ArrayArrayArrayArrayArrayArrayArrayArrayArray
BrainModularBrainModular Users Forum2010-03-29T14:55:26+01:00https://brainmodular.org/forums/app.php/feed/topic/20742010-03-29T14:55:26+01:002010-03-29T14:55:26+01:00https://brainmodular.org/forums/viewtopic.php?t=2074&p=13025#p13025 I don't understand the 'mapper' and 'array' logic (allways go without that). Here where am i yet (nowhere).
The SDK solution : definitively not for me! Script is certainly the best solution but after having a look at the 'transpose' example, well, is also not so easy to get a good logical approach.
Salutation, Cyrille.
Statistics: Posted by claygues — 29 Mar 2010, 15:55
]]>2010-03-26T17:06:11+01:002010-03-26T17:06:11+01:00https://brainmodular.org/forums/viewtopic.php?t=2074&p=12955#p12955so you can use 2 array ( 128 faders ) one for in values , one for out values..? more easy to edit...?
and good news for the crash..
Statistics: Posted by nay-seven — 26 Mar 2010, 17:06
]]>2010-03-26T16:47:02+01:002010-03-26T16:47:02+01:00https://brainmodular.org/forums/viewtopic.php?t=2074&p=12954#p12954 First, It seems that crashes that i have, no more appear since i remove a particular patche that i use to do test on midi behaviours. Then no more trouble in moving patches through grid. The trouble involves my patch, not usine.
How can i miss it? Still can't see a way to use 'mapper' to my purpose : there is only 31 entry in it; do i need to use (128/31=4,1) 5 'mapper', or divide data1 from 'midi get message' by 12 and without lose the octave value? i need to think it more.
Another way is to redo 'scaleMap' module that it is almost exactly that i want, i take a look on the sdk, if i can understand.
Statistics: Posted by claygues — 26 Mar 2010, 16:47
]]>2010-03-26T14:38:52+01:002010-03-26T14:38:52+01:00https://brainmodular.org/forums/viewtopic.php?t=2074&p=12941#p12941Statistics: Posted by nay-seven — 26 Mar 2010, 14:38
2010-03-26T14:27:39+01:002010-03-26T14:27:39+01:00https://brainmodular.org/forums/viewtopic.php?t=2074&p=12939#p12939Statistics: Posted by claygues — 26 Mar 2010, 14:27
]]>2010-03-26T10:41:21+01:002010-03-26T10:41:21+01:00https://brainmodular.org/forums/viewtopic.php?t=2074&p=12931#p12931For a script i can try collect scales (at least those in the old 'user scale') and put them in after someone had wrote it (i can't do that).
For now when i open old patches, i carefully do 'open patch', 'save patch' and 'clear patch' instead of move them in the grid to avoid crash. It's works. Another things, the file saver with image in the layer is very efficient to quickly organize patche interface, very helpful to me.
Statistics: Posted by claygues — 26 Mar 2010, 10:41
]]>2010-03-26T08:40:00+01:002010-03-26T08:40:00+01:00https://brainmodular.org/forums/viewtopic.php?t=2074&p=12929#p12929Statistics: Posted by soundmind — 26 Mar 2010, 08:40
]]>2010-03-26T08:07:56+01:002010-03-26T08:07:56+01:00https://brainmodular.org/forums/viewtopic.php?t=2074&p=12928#p12928but maybe a good candidate for a first script..? I'm sure some guru will help you here..
and if you have serious crash , please report to senso..
Statistics: Posted by nay-seven — 26 Mar 2010, 08:07
]]>2010-03-25T17:27:45+01:002010-03-25T17:27:45+01:00https://brainmodular.org/forums/viewtopic.php?t=2074&p=12912#p12912 Slowly come from usine 4 to 5 version, need to redo a lot of patches. Grid/IB is clearer and nicer now, but crashes often when moving several time patch in grid ('access violation'). The 'user scale' module no more works in usine 5. Is there a way to define more scales in 'midi/transform' module? (never try the sdk, if it exist a simpler way...).
Salutations, Cyrille.
Statistics: Posted by claygues — 25 Mar 2010, 17:27
]]>BrainModularBrainModular Users Forum2010-03-29T14:55:26+01:00https://brainmodular.org/forums/app.php/feed/topic/20742010-03-29T14:55:26+01:002010-03-29T14:55:26+01:00https://brainmodular.org/forums/viewtopic.php?t=2074&p=13025#p13025 I don't understand the 'mapper' and 'array' logic (allways go without that). Here where am i yet (nowhere).
]]>2010-03-26T14:27:39+01:002010-03-26T14:27:39+01:00https://brainmodular.org/forums/viewtopic.php?t=2074&p=12939#p12939Statistics: Posted by claygues — 26 Mar 2010, 14:27
