I want is to be able to move the cutoff knob in the vst and then press the UPDATE button, and have the drawbar update to display the value. Somehow, it's getting an erroneous value, and then passing that value on to the VST.
I can't for the life of me figure out where this other value is coming from!
any help appreciated.....
http://sensomusic.com/forums/uploaded/d ... stBed2.wkp
cheers,
-e
Statistics: Posted by woodslanding — 02 May 2010, 08:08
2010-04-24T18:23:58+01:00 2010-04-24T18:23:58+01:00 https://brainmodular.org/forums/viewtopic.php?t=2162&p=13610#p13610 <![CDATA[Modifying Senso's Parameter update module--Intermittent success....]]>
Here's my test patch. Maybe there is something wrong with the patch.
http://sensomusic.com/forums/uploaded/d ... estBed.wkp
Statistics: Posted by woodslanding — 24 Apr 2010, 19:23
2010-04-24T13:06:00+01:00 2010-04-24T13:06:00+01:00 https://brainmodular.org/forums/viewtopic.php?t=2162&p=13607#p13607 <![CDATA[Modifying Senso's Parameter update module--Intermittent success....]]>
Statistics: Posted by 23fx23 — 24 Apr 2010, 14:06
2010-04-24T09:08:31+01:00 2010-04-24T09:08:31+01:00 https://brainmodular.org/forums/viewtopic.php?t=2162&p=13606#p13606 <![CDATA[Modifying Senso's Parameter update module--Intermittent success....]]>
I'm in US, and my computer uses a dot, not a comma.
The tempIN on the script is showing many different values, but when I getValue() from it, it's always a 1 or 0.
But maybe I have another prob in my script. Here it is:
CODE:
/////////////////////////////////////////////// Send value to vst param////////////////////////////////////////////// parameters declarationvar plugNameIN    &#58; Tparameter;var paramNameIN    &#58; Tparameter;var paramValIN    &#58; Tparameter;var ctlNameIN    &#58; Tparameter;var prgchIN     &#58; Tparameter;var scriptNameIN &#58; Tparameter;var tempIN    &#58; Tparameter;var s         &#58; String;// destroyprocedure Destroy;begin  end;// initialisation &#58; create parametersprocedure init;begin   plugNameIN &#58;= CreateParam&#40;'plug name',ptTextField&#41;; ctlNameIN &#58;= CreateParam&#40;'control name', ptTextField&#41;; paramNameIN &#58;= CreateParam&#40;'param name',ptTextField&#41;; paramValIN &#58;= CreateParam&#40;'param value',ptDataField&#41;; prgchIN &#58;= CreateParam&#40;'prog changed',ptDataField&#41;; scriptNameIN &#58;= CreateParam&#40;'script Name',ptTextField&#41;; tempIN &#58;= CreateParam&#40;'tempIN',ptDataField&#41;; SetIsOutPut&#40;plugNameIN,false&#41;; SetIsOutPut&#40;paramNameIN,false&#41;; SetIsOutPut&#40;paramValIN,false&#41;; SetIsOutPut&#40;prgchIN,false&#41;; SetIsOutPut&#40;ctlNameIN,false&#41;; SetIsOutPut&#40;scriptNameIN,false&#41;; SetIsOutPut&#40;tempIN,false&#41;; end;procedure Callback&#40;n&#58;integer&#41;;var i &#58; integer;var val &#58; double;var scriptName &#58; String;begin SendUsineMsg&#40;'SET_TARGET_PATCH SENDER_PATCH'&#41;; if &#40;n = 1&#41; or &#40;n = 2&#41; or &#40;n = 4&#41; //retreive the old value then begin   S &#58;= 'GET_VALUE '+GetStringValue&#40;plugNameIN&#41;+' '''+GetStringValue&#40;paramNameIN&#41;+''' '+'THEPARAMVALUE';   SendUsineMsg &#40;s&#41;;//   strace&#40;s&#41;;     scriptName &#58;= getStringValue&#40;scriptNameIN&#41;;     S &#58;= 'SET_VALUE ' + scriptName + ' tempIN  THEPARAMVALUE';     SendUsineMsg &#40;s&#41;;     val &#58;= abs&#40;1 - getValue&#40;TempIN&#41;&#41;;     strace&#40;'value = ' + floatToStr&#40;val&#41;&#41;;     S &#58;= 'SET_VALUE ' + GetStringValue&#40;ctlNameIN&#41; + ' 1 ' + '"' + FLoatTostr&#40;val&#41; +'"';     SendUsineMsg &#40;s&#41;;     strace&#40;s&#41;;//    end else begin   S &#58;= 'SET_VALUE '+ GetStringValue&#40;plugNameIN&#41; + ' '''+GetStringValue&#40;paramNameIN&#41; + ''' ' + FloatTostr&#40;abs&#40;1 - GetValue&#40;paramValIN&#41;&#41;&#41;;   SendUsineMsg &#40;s&#41;;   //strace&#40;s&#41;; end; end;// no process bloc
Statistics: Posted by woodslanding — 24 Apr 2010, 10:08
2010-04-24T00:00:33+01:00 2010-04-24T00:00:33+01:00 https://brainmodular.org/forums/viewtopic.php?t=2162&p=13603#p13603 <![CDATA[Modifying Senso's Parameter update module--Intermittent success....]]>
Very clever workaround!!!
