ArrayArrayArrayArray BrainModular BrainModular Users Forum 2010-03-22T18:37:57+01:00 https://brainmodular.org/forums/app.php/feed/topic/2064 2010-03-22T18:37:57+01:00 2010-03-22T18:37:57+01:00 https://brainmodular.org/forums/viewtopic.php?t=2064&p=12832#p12832 <![CDATA[Creating a clock counter to my sampler]]>
ok ,so this one should more mach you needz as its linked to position of sampler, so should reflect stop/move position, there is also the swich to choose between displaying "elapsed" or "left" time.
elapsed (swch is 0) act like this: pick sample lengh, check with his position in percent what's current time in ms,convert in s,m,h
when switch is on, it pick total lengh and subtract current playing pos.
(to make less wire between two modes in fact when on "elapsed" A-B returns 0-current position, so a negative pos, the abs is used to make it always positive). hope it helps.
Statistics: Posted by 23fx23 — 22 Mar 2010, 18:37
2010-03-22T16:46:46+01:00 2010-03-22T16:46:46+01:00 https://brainmodular.org/forums/viewtopic.php?t=2064&p=12831#p12831 <![CDATA[Creating a clock counter to my sampler]]> Statistics: Posted by joffo78 — 22 Mar 2010, 16:46
2010-03-22T02:33:36+01:00 2010-03-22T02:33:36+01:00 https://brainmodular.org/forums/viewtopic.php?t=2064&p=12826#p12826 <![CDATA[Creating a clock counter to my sampler]]>
there are several possibilities, this is one, you can make it start when you start your sampler:
to know the time that rest, instead of driving "curent" to the modules,
drive (sampler lengh out(ms) - current) (using a A-B) out to the modules.
Statistics: Posted by 23fx23 — 22 Mar 2010, 02:33
2010-03-22T02:13:32+01:00 2010-03-22T02:13:32+01:00 https://brainmodular.org/forums/viewtopic.php?t=2064&p=12825#p12825 <![CDATA[Creating a clock counter to my sampler]]> I'd like to know if it's possible to make a counter which display the time with hours minutes and second and why not the time
left before the end of a soundfile.
thanks
Statistics: Posted by joffo78 — 22 Mar 2010, 02:13
thanks
