ArrayArrayArrayArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2010-04-15T22:57:16+01:00 https://brainmodular.org/forums/app.php/feed/topic/2144 2010-04-15T22:57:16+01:00 2010-04-15T22:57:16+01:00 https://brainmodular.org/forums/viewtopic.php?t=2144&p=13459#p13459 <![CDATA[help building a patch]]>
I'll try and tell. thank you.
Statistics: Posted by Floego — 15 Apr 2010, 23:57
2010-04-15T22:42:57+01:00 2010-04-15T22:42:57+01:00 https://brainmodular.org/forums/viewtopic.php?t=2144&p=13457#p13457 <![CDATA[help building a patch]]> sorry if it was obvious..
so maybe you have to use an extract sub array module before you array ?, but I'm not a specialist ..
Statistics: Posted by nay-seven — 15 Apr 2010, 23:42
2010-04-15T22:07:58+01:00 2010-04-15T22:07:58+01:00 https://brainmodular.org/forums/viewtopic.php?t=2144&p=13454#p13454 <![CDATA[help building a patch]]>
Statistics: Posted by Floego — 15 Apr 2010, 23:07
2010-04-15T20:45:01+01:00 2010-04-15T20:45:01+01:00 https://brainmodular.org/forums/viewtopic.php?t=2144&p=13452#p13452 <![CDATA[help building a patch]]> Statistics: Posted by nay-seven — 15 Apr 2010, 21:45
2010-04-15T20:22:03+01:00 2010-04-15T20:22:03+01:00 https://brainmodular.org/forums/viewtopic.php?t=2144&p=13451#p13451 <![CDATA[help building a patch]]> The profile I have used is /tuio/2Dcur , which owns 3 types of messages per package:
-set, defines the position of each blob at a given time
-alive, tells me what is the id of each one of that blobs
-fseq, helps me to know when I have to reset the set and alive, ie. when a blob is killed or created.
A package may contain a lot of set messages but only one alive and one fseq.
But in usine I have not been able to track the fseq command, that is my main problem. Usine receives the whole package (as seen in the osc terminal) but the "Osc receive" module fails to pick them. Or maybe I am missing something, I don't really know.
Summarizing, I just can't keep a track of multitouch, only one touch at a time. Multitouch gives me wrong parameters (ie. position)
Sorry for being soooo boring with this explanations!!, thank you for reading.
Statistics: Posted by Floego — 15 Apr 2010, 21:22
2010-04-15T19:56:40+01:00 2010-04-15T19:56:40+01:00 https://brainmodular.org/forums/viewtopic.php?t=2144&p=13449#p13449 <![CDATA[help building a patch]]> this link
seems to be an array way..? ( profiles and attributes )
Statistics: Posted by nay-seven — 15 Apr 2010, 20:56
2010-04-15T19:30:10+01:00 2010-04-15T19:30:10+01:00 https://brainmodular.org/forums/viewtopic.php?t=2144&p=13447#p13447 <![CDATA[help building a patch]]>
The main problem (at the moment) seems to do with the way tuio handles the id for each blob and how it kills and creates new ones. Inside Usine I can't find the fseq parameter when using the osc receive module. Maybe I could explain that better, just ask me please.
Statistics: Posted by Floego — 15 Apr 2010, 20:30
2010-04-15T18:15:07+01:00 2010-04-15T18:15:07+01:00 https://brainmodular.org/forums/viewtopic.php?t=2144&p=13444#p13444 <![CDATA[help building a patch]]> what kind of information do you receive right now..?
have you try use the create inlet of a create midi module..?
Statistics: Posted by nay-seven — 15 Apr 2010, 19:15
2010-04-15T07:13:52+01:00 2010-04-15T07:13:52+01:00 https://brainmodular.org/forums/viewtopic.php?t=2144&p=13425#p13425 <![CDATA[help building a patch]]>
I'm trying to build a patch that create simple note on midi messages in usine from a tuio device (like a tuio multitouch screen). That way, I can virtually connect any tuio device with any vsti/vst using only usine as a bridge. If the patch is developed enough I believe it could be able to send a complex midi message to any midi device from a touch screen. As of today I have a semifunctional basic patch, so any colaboration or help would be appreciated.
Statistics: Posted by Floego — 15 Apr 2010, 08:13
