ArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArray
BrainModularBrainModular Users Forum2010-03-29T13:13:11+01:00https://brainmodular.org/forums/app.php/feed/topic/20652010-03-29T13:13:11+01:002010-03-29T13:13:11+01:00https://brainmodular.org/forums/viewtopic.php?t=2065&p=13024#p13024My new version of perform seq is on the addons page. It had a lot of improvement like surrond panner and midi. have a look. bye JF
Statistics: Posted by joffo78 — 29 Mar 2010, 14:13
]]>2010-03-27T22:25:09+01:002010-03-27T22:25:09+01:00https://brainmodular.org/forums/viewtopic.php?t=2065&p=12994#p12994Statistics: Posted by joffo78 — 27 Mar 2010, 22:25
2010-03-27T21:38:40+01:002010-03-27T21:38:40+01:00https://brainmodular.org/forums/viewtopic.php?t=2065&p=12991#p12991Statistics: Posted by nay-seven — 27 Mar 2010, 21:38
]]>2010-03-27T21:05:47+01:002010-03-27T21:05:47+01:00https://brainmodular.org/forums/viewtopic.php?t=2065&p=12990#p12990A new version of this workspace should be here next monday
Statistics: Posted by joffo78 — 27 Mar 2010, 21:05
]]>2010-03-25T00:47:45+01:002010-03-25T00:47:45+01:00https://brainmodular.org/forums/viewtopic.php?t=2065&p=12883#p12883The wiki page existe now. I did my best to be the most accurate but it wasn't easy due to my english.
Statistics: Posted by joffo78 — 25 Mar 2010, 00:47
now just click the edit button and add pictures and a little explanations...
Statistics: Posted by nay-seven — 24 Mar 2010, 20:38
]]>2010-03-24T19:47:45+01:002010-03-24T19:47:45+01:00https://brainmodular.org/forums/viewtopic.php?t=2065&p=12874#p12874Statistics: Posted by joffo78 — 24 Mar 2010, 19:47
]]>2010-03-24T18:02:01+01:002010-03-24T18:02:01+01:00https://brainmodular.org/forums/viewtopic.php?t=2065&p=12873#p12873a new tradition here is to create a wiki page for an addon...? check the playground or other wiki page to have an idea / copy and adapt...
Statistics: Posted by nay-seven — 24 Mar 2010, 18:02
]]>2010-03-24T14:31:26+01:002010-03-24T14:31:26+01:00https://brainmodular.org/forums/viewtopic.php?t=2065&p=12869#p12869It seems to be very ineresting. Good job, it seems to be a master piece.
Bravo !!!!
Statistics: Posted by cmodica — 24 Mar 2010, 14:31
]]>2010-03-24T13:08:00+01:002010-03-24T13:08:00+01:00https://brainmodular.org/forums/viewtopic.php?t=2065&p=12868#p12868I've just upload a new version of my seq in the addons page:
Statistics: Posted by ethnix73 — 22 Mar 2010, 23:08
]]>2010-03-22T22:50:55+01:002010-03-22T22:50:55+01:00https://brainmodular.org/forums/viewtopic.php?t=2065&p=12843#p12843You're right for the conductor i'll think about a good way. for the name of sub patchs i didn't find how we can do that.
Statistics: Posted by joffo78 — 22 Mar 2010, 22:50
]]>2010-03-22T22:37:22+01:002010-03-22T22:37:22+01:00https://brainmodular.org/forums/viewtopic.php?t=2065&p=12841#p12841there's no condition excepted be a gold member to add an addon and this one has his place here
about suggestions : use a pop up window for the conductor window and add a button to open it in the main interface..? cause right now if you close it ...not easy to open it again.. and maybe a good thing is to rename your sub patches , for those who discover your work and try to use it..?
Statistics: Posted by nay-seven — 22 Mar 2010, 22:37
]]>2010-03-22T22:22:49+01:002010-03-22T22:22:49+01:00https://brainmodular.org/forums/viewtopic.php?t=2065&p=12840#p12840i did my best but i'd like to do better
Statistics: Posted by joffo78 — 22 Mar 2010, 22:22
]]>2010-03-22T22:17:19+01:002010-03-22T22:17:19+01:00https://brainmodular.org/forums/viewtopic.php?t=2065&p=12839#p12839Statistics: Posted by 23fx23 — 22 Mar 2010, 22:17
]]>2010-03-22T22:03:39+01:002010-03-22T22:03:39+01:00https://brainmodular.org/forums/viewtopic.php?t=2065&p=12837#p12837I'm proud to present you my first création under Usine. It's a patch dedicaced to theatre or dance perform. you can find it in the uploader page (i don't know what are condition to put it in addons page). http://www.sensomusic.com/forums/upload ... livev5.wkp
the concept is simple. 4 players can be routed to 6 output (1 stereo 4 monos). here is the players:
you can set if a wave file will be played,stopped or nothing you can set a fixed level of each output or draw a line (with point) to modulate the level. what i'd like to do is select between line mod or step mod and optimise interface. If you have another ideas there're welcome !!! good try. Joffo
Statistics: Posted by joffo78 — 22 Mar 2010, 22:03
]]>BrainModularBrainModular Users Forum2010-03-29T13:13:11+01:00https://brainmodular.org/forums/app.php/feed/topic/20652010-03-29T13:13:11+01:002010-03-29T13:13:11+01:00https://brainmodular.org/forums/viewtopic.php?t=2065&p=13024#p13024My new version of perform seq is on the addons page. It had a lot of improvement like surrond panner and midi. have a look. bye JF
]]>2010-03-27T21:38:40+01:002010-03-27T21:38:40+01:00https://brainmodular.org/forums/viewtopic.php?t=2065&p=12991#p12991Statistics: Posted by nay-seven — 27 Mar 2010, 21:38
Bravo !!!!
