Statistics: Posted by joffo78 — 12 Apr 2010, 01:52
]]>2010-04-11T15:28:35+01:002010-04-11T15:28:35+01:00https://brainmodular.org/forums/viewtopic.php?t=2122&p=13326#p13326If you want to see a new approach you can have a look on my addon (perform seq). You can activate or not the sending of a PGM in a conductor. It's easy because you can do that whitout modify the structure of the patch. Only with switching on or off the sending of one PGM
Statistics: Posted by joffo78 — 11 Apr 2010, 16:28
]]>2010-04-11T13:00:39+01:002010-04-11T13:00:39+01:00https://brainmodular.org/forums/viewtopic.php?t=2122&p=13325#p13325Statistics: Posted by noise2sine — 11 Apr 2010, 14:00
Statistics: Posted by nay-seven — 10 Apr 2010, 19:27
]]>2010-04-10T17:48:16+01:002010-04-10T17:48:16+01:00https://brainmodular.org/forums/viewtopic.php?t=2122&p=13313#p13313Thanks i will test. But could you tell me what i had to affect at code 1 and code 2 ? sorry i am not very easy with MIDI :/
Statistics: Posted by cmodica — 10 Apr 2010, 18:48
]]>2010-04-10T17:44:45+01:002010-04-10T17:44:45+01:00https://brainmodular.org/forums/viewtopic.php?t=2122&p=13312#p13312Statistics: Posted by cmodica — 10 Apr 2010, 18:44
]]>2010-04-10T17:42:20+01:002010-04-10T17:42:20+01:00https://brainmodular.org/forums/viewtopic.php?t=2122&p=13311#p13311
Statistics: Posted by nay-seven — 10 Apr 2010, 18:42
]]>2010-04-10T15:48:05+01:002010-04-10T15:48:05+01:00https://brainmodular.org/forums/viewtopic.php?t=2122&p=13310#p13310 How can i send a specific program change when i recall a specific line in the conductor ??
i mean how a specific line in the conductor when recalling send as well a program change ?
thanks in advance
Statistics: Posted by noise2sine — 10 Apr 2010, 16:48
]]>2010-04-10T21:13:06+01:002010-04-10T21:13:06+01:00https://brainmodular.org/forums/viewtopic.php?t=2122&p=13317#p13317
Statistics: Posted by nay-seven — 10 Apr 2010, 22:13
]]>2010-04-10T18:35:18+01:002010-04-10T18:35:18+01:00https://brainmodular.org/forums/viewtopic.php?t=2122&p=13315#p13315 thanks again
Statistics: Posted by noise2sine — 10 Apr 2010, 19:35
thanks in advance
