ArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2010-03-20T21:54:59+01:00 https://brainmodular.org/forums/app.php/feed/topic/2020 2010-03-20T21:54:59+01:00 2010-03-20T21:54:59+01:00 https://brainmodular.org/forums/viewtopic.php?t=2020&p=12783#p12783 <![CDATA[Selecting in a combo box]]>
But thanks for the support. I need to have patience, and keep remembering it is one man building this software!
cheers,
-e
Statistics: Posted by woodslanding — 20 Mar 2010, 21:54
2010-03-18T15:44:18+01:00 2010-03-18T15:44:18+01:00 https://brainmodular.org/forums/viewtopic.php?t=2020&p=12734#p12734 <![CDATA[Selecting in a combo box]]> I agree with you, understand your frustration, just was speaking about the 'text form' of requesting, be cool and there is 99,99 percent chance a solution to come up soon or later.
by waiting, im sure we can make a good low cpu workaround based on your patch or list box teck.
on your patch, im sure if Iml could wire once to cell caption so they update then delete the wires Cpu would be much lower.
same in mine, once each list box has it's own comma, deleting wire the cpu should be <0.3 percent, that seems ok for a waiting workaround.
Statistics: Posted by 23fx23 — 18 Mar 2010, 15:44
2010-03-18T11:09:01+01:00 2010-03-18T11:09:01+01:00 https://brainmodular.org/forums/viewtopic.php?t=2020&p=12724#p12724 <![CDATA[Selecting in a combo box]]>
But I'm not that much a fan of it on the iphone, actually. And I don't need to double-click on it either.
Well, thanks for the listbox kludges. They look to be much more processor efficient than mondo combo, although not quite as elegant.
Maybe I'll put them in, and see if I can save a few % on my cpu.....
cheers,
-e
Statistics: Posted by woodslanding — 18 Mar 2010, 11:09
2010-03-17T03:23:10+01:00 2010-03-17T03:23:10+01:00 https://brainmodular.org/forums/viewtopic.php?t=2020&p=12656#p12656 <![CDATA[Selecting in a combo box]]> VERY simplified - I'm happy to use a scroller :)
Statistics: Posted by Clearscreen — 17 Mar 2010, 03:23
2010-03-17T02:39:01+01:00 2010-03-17T02:39:01+01:00 https://brainmodular.org/forums/viewtopic.php?t=2020&p=12655#p12655 <![CDATA[Selecting in a combo box]]>
it could be improved using iml to wire/unwire once split comma is done , then it should be very low cpu..
Statistics: Posted by 23fx23 — 17 Mar 2010, 02:39
2010-03-17T02:32:09+01:00 2010-03-17T02:32:09+01:00 https://brainmodular.org/forums/viewtopic.php?t=2020&p=12653#p12653 <![CDATA[Selecting in a combo box]]>
I ve made a different aproach workaround patch, allowing to choose nb of item to be displayed in Y if we set item size the good way.
http://www.sensomusic.com/forums/upload ... %20box.pat
Thanks for sharing 23fx23, I had a couple of issues with this so I've modified it a little to suit meself if that's ok...
Simple ComboBox
Statistics: Posted by Clearscreen — 17 Mar 2010, 02:32
2010-03-17T00:24:10+01:00 2010-03-17T00:24:10+01:00 https://brainmodular.org/forums/viewtopic.php?t=2020&p=12652#p12652 <![CDATA[Selecting in a combo box]]> Statistics: Posted by Clearscreen — 17 Mar 2010, 00:24
2010-03-16T06:30:51+01:00 2010-03-16T06:30:51+01:00 https://brainmodular.org/forums/viewtopic.php?t=2020&p=12638#p12638 <![CDATA[Selecting in a combo box]]> http://www.sensomusic.com/forums/upload ... %20box.pat
Statistics: Posted by 23fx23 — 16 Mar 2010, 06:30
2010-03-16T02:05:25+01:00 2010-03-16T02:05:25+01:00 https://brainmodular.org/forums/viewtopic.php?t=2020&p=12636#p12636 <![CDATA[Selecting in a combo box]]>
no to be honest i also in some case would prefer a single clic action item.
but see positive inertia is cool.
it means you can scroll like the iphone (not to be fashion, i don't have one, but best visual example, the device is fast and responsive in scrolling, thanks to inertia), the fastest is your move, the longest time the list keep on scrolling even if you release your finger,(i can't beleive you didn't noticed it on V5 video or in ib!) . personally i find it's a cool/best way to have a fast access while keeping a low screen size, but this implies by nature it shouldn't select on a clic to avoid accidents, on the other side you can scroll and clic with the iphone,but it must be a more complex system
probably there is something that check if click is very short, it acts as a clic on release, if longer acts for inertia scrolling, as inertia effect implies a certain amount of time to check velocity, or if velocity is lower than a thresohld it's considered as a clic?
well i can imagine it's far more complex in programming than it seems on patching;)
Statistics: Posted by 23fx23 — 16 Mar 2010, 02:05
2010-03-16T01:44:45+01:00 2010-03-16T01:44:45+01:00 https://brainmodular.org/forums/viewtopic.php?t=2020&p=12635#p12635 <![CDATA[Selecting in a combo box]]>
Can somebody explain what inertia is or does??
Hey Senso, can you explain what you mean by inertia?
Statistics: Posted by Clearscreen — 16 Mar 2010, 01:44
2010-03-15T12:52:15+01:00 2010-03-15T12:52:15+01:00 https://brainmodular.org/forums/viewtopic.php?t=2020&p=12616#p12616 <![CDATA[Selecting in a combo box]]>
Like all all the non-usine combo boxes in the world.
all combo box of the word don't have inertia...
