ArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2010-09-18T08:36:51+01:00 https://brainmodular.org/forums/app.php/feed/topic/2017 2010-09-18T08:36:51+01:00 2010-09-18T08:36:51+01:00 https://brainmodular.org/forums/viewtopic.php?t=2017&p=15842#p15842 <![CDATA[Surround Pack official thread]]> I introduce myself in the discussion.
the actual pack is great and I use it a lot.
From my point of view, some simple objects are missing:
- a random surround panner
- a trajectory panner, which mixes the DrawTrajectory user module and a simple panner
- the possibility to record mouse movements and play them in loop
- some basic audio processing, like N x limiter, N x compressor, N x Delay, etc...
As you can see, only simple things...
Statistics: Posted by senso — 18 Sep 2010, 09:36
2010-09-16T23:00:50+01:00 2010-09-16T23:00:50+01:00 https://brainmodular.org/forums/viewtopic.php?t=2017&p=15814#p15814 <![CDATA[Surround Pack official thread]]>
I'm not looking to slow some samples but some parameters of an auto generative granular synth I'm working on, so i need a kind of natural auto morphing , so friction is cool but this stop the movement too quickly for me...
thanks, and don't worry they're some cool trees and fresh air in the science academy garden...
Statistics: Posted by nay-seven — 17 Sep 2010, 00:00
2010-09-16T22:18:09+01:00 2010-09-16T22:18:09+01:00 https://brainmodular.org/forums/viewtopic.php?t=2017&p=15813#p15813 <![CDATA[Surround Pack official thread]]>
First, this is not "my script" but the utilization of "Senso script" Me too I'm little lost in this procedure of friction and attraction.
So, I don't play the guy just outing of Science academy because I'm not enter in the Science academy ;-)
But,
A direct response is to replace this scrip by another "Senso script" the Pool Ball. This one is very close from the friction and attraction script and have a Speed parameter.
I think i understand the question behind. You want to reduce the speed during the sample play ? Another response is to increase the friction, but in this case the race of the object is reduced.
However, if you use the friction briefly, to give a sort of stop-speed will be reduced. Given that the parameters are related to each other by physical laws I have no other solutions to give you the time without rethinking the script. I't a way of play with them.
Let me think about that...
Statistics: Posted by multiphone — 16 Sep 2010, 23:18
2010-09-16T13:26:20+01:00 2010-09-16T13:26:20+01:00 https://brainmodular.org/forums/viewtopic.php?t=2017&p=15801#p15801 <![CDATA[Surround Pack official thread]]> very surprised I'm the first here, this pack is really awesome and interesting to study..
congrats and thanks
now my question : i want to use some of your sub-patches ( Free Attraction 8+random8, 10 and his pass if change , extract from SPAT Schuffler AREA 4) to use them to send movement to parameters , ok works fine
but , i want to slow down all this and to move longer..
about time , ok , i've found the H time , so no problem
but the speed ..?
I've try to follow your script..mm no way ,
i understand when you talk about force who have influence on speed , but don't know how to proceed to change that
can I've a little help on this..?
Statistics: Posted by nay-seven — 16 Sep 2010, 14:26
2010-03-09T11:21:27+01:00 2010-03-09T11:21:27+01:00 https://brainmodular.org/forums/viewtopic.php?t=2017&p=12456#p12456 <![CDATA[Surround Pack official thread]]>
like the other member of the comunity says...
If you need help or if du you have a new ideas about surround utility all your post are welcome.
Best
Statistics: Posted by multiphone — 09 Mar 2010, 11:21
But,
congrats and thanks
but the speed ..?
Best
