ArrayArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2010-03-28T03:24:14+01:00 https://brainmodular.org/forums/app.php/feed/topic/2081 2010-03-28T03:24:14+01:00 2010-03-28T03:24:14+01:00 https://brainmodular.org/forums/viewtopic.php?t=2081&p=12999#p12999 <![CDATA[SQuare v2.5____V5 reloaded]]> Know that still does not remove his charm and ingenuity of The Square, because its a lot of work to do his.
It deserves a big BRAVO!
the way you found, I am also veejay and it'sa good idea to see
give what Resolume 3 with The Square, can give her things
amazing.
if it is with great anticipation that I wait with version 3
sampler and listbox to be able to load my sounds and exploit the potential of The Square .:D
Statistics: Posted by VjRobotX — 28 Mar 2010, 04:24
2010-03-28T02:04:29+01:00 2010-03-28T02:04:29+01:00 https://brainmodular.org/forums/viewtopic.php?t=2081&p=12997#p12997 <![CDATA[SQuare v2.5____V5 reloaded]]> yup, sorry if feel disapointed, i will have a look for your suggest.
in videos square was contolling some vst synth in usine, and also contolling ableton live via midi. To my mind it's more modular to have a controller one side that controls instruments otherside, because everybody don't have same wantings, some may want to use samplers, some other their favorite vst, some use a certain page to trigger specific fx, control a mixer/bus routing ect..
but it's true could be nice to have build in i will have a look for v3.
but yes Square can control any usine/vst/outside app via midi (or there is also a direct data,no midi, busses list i have to update, will repost), so you can make it trigger some samples of usine sampler, or use it's sequencer to command your favorite vst synth ect.i also fixed the automations. I will try to repost soon (during next week)with an example controlling usine sampler or vst/synth, but you can try to command a sampler/synth via midi.
(look at the midi options, clic a cell to edit it's parameters, for example activate Z so it will send a midi message you can choose when cliqing that cell (ie note on), another for next cell ect, but once youve set some settings, you need to press apply/store for them to work, then you will see some led activity blink).
Statistics: Posted by 23fx23 — 28 Mar 2010, 03:04
2010-03-27T19:06:47+01:00 2010-03-27T19:06:47+01:00 https://brainmodular.org/forums/viewtopic.php?t=2081&p=12988#p12988 <![CDATA[SQuare v2.5____V5 reloaded]]> and second, LIVE mode, where you'll have his bank loop and melody.
without having to go through the machines outside.
It is true that the video we see that The Square is that of driving sounds
damage I was doing such a joy to work with The Square.
Now, The Square can He commend control module Usine, such as drum or other sampler
Statistics: Posted by VjRobotX — 27 Mar 2010, 19:06
2010-03-27T17:59:30+01:00 2010-03-27T17:59:30+01:00 https://brainmodular.org/forums/viewtopic.php?t=2081&p=12985#p12985 <![CDATA[SQuare v2.5____V5 reloaded]]> Statistics: Posted by 23fx23 — 27 Mar 2010, 17:59
2010-03-27T15:42:17+01:00 2010-03-27T15:42:17+01:00 https://brainmodular.org/forums/viewtopic.php?t=2081&p=12983#p12983 <![CDATA[SQuare v2.5____V5 reloaded]]>
I need a little help
I'd like to understand how The Square, because once opened there is no sound.
My question is: The Square is it just a MIDI controller or can be put that to semple am mode
SQ or Live.
I have searched and I have not found a listbox or other places to put sound
thank you in advance for your help
Statistics: Posted by VjRobotX — 27 Mar 2010, 15:42
2010-03-27T04:45:17+01:00 2010-03-27T04:45:17+01:00 https://brainmodular.org/forums/viewtopic.php?t=2081&p=12979#p12979 <![CDATA[SQuare v2.5____V5 reloaded]]> Statistics: Posted by VjRobotX — 27 Mar 2010, 04:45
2010-03-27T01:48:08+01:00 2010-03-27T01:48:08+01:00 https://brainmodular.org/forums/viewtopic.php?t=2081&p=12976#p12976 <![CDATA[SQuare v2.5____V5 reloaded]]> (for those who didn't see previous version, what it can do some videos with shitty soundz just to test previous V2.2 and v2:
http://www.youtube.com/user/23fx232323# ... JO1nLrT1rw
http://www.youtube.com/watch?v=pIMOLI2eTQ4
now the v2.5 a bit "rounded" ;) :
so brief summup:
It's a grid of 16 cellz. there are 32 pages. each page can have it's own colors/captions/modes/advanced midi out settings stored and recalled.
Each cell act as an XY and can store/recall XYZ value, in absolute or relative (recall previous value to avoid jumps).
on performance can choose to be in toggle or momentary action.
each page have also 16 local presets for "paterns" for XYZ values.
on a chosen page can have 16x synced automations running and looping, endless looper like.
tab Square/ableton mode for an ableton type trigger grid.
Im sorry, im not sure i will make a wiki yet because it would be a huge job and i plan to rebuild it all with matrix/V5 powered, on 8x4.actually it's the V4 readapted, and I feel lost in it and think many patching could be improved and would worth a complete rebuild, LiveOsc being my new live dedicaced patch, and square will more focus on midi/usine internal with extended features i got in mind, ie to use with usine samplerz. so i consider it as a "by waiting" reloaded patch i don't plan to maintenance that much..(still a bit if find bugz) but if i see it still performs good i ll try to mazke a wiki (with luky luke help ;)?
but no worries there is a help tutorial included, and i spent time so that each item have a hint (right clic to have a short description), and I will answer any Question some may have.
hope ya enjoy.
note: as my sequencers are quite complex (can set ie Y set velocity, X gate, or note ect..) they are a bit cpu hungry so I limited them to 8 on first 1-8 page if they are activated, i will have a look to find a better system for V3.matrix powered.
(im waiting you martin ;) !!)
/addons/other
re edit: ive seen a litlle mess in automations due to the fact that roll module have been changed from percent to steps. (hehe i asked for that now i pay) that's a better behaviour, thanks a lot martin. but I have to correct that, will update later)
Statistics: Posted by 23fx23 — 27 Mar 2010, 01:48
amazing.
SQ or Live.
so brief summup:
hope ya enjoy.
/addons/other