Statistics: Posted by woodslanding — 24 Apr 2010, 01:00
2010-04-23T10:10:41+01:00 2010-04-23T10:10:41+01:00 https://brainmodular.org/forums/viewtopic.php?t=2162&p=13598#p13598 <![CDATA[Modifying Senso's Parameter update module--Intermittent success....]]>
ie when using GET_VALUE F1 1 PARAMVAL iml goes and pick inlet 1 of F1 and stores it to variable PARAMVAL.
when then using SET_VALUE F2 1 PARAMVAL the variable will set F2, as i does actually. but I never could get something like
SET_VALUE F2 1 (1-PARAMVAL) directly working.
I had similar pbs, so my workaround was that the script should know the variable and prepare the message internally. I would create a new TEMPVALin inlet, the first Mess getting value out of VST, second applying to the Script Inlet.
S := 'GET_VALUE '+GetStringValue(plugNameIN)+' '''+GetStringValue(paramNameIN)+''' '+'THEPARAMVALUE';
SendUsineMsg (s);
S := 'SET_VALUE SCRIPTNAME TEMPVALin THEPARAMVALUE';
SendUsineMsg (s);
///third resending correct value.
S := 'SET_VALUE ' + GetStringValue(ctlNameIN) + ' 1 '+'"'+FloatToStr(abs(1-GetValue(TEMPVaIn)))+'"';
SendUsineMsg (s);
(maybe need to make your windows decimal system being . and not , im not sure)
but if there is a way to direct performs operations to iml variables i would love to be aware of.
Statistics: Posted by 23fx23 — 23 Apr 2010, 11:10
2010-04-23T06:44:24+01:00 2010-04-23T06:44:24+01:00 https://brainmodular.org/forums/viewtopic.php?t=2162&p=13593#p13593 <![CDATA[Modifying Senso's Parameter update module--Intermittent success....]]>
Here's my question for anyone who understands IML. I would like to use this to control drawbars on the hammond. This requires inverting the values. I have managed to get the slider and the VST param to agree by changing the appropriate line to this:
S := 'SET_VALUE '+GetStringValue(plugNameIN)+' '''+GetStringValue(paramNameIN)+''' '+FloatTostr(abs(1 - GetValue(paramValIN)));
Works great! Problem is that I'm not getting the inverted values on a patch change. I don't understand how I might alter the value represented by THEPARAMVALUE, as it seems like this value is never actually known to the script!!
Any help appreciated!