Statistics: Posted by senso — 15 Mar 2010, 12:52
2010-03-15T11:25:28+01:00 2010-03-15T11:25:28+01:00 https://brainmodular.org/forums/viewtopic.php?t=2020&p=12610#p12610 <![CDATA[Selecting in a combo box]]>
Statistics: Posted by Clearscreen — 15 Mar 2010, 11:25
2010-03-15T09:17:08+01:00 2010-03-15T09:17:08+01:00 https://brainmodular.org/forums/viewtopic.php?t=2020&p=12601#p12601 <![CDATA[Selecting in a combo box]]>
I don't want to reduce the number of items--I have just the number I want. I just want to be able to select an item with a single-click. Like all all the non-usine combo boxes in the world. Like V4.
I'm uploading my mondo combo to the addons. It works like I'd like comboboxes to work, but unfortunately uses 10000% more CPU than a combobox.
Statistics: Posted by woodslanding — 15 Mar 2010, 09:17
2010-03-14T13:39:59+01:00 2010-03-14T13:39:59+01:00 https://brainmodular.org/forums/viewtopic.php?t=2020&p=12589#p12589 <![CDATA[Selecting in a combo box]]> Statistics: Posted by La Tenaille — 14 Mar 2010, 13:39
2010-03-14T09:30:29+01:00 2010-03-14T09:30:29+01:00 https://brainmodular.org/forums/viewtopic.php?t=2020&p=12587#p12587 <![CDATA[Selecting in a combo box]]> Statistics: Posted by senso — 14 Mar 2010, 09:30
2010-03-13T23:38:12+01:00 2010-03-13T23:38:12+01:00 https://brainmodular.org/forums/viewtopic.php?t=2020&p=12583#p12583 <![CDATA[Selecting in a combo box]]> Statistics: Posted by Clearscreen — 13 Mar 2010, 23:38
2010-03-13T10:04:10+01:00 2010-03-13T10:04:10+01:00 https://brainmodular.org/forums/viewtopic.php?t=2020&p=12571#p12571 <![CDATA[Selecting in a combo box]]> Image
Statistics: Posted by nay-seven — 13 Mar 2010, 10:04
2010-03-12T23:46:37+01:00 2010-03-12T23:46:37+01:00 https://brainmodular.org/forums/viewtopic.php?t=2020&p=12567#p12567 <![CDATA[Selecting in a combo box]]>
I imagine that you can be disappointed by the V5 comboBox style.
But do you have noticed that you can reduce the number of displayed items by using the '=' character in the list?
like:
A=0
B=24
C=34
D=231
Gave this a try and I can't work out the difference - can you explain this a bit more Senso? Hopefully we can work out a single click solution as well... :( is there any hope?
Statistics: Posted by Clearscreen — 12 Mar 2010, 23:46
2010-03-12T10:10:51+01:00 2010-03-12T10:10:51+01:00 https://brainmodular.org/forums/viewtopic.php?t=2020&p=12531#p12531 <![CDATA[Selecting in a combo box]]> But do you have noticed that you can reduce the number of displayed items by using the '=' character in the list?
like:
A=0
B=24
C=34
D=231
Statistics: Posted by senso — 12 Mar 2010, 10:10
2010-03-12T06:39:58+01:00 2010-03-12T06:39:58+01:00 https://brainmodular.org/forums/viewtopic.php?t=2020&p=12529#p12529 <![CDATA[Selecting in a combo box]]>
Statistics: Posted by woodslanding — 12 Mar 2010, 06:39
2010-03-12T06:39:33+01:00 2010-03-12T06:39:33+01:00 https://brainmodular.org/forums/viewtopic.php?t=2020&p=12528#p12528 <![CDATA[Selecting in a combo box]]>
I think *some* sort of solution is essential.
2010-03-12T00:36:45+01:00 2010-03-12T00:36:45+01:00 https://brainmodular.org/forums/viewtopic.php?t=2020&p=12525#p12525 <![CDATA[Selecting in a combo box]]> http://sensomusic.com/forums/viewtopic.php?id=1503[/html]?
I'd be happy for it to only stay open as long as the mouse was in the selection box but have instant selection change? That probably wouldn't please everyone though would it....
Is there even a possibility for a completely separate more touch friendly combo box style module? user module maybe? (he says clutching at straws...:lol:)
Statistics: Posted by Clearscreen — 12 Mar 2010, 00:36
2010-03-11T08:23:13+01:00 2010-03-11T08:23:13+01:00 https://brainmodular.org/forums/viewtopic.php?t=2020&p=12513#p12513 <![CDATA[Selecting in a combo box]]> Statistics: Posted by senso — 11 Mar 2010, 08:23
2010-03-11T00:30:31+01:00 2010-03-11T00:30:31+01:00 https://brainmodular.org/forums/viewtopic.php?t=2020&p=12509#p12509 <![CDATA[Selecting in a combo box]]>
Statistics: Posted by Clearscreen — 11 Mar 2010, 00:30
2010-03-10T09:16:05+01:00 2010-03-10T09:16:05+01:00 https://brainmodular.org/forums/viewtopic.php?t=2020&p=12483#p12483 <![CDATA[Selecting in a combo box]]> Statistics: Posted by senso — 10 Mar 2010, 09:16
cheers,
-e
cheers,
-e
Simple ComboBox
like:
A=0
B=24
C=34
D=231
like:
A=0
B=24
C=34
D=231
