ArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArray
BrainModularBrainModular Users Forum2010-03-23T11:35:01+01:00https://brainmodular.org/forums/app.php/feed/topic/20552010-03-23T11:35:01+01:002010-03-23T11:35:01+01:00https://brainmodular.org/forums/viewtopic.php?t=2055&p=12855#p12855my issues are different than yours, already using groundlift, but its in another thread so ill leave it there for now
]]>2010-03-23T09:45:11+01:002010-03-23T09:45:11+01:00https://brainmodular.org/forums/viewtopic.php?t=2055&p=12854#p12854With my simple patch above, when stressing the midi like a mad with my two pedals, the audio started slowing. I didn't imagine there was a link between MIDI activity and sound card buffer size ! I'm going to test this today to close this thread if my solution is concluding
Statistics: Posted by La Tenaille — 23 Mar 2010, 09:45
]]>2010-03-23T09:25:20+01:002010-03-23T09:25:20+01:00https://brainmodular.org/forums/viewtopic.php?t=2055&p=12853#p12853I'm using my built-in MIDI Fireface 400 interface, no spikes monitores in Win XP task manager.
Perhaps loveandelectrik your noises are caused by a ground loop. The simplest way to check this is to temporarily "cut" the ground of your laptop.
To isolate my problem I've made this patch in a new workspace :
MIDI in unpacked, sending CCs with two expression pedals to stress the midi messages.
The sampler plays a Usine demo file (lagoon). With one MIDI out, no crackes (or too few crackles to be heard). They appear when I select the MIDI wire.
The crackles become obvious with the 3rd midi out, and terribles if I select a wire. No crackles if I select the audio wire.
I've tried to cut the ground but it doesn't change anything.
... still stuck.
Statistics: Posted by La Tenaille — 23 Mar 2010, 09:25
]]>2010-03-22T23:38:27+01:002010-03-22T23:38:27+01:00https://brainmodular.org/forums/viewtopic.php?t=2055&p=12848#p12848im experiencing crackles too but for me its when scrolling around in interface browser,, cpu spikes, then causes crackle,, do you see spikes in your activity monitor/task manager when you hear the spikes? for me i see the spike causing drop out,, its definately coming from usine, checking dpc latency,, no spikes there,,
]]>2010-03-22T21:24:15+01:002010-03-22T21:24:15+01:00https://brainmodular.org/forums/viewtopic.php?t=2055&p=12835#p12835I haven't found the solution yet. I have a clue : when I select the midi wire that goes in the MIDI out (data displays on screen), the crackles increase a lot, a crackle with each event. Perhaps a ground loop ? Nobody has had this problem before ? Thanks
Statistics: Posted by La Tenaille — 22 Mar 2010, 21:24
]]>2010-03-19T15:27:00+01:002010-03-19T15:27:00+01:00https://brainmodular.org/forums/viewtopic.php?t=2055&p=12751#p12751Statistics: Posted by bsork — 19 Mar 2010, 15:27
2010-03-19T13:24:12+01:002010-03-19T13:24:12+01:00https://brainmodular.org/forums/viewtopic.php?t=2055&p=12750#p12750I'll continue my investigation tomorrow, but the fact is I have two midi wires from two create MIDI modules (one for PC, one for CC) that feed the same midi out, and when I delete the PC wire, the CC messages stop generating crackles...
Statistics: Posted by La Tenaille — 19 Mar 2010, 13:24
Haven't checked, but I think it will pass MIDI as well. However, I don't think it's of much use, as MIDI messages can be likened more to triggers from buttons rather than values from eg faders or switches. A MIDI output is populated with X number of messages per block in an array. If nothing is sent in the block, the array is empty (length =0) which can be considered as a "non-event" (aka NIL or NULL). Similarly, the button module has in fact now got an option for the off to be a NULL event - ie nothing is sent instead of the off value.
]]>2010-03-19T11:59:16+01:002010-03-19T11:59:16+01:00https://brainmodular.org/forums/viewtopic.php?t=2055&p=12748#p12748I've checked my hardware and nothing seems wrong but I have a clue : I send PC in another patch, on the same MIDI out. When I disconnect it, the crackles disapear. I'm going to join together the two patches to use only one MIDI out per channel and see what happens. Does the pass if change works on MIDI pins ? Thanks for your help.
Statistics: Posted by La Tenaille — 19 Mar 2010, 11:59
Statistics: Posted by nay-seven — 18 Mar 2010, 23:15
]]>2010-03-18T21:46:07+01:002010-03-18T21:46:07+01:00https://brainmodular.org/forums/viewtopic.php?t=2055&p=12743#p12743 Come to think of it, it might have something to do with the MIDI signals interfering with the audio - possibly in the analogue domain. If you can, you might try to switch around MIDI and audio in- and outputs ans see if that helps.
]]>2010-03-18T21:07:09+01:002010-03-18T21:07:09+01:00https://brainmodular.org/forums/viewtopic.php?t=2055&p=12740#p12740 To be simple, Usine gets my pedal board midi messages, and use them to "midi create" other messages to be sent out to my hardware (guitar modeling effect and voice harmoniser). I've made midi learns on switches and faders to match my pedalboard and use them for the values (0>127).
Statistics: Posted by La Tenaille — 18 Mar 2010, 21:07
]]>2010-03-18T19:00:33+01:002010-03-18T19:00:33+01:00https://brainmodular.org/forums/viewtopic.php?t=2055&p=12738#p12738classic way , but depending of what you want to achieve of course....?
Statistics: Posted by nay-seven — 18 Mar 2010, 19:00
]]>2010-03-18T18:21:10+01:002010-03-18T18:21:10+01:00https://brainmodular.org/forums/viewtopic.php?t=2055&p=12737#p12737I have crackles when I use my pedal board to send midi in and out of Usine. It happens only when I send audio (voice in a microphone) in another track. It becomes obvious when I use a pedal (range fader 0>127). I've checked everything : it seems it's because I've wired my MIDI IN module pin "receive out" to the "create in" pin of a CREATE MIDI module. Is it a wrong way to create MIDI messages ? Thanks
Statistics: Posted by La Tenaille — 18 Mar 2010, 18:21
]]>BrainModularBrainModular Users Forum2010-03-23T11:35:01+01:00https://brainmodular.org/forums/app.php/feed/topic/20552010-03-23T11:35:01+01:002010-03-23T11:35:01+01:00https://brainmodular.org/forums/viewtopic.php?t=2055&p=12855#p12855my issues are different than yours, already using groundlift, but its in another thread so ill leave it there for now
... still stuck.
]]>2010-03-19T13:24:12+01:002010-03-19T13:24:12+01:00https://brainmodular.org/forums/viewtopic.php?t=2055&p=12750#p12750I'll continue my investigation tomorrow, but the fact is I have two midi wires from two create MIDI modules (one for PC, one for CC) that feed the same midi out, and when I delete the PC wire, the CC messages stop generating crackles...