CODE:
/////////////////////////////////////////////// Send value to vst param////////////////////////////////////////////// parameters declarationvar plugNameIN    &#58; Tparameter;var paramNameIN    &#58; Tparameter;var paramValIN    &#58; Tparameter;var ctlNameIN    &#58; Tparameter;var prgchIN     &#58; Tparameter;var s         &#58; String;// destroyprocedure Destroy;begin  end;// initialisation &#58; create parametersprocedure init;begin   plugNameIN &#58;= CreateParam&#40;'plug name',ptTextField&#41;; ctlNameIN &#58;= CreateParam&#40;'control name', ptTextField&#41;; paramNameIN &#58;= CreateParam&#40;'param name',ptTextField&#41;; paramValIN &#58;= CreateParam&#40;'param value',ptDataField&#41;; prgchIN &#58;= CreateParam&#40;'prog changed',ptDataField&#41;; SetIsOutPut&#40;plugNameIN,false&#41;; SetIsOutPut&#40;paramNameIN,false&#41;; SetIsOutPut&#40;paramValIN,false&#41;; SetIsOutPut&#40;prgchIN,false&#41;; SetIsOutPut&#40;ctlNameIN,false&#41;; end;procedure Callback&#40;n&#58;integer&#41;;var i &#58; integer;begin SendUsineMsg&#40;'SET_TARGET_PATCH SENDER_PATCH'&#41;; if &#40;n = 1&#41; or &#40;n = 2&#41; or &#40;n = 4&#41; //retreive the old value then begin   S &#58;= 'GET_VALUE '+GetStringValue&#40;plugNameIN&#41;+' '''+GetStringValue&#40;paramNameIN&#41;+''' '+'THEPARAMVALUE';   SendUsineMsg &#40;s&#41;;//   strace&#40;s&#41;;   S &#58;= 'SET_VALUE ' + GetStringValue&#40;ctlNameIN&#41; + ' 1 THEPARAMVALUE';   SendUsineMsg &#40;s&#41;;//   strace&#40;s&#41;; end else begin   S &#58;= 'SET_VALUE '+GetStringValue&#40;plugNameIN&#41;+' '''+GetStringValue&#40;paramNameIN&#41;+''' '+FloatTostr&#40;abs&#40;1 - GetValue&#40;paramValIN&#41;&#41;&#41;;   SendUsineMsg &#40;s&#41;;   strace&#40;s&#41;; end; end;// no process bloc
Statistics: Posted by woodslanding — 23 Apr 2010, 07:44
2010-04-23T02:33:51+01:00 2010-04-23T02:33:51+01:00 https://brainmodular.org/forums/viewtopic.php?t=2162&p=13589#p13589 <![CDATA[Modifying Senso's Parameter update module--Intermittent success....]]>
note i noticed not all Vst param will work, only the 64 first. try first with the Wksp and RMXL, try to move upper left pots.
but unfortunately I didn't found solution for replacing the "pass if chg" out of vst, here it's one side control.
Iml and scripting is "relatively" simple once you got some good simple example and understand delphi basics like string concenation is + a string is in between ' ' ect, once understand all recurents "for i=0 to..." if, const, variables, types ect...
but for non initied like us, man can turn and turn around for hours...
still around 3weeks ago I started my first dive and i would say it's positive, even if yesterday I killed the script i spent one day on it, and made a working patch of what i what after in few minutes.
I think scripts are cool in some cases, but not vital generally, as you often can do a patch equivalent, that won't necessary be higher cpu. It worth a lot when there is N opertations, or some checks to do in N, or i suppose midi messages generating and array manipulations. So long way for us to learn..
so ...when a scripting workshop session with bsork in france :D?
Statistics: Posted by 23fx23 — 23 Apr 2010, 03:33
2010-04-22T20:33:55+01:00 2010-04-22T20:33:55+01:00 https://brainmodular.org/forums/viewtopic.php?t=2162&p=13576#p13576 <![CDATA[Modifying Senso's Parameter update module--Intermittent success....]]>
I should be able to press start learn, turn a knob on the VST and press stop learn and then have the VST knob update the fader?
Anyways, I am happy to see great minds working on breaking the barrier between VST parameters and wires. Having a fader and a pass if change module on every used VST parameter pin is soooo 2009!
I hope someone can kick me and tell me how easy scripting IML is but at the moment it makes absolutely no sense to me at all !
There is so many cool things I 'could' be doing....
Statistics: Posted by gurulogic — 22 Apr 2010, 21:33
2010-04-22T16:44:40+01:00 2010-04-22T16:44:40+01:00 https://brainmodular.org/forums/viewtopic.php?t=2162&p=13566#p13566 <![CDATA[Modifying Senso's Parameter update module--Intermittent success....]]>
I just tried this, including 23fx23's suggestion and one problem I am noticing is that when selecting a parameter from the combobox, the fader value is not updating as in the original Senso patch. Insted the current (static) value of the fader is being sent to the new VST parameter each time a parameter is selected.
Hmmm. I thought I left the original functionality of the script intact. I'll see what I can do.
I assume there is no way to actually monitor changes to the VST parameter via IML? so the fader would update its value to the VST value, whether it was via the VST GUI, or via patch change. That would be more elegant.....
Anyway, I will look into it. But I have no clue of IML-- I am just trying to send it out the same IML Olivier did, but a little more often!
