ArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArray
BrainModularBrainModular Users Forum2010-03-18T09:27:34+01:00https://brainmodular.org/forums/app.php/feed/topic/20492010-03-18T09:27:34+01:002010-03-18T09:27:34+01:00https://brainmodular.org/forums/viewtopic.php?t=2049&p=12719#p12719 Whaou, A lot of good things in this update, thanks very much for this news.
]]>2010-03-18T09:02:34+01:002010-03-18T09:02:34+01:00https://brainmodular.org/forums/viewtopic.php?t=2049&p=12718#p12718 video tracker runs perfectly...thanks!
Statistics: Posted by iococoi — 18 Mar 2010, 09:02
Statistics: Posted by gurulogic — 18 Mar 2010, 03:35
]]>2010-03-17T22:23:58+01:002010-03-17T22:23:58+01:00https://brainmodular.org/forums/viewtopic.php?t=2049&p=12704#p12704Statistics: Posted by grego mondo — 17 Mar 2010, 22:23
2010-03-17T22:12:21+01:002010-03-17T22:12:21+01:00https://brainmodular.org/forums/viewtopic.php?t=2049&p=12702#p12702Statistics: Posted by artificial — 17 Mar 2010, 22:12
]]>2010-03-17T22:05:31+01:002010-03-17T22:05:31+01:00https://brainmodular.org/forums/viewtopic.php?t=2049&p=12701#p12701
Statistics: Posted by La Tenaille — 17 Mar 2010, 21:15
]]>2010-03-17T20:33:58+01:002010-03-17T20:33:58+01:00https://brainmodular.org/forums/viewtopic.php?t=2049&p=12686#p12686 As usual
Statistics: Posted by ethnix73 — 17 Mar 2010, 20:33
]]>2010-03-17T20:20:44+01:002010-03-17T20:20:44+01:00https://brainmodular.org/forums/viewtopic.php?t=2049&p=12684#p12684Statistics: Posted by 23fx23 — 17 Mar 2010, 20:20
]]>2010-03-17T20:01:53+01:002010-03-17T20:01:53+01:00https://brainmodular.org/forums/viewtopic.php?t=2049&p=12682#p12682version 5.12[/large] This version fixes most of reported bugs and implement new important features. Can be considered as the first "service pack" of the V5 and because of all the changes It is still a beta version. Download highly recommended.
[large]improvements[/large] - You can now send several audio flow in the same Audio Bus. - New Analysis/Partial Tracker Module can replace the zero crossing module in the AudioToMidi Patch. - new perfect synchro option in the setup and globally a better synchro in the sampler. - the Audio volume contains a new “Mute” inlet - better resampling quality in sampler especially when the pitch is smaller than -2 octaves - various GUI details in the sequencer - new "unSelect all" menu in the sequencer. - You can drop VST's directly in the sequencer - improvements on Button module, which now has a max/min value - New internal help window. - the On Activation module works when the position reaches the beginning of the patch in the sequencer.
[large]fixed bugs[/large] - almost all cameras incompatibility issues in the Video Detect Module DX - the sequencer insert patch control panel is always invisible - various VST denormalization bugs - no more flicker effect in the Video Detect module - graphic Freeze issues in the sequencer. - the mouseMove now works in Sequenced Switches module - various bitmap chaining issues - the 'find in patch' command doesn't work in the Free version - the last character is truncated in osc tag 's' - new Midi-Arpeggiator script - various reported bugs
]]>BrainModularBrainModular Users Forum2010-03-18T09:27:34+01:00https://brainmodular.org/forums/app.php/feed/topic/20492010-03-18T09:27:34+01:002010-03-18T09:27:34+01:00https://brainmodular.org/forums/viewtopic.php?t=2049&p=12719#p12719 Whaou, A lot of good things in this update, thanks very much for this news.
]]>2010-03-17T22:12:21+01:002010-03-17T22:12:21+01:00https://brainmodular.org/forums/viewtopic.php?t=2049&p=12702#p12702Statistics: Posted by artificial — 17 Mar 2010, 22:12
