ArrayArrayArrayArrayArrayArrayArrayArrayArrayArray
BrainModularBrainModular Users Forum2010-04-21T17:13:29+01:00https://brainmodular.org/forums/app.php/feed/topic/21202010-04-21T17:13:29+01:002010-04-21T17:13:29+01:00https://brainmodular.org/forums/viewtopic.php?t=2120&p=13543#p13543 , but the core is bsork , the i,j thing i was after.. i tweaked and adapted for Bg, yup can be handy to loop some paterns in the matrix as visual references especially when we ll have colrs
really love the background customisation section (another great utility patch candidate ), and the whole feeling of this 'simple but polyphonic' sequencer
soon a matrix version of the pianoroll ?! :rolleyes:
keep up the good work
Statistics: Posted by martignasse — 21 Apr 2010, 16:23
]]>2010-04-12T22:19:15+01:002010-04-12T22:19:15+01:00https://brainmodular.org/forums/viewtopic.php?t=2120&p=13357#p13357 you can connect back it to matrix mode, then on ib rightclic on the combobox and clic "not stored in Preset Manager" then it should be ok and will work in all modes.
]]>2010-04-12T03:54:32+01:002010-04-12T03:54:32+01:00https://brainmodular.org/forums/viewtopic.php?t=2120&p=13330#p13330Statistics: Posted by 23fx23 — 12 Apr 2010, 04:54
2010-04-11T11:19:34+01:002010-04-11T11:19:34+01:00https://brainmodular.org/forums/viewtopic.php?t=2120&p=13324#p13324 there is a little problem with the matrix mode because the combobox isn't connected. I've try to connect it but I failed.
]]>2010-04-10T22:25:09+01:002010-04-10T22:25:09+01:00https://brainmodular.org/forums/viewtopic.php?t=2120&p=13318#p13318the paterns can be any size and they will repeat on Bg, to make ie the Main beat and semitones, with a 4 and 12 lengh array. ala fruity loops" this allow to display notes behind, easier to see what we trig or visualize where we are, and can be customized for different uses ie split in 8 sequences or whatever..
]]>2010-04-10T19:18:38+01:002010-04-10T19:18:38+01:00https://brainmodular.org/forums/viewtopic.php?t=2120&p=13316#p13316notes, but will make a V2 later, think the zoom system and sequenaya would make a good combo touch sequencer... maybe if you wanna reuse the script for you..i will let that for a while.
]]>2010-04-10T10:54:17+01:002010-04-10T10:54:17+01:00https://brainmodular.org/forums/viewtopic.php?t=2120&p=13306#p13306for sure a future classic for Usine..
congrats
Statistics: Posted by nay-seven — 10 Apr 2010, 11:54
]]>2010-04-10T04:37:09+01:002010-04-10T04:37:09+01:00https://brainmodular.org/forums/viewtopic.php?t=2120&p=13298#p13298courtesy of nay and martignasse for stuff i picked in Sequenaya hope ya don't mind.
Basically it's a simple but polyphonic sequencer where can zoom/scroll to easy edit/display parts or have a global overview . compatible with preset manager, octave, speed, nb of steps.
direct exemple workspace with Helios Vst, can replace by what ya want.
]]>BrainModularBrainModular Users Forum2010-04-21T17:13:29+01:00https://brainmodular.org/forums/app.php/feed/topic/21202010-04-21T17:13:29+01:002010-04-21T17:13:29+01:00https://brainmodular.org/forums/viewtopic.php?t=2120&p=13543#p13543 , but the core is bsork , the i,j thing i was after.. i tweaked and adapted for Bg, yup can be handy to loop some paterns in the matrix as visual references especially when we ll have colrs
]]>2010-04-11T11:19:34+01:002010-04-11T11:19:34+01:00https://brainmodular.org/forums/viewtopic.php?t=2120&p=13324#p13324 there is a little problem with the matrix mode because the combobox isn't connected. I've try to connect it but I failed.
congrats
