ArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2010-03-27T18:01:22+01:00 https://brainmodular.org/forums/app.php/feed/topic/2059 2010-03-27T18:01:22+01:00 2010-03-27T18:01:22+01:00 https://brainmodular.org/forums/viewtopic.php?t=2059&p=12986#p12986 <![CDATA[Matrix XYZ]]> no direct sound, i will think about that for V3..
Statistics: Posted by 23fx23 — 27 Mar 2010, 18:01
2010-03-27T16:02:48+01:00 2010-03-27T16:02:48+01:00 https://brainmodular.org/forums/viewtopic.php?t=2059&p=12984#p12984 <![CDATA[Matrix XYZ]]>
but Matrix is there a midi controller or not we assign sounds directly
Statistics: Posted by VjRobotX — 27 Mar 2010, 16:02
2010-03-26T20:38:00+01:00 2010-03-26T20:38:00+01:00 https://brainmodular.org/forums/viewtopic.php?t=2059&p=12964#p12964 <![CDATA[Matrix XYZ]]>
the Square was a grid of cells with a complex behind system, with an ableton grid. This is effectively a much simpler little part of square features using Matrix, a module that allow to have lot of cells accessible in one module only, very conveniant. At this time matrix doesn't support colors and caption, but should in a short amout of time, that will allow me to build a new square more powerfull.
I could clean and reupload the square for V5 (well i started and ll take a bit amount of time to check that tonight),
but if your goal is to control ableton, im working on a much better system using LiveOsc (see liveOsc thread in general),
Square will then be a different addon more focused on general midi/usine applications.
But if you are a VJ as i suppose, yes square would be cooler to trig videos.
I promise i do my best to give you square/liveOsc asap, but they are "complex" patchs needing time to check...
im checking square patch to upload it tonight..
note: je parle français mais ici on parle en anglais comme le forum est international si tu galères tu eux mettre en français aussi mais jusque la je comprend ce que tu dis;) je mate si je peux corriger/reupload le "carré" ce soir ;)
Statistics: Posted by 23fx23 — 26 Mar 2010, 20:38
2010-03-26T15:51:20+01:00 2010-03-26T15:51:20+01:00 https://brainmodular.org/forums/viewtopic.php?t=2059&p=12951#p12951 <![CDATA[Matrix XYZ]]> http://fr.audiofanzine.com/sequenceur-d ... -5/forums/
and yes , the square is a monster...
Statistics: Posted by nay-seven — 26 Mar 2010, 15:51
2010-03-26T15:45:25+01:00 2010-03-26T15:45:25+01:00 https://brainmodular.org/forums/viewtopic.php?t=2059&p=12950#p12950 <![CDATA[Matrix XYZ]]>
I can not find the same thing on Matrix
et si tu parle français se serai vraiment cool, car je dois faire à chaque fois un mic mac avec le translater. Se serai plus facile pour m'exprimer.
au qu'a où
Statistics: Posted by VjRobotX — 26 Mar 2010, 15:45
2010-03-26T15:03:25+01:00 2010-03-26T15:03:25+01:00 https://brainmodular.org/forums/viewtopic.php?t=2059&p=12946#p12946 <![CDATA[Matrix XYZ]]> Statistics: Posted by VjRobotX — 26 Mar 2010, 15:03
2010-03-26T14:59:55+01:00 2010-03-26T14:59:55+01:00 https://brainmodular.org/forums/viewtopic.php?t=2059&p=12944#p12944 <![CDATA[Matrix XYZ]]> have fun..
Statistics: Posted by nay-seven — 26 Mar 2010, 14:59
2010-03-26T14:47:50+01:00 2010-03-26T14:47:50+01:00 https://brainmodular.org/forums/viewtopic.php?t=2059&p=12943#p12943 <![CDATA[Matrix XYZ]]>
merci beaucoup Nay-seven for you help
last question, Matrix is the big brother (the Square) or the same thing
Statistics: Posted by VjRobotX — 26 Mar 2010, 14:47
2010-03-26T14:40:10+01:00 2010-03-26T14:40:10+01:00 https://brainmodular.org/forums/viewtopic.php?t=2059&p=12942#p12942 <![CDATA[Matrix XYZ]]> http://www.sensomusic.com/download/
direct link
http://www.sensomusic.com/download/_PAC ... eurent.zip
Statistics: Posted by nay-seven — 26 Mar 2010, 14:40
2010-03-26T14:32:49+01:00 2010-03-26T14:32:49+01:00 https://brainmodular.org/forums/viewtopic.php?t=2059&p=12940#p12940 <![CDATA[Matrix XYZ]]>
I DO NOT KNOW ALL THE FORUM, WELL I HAVE TO FIND Additional packs FORUM BUT NO MATRIX.USR
MERCI ^_^
Statistics: Posted by VjRobotX — 26 Mar 2010, 14:32
2010-03-26T14:06:04+01:00 2010-03-26T14:06:04+01:00 https://brainmodular.org/forums/viewtopic.php?t=2059&p=12938#p12938 <![CDATA[Matrix XYZ]]> and put the 'Matrix.usr' in the folder 'Usine/Files/Modules/Interface Design/'.
Statistics: Posted by nay-seven — 26 Mar 2010, 14:06
2010-03-26T13:54:12+01:00 2010-03-26T13:54:12+01:00 https://brainmodular.org/forums/viewtopic.php?t=2059&p=12937#p12937 <![CDATA[Matrix XYZ]]> but once I open it I
say : Can't find the User Modul D: usine pro standalone 5.0moduleinterface designmatrix.usr
Once I pressed ok, but the Matrix appears square in the middle is not
Can you help me please thank you
Statistics: Posted by VjRobotX — 26 Mar 2010, 13:54
2010-03-20T06:40:02+01:00 2010-03-20T06:40:02+01:00 https://brainmodular.org/forums/viewtopic.php?t=2059&p=12763#p12763 <![CDATA[Matrix XYZ]]>
edit: ok corrected/reuploaded.
Statistics: Posted by 23fx23 — 20 Mar 2010, 06:40
2010-03-20T06:04:27+01:00 2010-03-20T06:04:27+01:00 https://brainmodular.org/forums/viewtopic.php?t=2059&p=12762#p12762 <![CDATA[Matrix XYZ]]>
not really an addon, more
A matrix a bit extended setup to set/recall X,Y, an Z (toggles status) with matrix cells. (like my prev square)
toggle/momentary mode. absolute/relative mode.
combo toggle/fade mode: like a toggle mode , except that we can set value like in fade mode when reclicing on a cell.
absolute/relative: absolute pick absolute position clicked on cell, ie higher you clic on cell higher is value (cf velocity on matrix keyboard. relative: recall previous value, and zone for setting is independant from cell size, to allow finer precision setting, even if moving outside a cell. adjustable.
pages: by default it's a 4x4 with 8 virtual pages, but in theory you can scale the matrix and choose nb of virtual page
infos inside the patch, hints.
addons/other
Statistics: Posted by 23fx23 — 20 Mar 2010, 06:04
au qu'a où
direct link
MERCI ^_^
addons/other
