Statistics: Posted by cmodica — 30 Mar 2010, 18:59
]]>2010-03-30T13:16:14+01:002010-03-30T13:16:14+01:00https://brainmodular.org/forums/viewtopic.php?t=2090&p=13058#p13058Statistics: Posted by martignasse — 30 Mar 2010, 14:16
]]>2010-03-30T08:36:36+01:002010-03-30T08:36:36+01:00https://brainmodular.org/forums/viewtopic.php?t=2090&p=13043#p13043 The layout problems are resolved (with your help!). I have uploaded a new version.
]]>2010-03-29T21:53:06+01:002010-03-29T21:53:06+01:00https://brainmodular.org/forums/viewtopic.php?t=2090&p=13031#p13031about your layouts problems try to put them in a subpatch and set them as parent control panel
btw , you must have a huge screen ! I've a 22' and i have to adapt it to see it without scrolling..
good job ! and thanks to share
Statistics: Posted by nay-seven — 29 Mar 2010, 22:53
]]>2010-03-29T21:28:19+01:002010-03-29T21:28:19+01:00https://brainmodular.org/forums/viewtopic.php?t=2090&p=13030#p13030 Here is a small patch which I have make by inspiring me of " Marteleur " (by Servovalve).
Samplers are loaded with sounds of demo/audio files so that everybody can use it... but for best results, build up your own personal bank (it works well with shorts rhythmics sounds)...
There are still some little bug, but that work all the same. (for example, the general presetmanager and the crossfader which I do not manage to put them above in the graphic interface, every time I reload the patch they passes down..). Questions, suggestions, improvement are welcome..!
]]>BrainModularBrainModular Users Forum2010-03-30T22:22:53+01:00https://brainmodular.org/forums/app.php/feed/topic/20902010-03-30T22:22:53+01:002010-03-30T22:22:53+01:00https://brainmodular.org/forums/viewtopic.php?t=2090&p=13073#p13073Statistics: Posted by gurulogic — 30 Mar 2010, 23:22
]]>2010-03-30T17:59:11+01:002010-03-30T17:59:11+01:00https://brainmodular.org/forums/viewtopic.php?t=2090&p=13064#p13064 Bravo !!!
