ArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArray
BrainModularBrainModular Users Forum2011-08-14T15:03:28+01:00https://brainmodular.org/forums/app.php/feed/topic/20972011-08-14T15:03:28+01:002011-08-14T15:03:28+01:00https://brainmodular.org/forums/viewtopic.php?t=2097&p=20703#p20703Statistics: Posted by nay-seven — 14 Aug 2011, 16:03
2011-08-14T14:46:44+01:002011-08-14T14:46:44+01:00https://brainmodular.org/forums/viewtopic.php?t=2097&p=20702#p20702 i wanna try to look into making a "time-detector(i belive i have seen a module for this somewhere)so when the main bpm gets changes the sounds follows the tempo
one other thing i have thought about checking out if would be possible is a way to combine 2 of these into 1 to get a bigger matrix but with the same size cells as they have now
]]>2011-08-14T08:12:03+01:002011-08-14T08:12:03+01:00https://brainmodular.org/forums/viewtopic.php?t=2097&p=20696#p20696Statistics: Posted by nay-seven — 14 Aug 2011, 09:12
]]>2011-08-14T00:54:22+01:002011-08-14T00:54:22+01:00https://brainmodular.org/forums/viewtopic.php?t=2097&p=20690#p20690 i know they get shown in the waveform when a pad is pressed,but if it was possible you didnt have to remember where each sample is placed?
]]>2011-08-13T20:53:41+01:002011-08-13T20:53:41+01:00https://brainmodular.org/forums/viewtopic.php?t=2097&p=20683#p20683Statistics: Posted by ErotiCore SteNch — 13 Aug 2011, 21:53
]]>2011-08-13T20:52:20+01:002011-08-13T20:52:20+01:00https://brainmodular.org/forums/viewtopic.php?t=2097&p=20682#p20682Statistics: Posted by nay-seven — 13 Aug 2011, 21:52
]]>2011-08-13T20:33:04+01:002011-08-13T20:33:04+01:00https://brainmodular.org/forums/viewtopic.php?t=2097&p=20681#p20681 and the one that dont "work"wont give any sound no matter what i do,it also doesent help to re-load a new instance,dont know if it just happens here though.
btw i havent changed any samples or other settings in the patch
]]>2011-08-13T13:16:21+01:002011-08-13T13:16:21+01:00https://brainmodular.org/forums/viewtopic.php?t=2097&p=20667#p20667 one thing though i get alot of clicks,might just be the samples it came with though
]]>2011-05-13T09:34:59+01:002011-05-13T09:34:59+01:00https://brainmodular.org/forums/viewtopic.php?t=2097&p=19342#p19342Statistics: Posted by nay-seven — 13 May 2011, 10:34
]]>2010-08-18T03:10:24+01:002010-08-18T03:10:24+01:00https://brainmodular.org/forums/viewtopic.php?t=2097&p=15242#p15242
Statistics: Posted by waolelaid — 18 Aug 2010, 04:10
]]>2010-08-17T12:58:00+01:002010-08-17T12:58:00+01:00https://brainmodular.org/forums/viewtopic.php?t=2097&p=15223#p15223check the different layout in the first post
Statistics: Posted by nay-seven — 17 Aug 2010, 13:58
1_moment mode = will play momentary the sample as long you press the pad , except if you press and move your finger inside the pad 2_moment off = let play the sample in a classic toggle mode
Options button open a new window with a filter and a mixer.
Was a little try to use the great matrix with a momentary option , for a pad tool
Statistics: Posted by nay-seven — 01 Apr 2010, 13:18
]]>BrainModularBrainModular Users Forum2011-08-14T15:03:28+01:00https://brainmodular.org/forums/app.php/feed/topic/20972011-08-14T15:03:28+01:002011-08-14T15:03:28+01:00https://brainmodular.org/forums/viewtopic.php?t=2097&p=20703#p20703Statistics: Posted by nay-seven — 14 Aug 2011, 16:03
]]>2011-08-14T14:46:44+01:002011-08-14T14:46:44+01:00https://brainmodular.org/forums/viewtopic.php?t=2097&p=20702#p20702 i wanna try to look into making a "time-detector(i belive i have seen a module for this somewhere)so when the main bpm gets changes the sounds follows the tempo
