ArrayArrayArrayArrayArrayArrayArray
BrainModularBrainModular Users Forum2010-04-08T00:05:42+02:00https://brainmodular.org/forums/app.php/feed/topic/21032010-04-08T00:05:42+02:002010-04-08T00:05:42+02:00https://brainmodular.org/forums/viewtopic.php?t=2103&p=13228#p13228It works this way I also learn a lot about midi routing with your answer
In another hand the volume control is now controlled by "usine" for each track I lose the volume automation of reaper for each track
maybe a easier implementation of "usine vst" in reaper (or other DAW) would be nice for midi item (especially for newbies) like for audio (as in the manual)
++ j.
Statistics: Posted by javanaiz — 08 Apr 2010, 00:05
]]>2010-04-06T07:28:07+02:002010-04-06T07:28:07+02:00https://brainmodular.org/forums/viewtopic.php?t=2103&p=13195#p13195 in reaper , route all midi canal to 2 ( for track 2 ):
In Usine , filter canal 1 , for track 1, canal 2 for track 2 and so..works fine and don't forget to set your audio out in Usine tracks too
Statistics: Posted by nay-seven — 06 Apr 2010, 07:28
"have you try to use only one instance of Usine vst and use several midi canal to route your tracks to usine...?"
do you mean :
I only open a usine vst in my reaper track number one ? then my "midi item" on "reaper track 2" will be routed to "usine track 2"
I tried but I didn't succed I abled "map input to channel 2 in reaper on my track 2 but I aint got any "midi in" in usine ?
txs for the vst buffer no crackle anymore now
Statistics: Posted by javanaiz — 06 Apr 2010, 01:01
]]>2010-04-05T23:17:50+02:002010-04-05T23:17:50+02:00https://brainmodular.org/forums/viewtopic.php?t=2103&p=13193#p13193have you try to use only one instance of Usine vst and use several midi canal to route your tracks to usine...? about crackles , i suppose you have test with different vst buffer size in usine..? ( setup /vst )
try also the last vst version..( 5.13 )
Statistics: Posted by nay-seven — 05 Apr 2010, 23:17
]]>2010-04-05T20:29:50+02:002010-04-05T20:29:50+02:00https://brainmodular.org/forums/viewtopic.php?t=2103&p=13188#p13188cause if I play a "sample item" (.wav) instead of this "midi item" the audio routing is all right
but ...
I got crackle and audio artefact maybe an previous vst usine version is doing better ?!
Statistics: Posted by javanaiz — 05 Apr 2010, 20:29
]]>2010-04-04T02:46:19+02:002010-04-04T02:46:19+02:00https://brainmodular.org/forums/viewtopic.php?t=2103&p=13159#p13159Statistics: Posted by gurulogic — 04 Apr 2010, 02:46
2010-04-04T00:23:58+02:002010-04-04T00:23:58+02:00https://brainmodular.org/forums/viewtopic.php?t=2103&p=13157#p13157 maybe some of you are using the usine vst version in Reaper. I've been doing like in the manual http://www.sensomusic.com/wiki/doku.php ... st_version I Simply add 3 UsineVst plugins, one per track.
I got a midi item in reaper in my track 1
But I got this problem : this midi item is played throught track 1,2,3 instead of track one in usine (or reaper ?!)
anyone encounter rhe same problem ?
Txs
Statistics: Posted by javanaiz — 04 Apr 2010, 00:23
]]>BrainModularBrainModular Users Forum2010-04-08T00:05:42+02:00https://brainmodular.org/forums/app.php/feed/topic/21032010-04-08T00:05:42+02:002010-04-08T00:05:42+02:00https://brainmodular.org/forums/viewtopic.php?t=2103&p=13228#p13228It works this way I also learn a lot about midi routing with your answer
++ j.
do you mean :
but ...
]]>2010-04-04T00:23:58+02:002010-04-04T00:23:58+02:00https://brainmodular.org/forums/viewtopic.php?t=2103&p=13157#p13157 maybe some of you are using the usine vst version in Reaper. I've been doing like in the manual http://www.sensomusic.com/wiki/doku.php ... st_version I Simply add 3 UsineVst plugins, one per track.
Txs