-e
Statistics: Posted by woodslanding — 22 Apr 2010, 17:44
2010-04-22T15:24:54+01:00 2010-04-22T15:24:54+01:00 https://brainmodular.org/forums/viewtopic.php?t=2162&p=13565#p13565 <![CDATA[Modifying Senso's Parameter update module--Intermittent success....]]>
btw if some are interested, I made a patch that do kind of reverse operation:
"learn" a vst parameter to some usine fader wireless , by moving the pot on vst interface.
http://www.sensomusic.com/forums/upload ... 0param.rar
works cool with values, unfortunately could'nt get captions, seems the iml
GET_STRING_VALUE ITEM i VAR
will always store the caption to some float Var, any trick to make it store to a string variable, then re- assign it using ie
SET_STRING_VALUE ITEM caption VAR ?
works in script, and float values Get-set works with iml but don't catch how to deal with string get-set with IML..
is it possible?
Statistics: Posted by 23fx23 — 22 Apr 2010, 16:24
2010-04-22T11:05:58+01:00 2010-04-22T11:05:58+01:00 https://brainmodular.org/forums/viewtopic.php?t=2162&p=13558#p13558 <![CDATA[Modifying Senso's Parameter update module--Intermittent success....]]> Statistics: Posted by gurulogic — 22 Apr 2010, 12:05
2010-04-22T09:31:58+01:00 2010-04-22T09:31:58+01:00 https://brainmodular.org/forums/viewtopic.php?t=2162&p=13557#p13557 <![CDATA[Modifying Senso's Parameter update module--Intermittent success....]]>
THANKS!
Statistics: Posted by woodslanding — 22 Apr 2010, 10:31
2010-04-22T07:39:52+01:00 2010-04-22T07:39:52+01:00 https://brainmodular.org/forums/viewtopic.php?t=2162&p=13556#p13556 <![CDATA[Modifying Senso's Parameter update module--Intermittent success....]]> I think pb is you need a longer time than just a wait one bloc for all params of VST beeing changed, then script should check the values, so here I put a tempo wait of 100 ms using a countMs to test and it seems to work now always correctly
Can tweak the time for a good ratio speed/no data loss, generally 100ms is sure and fast enough, but maybe this depends on VST, usine blocs or others, so a manual adjust is maybe simpler.
(just replace the wait one out of haschd of pgm change by a wait ms, stop led driven to the script.)
(btw olivier I would love to know if there are some "static" time ranges usine uses in iml, or various process, to fit them in adapted cases ie
iml, bitmap/gfx updates ect..) even if feel in this case this depends more on VSt, in some cases could be interesting to know..
..if some are "fixed"...
Statistics: Posted by 23fx23 — 22 Apr 2010, 08:39
2010-04-22T00:50:09+01:00 2010-04-22T00:50:09+01:00 https://brainmodular.org/forums/viewtopic.php?t=2162&p=13553#p13553 <![CDATA[Modifying Senso's Parameter update module--Intermittent success....]]> http://www.sensomusic.com/forums/upload ... Update.zip
Statistics: Posted by gurulogic — 22 Apr 2010, 01:50
2010-04-22T00:47:25+01:00 2010-04-22T00:47:25+01:00 https://brainmodular.org/forums/viewtopic.php?t=2162&p=13552#p13552 <![CDATA[Modifying Senso's Parameter update module--Intermittent success....]]> Statistics: Posted by Clearscreen — 22 Apr 2010, 01:47
2010-04-21T23:44:18+01:00 2010-04-21T23:44:18+01:00 https://brainmodular.org/forums/viewtopic.php?t=2162&p=13550#p13550 <![CDATA[Modifying Senso's Parameter update module--Intermittent success....]]>
Params are being controlled just fine by the fader, but the fader value doesn't always update when a new patch is selected.
I had this problem in the context of my larger setup, and thought maybe the IML was being intercepted, but even running only this test patch in an empty workspace, it is intermittent.
http://sensomusic.com/forums/uploaded/P ... Update.zip
Any thoughts?? I expected it to either work or not, but not sure why it sometimes does!
-e
Statistics: Posted by woodslanding — 22 Apr 2010, 00:44
here is the file:
cheers,
-e
CODE:
SendUsineMsg (s);
SendUsineMsg (s);
SendUsineMsg (s);
CODE:
-e
is it possible?
THANKS!
-e
