- new Option 'Conductor isolate' in patches and sub-patches. To isolate parameters from a conductor recall.
That ... is a fucking good new! Simply magic for my use. Thanks a lot, christmas never stops
Statistics: Posted by La Tenaille — 09 Mar 2010, 21:50
]]>2010-03-08T15:06:36+01:002010-03-08T15:06:36+01:00https://brainmodular.org/forums/viewtopic.php?t=1998&p=12410#p12410Statistics: Posted by artificial — 08 Mar 2010, 15:06
2010-03-08T02:46:18+01:002010-03-08T02:46:18+01:00https://brainmodular.org/forums/viewtopic.php?t=1998&p=12402#p12402Statistics: Posted by grego mondo — 08 Mar 2010, 02:46
]]>2010-03-07T11:45:09+01:002010-03-07T11:45:09+01:00https://brainmodular.org/forums/viewtopic.php?t=1998&p=12379#p12379Statistics: Posted by gurulogic — 07 Mar 2010, 11:45
]]>2010-03-07T11:44:15+01:002010-03-07T11:44:15+01:00https://brainmodular.org/forums/viewtopic.php?t=1998&p=12378#p12378
Statistics: Posted by artificial — 07 Mar 2010, 11:44
]]>2010-03-07T00:00:53+01:002010-03-07T00:00:53+01:00https://brainmodular.org/forums/viewtopic.php?t=1998&p=12366#p12366Statistics: Posted by ethnix73 — 07 Mar 2010, 00:00
]]>2010-03-06T22:08:22+01:002010-03-06T22:08:22+01:00https://brainmodular.org/forums/viewtopic.php?t=1998&p=12353#p12353Statistics: Posted by 23fx23 — 06 Mar 2010, 22:08
]]>2010-03-06T18:24:12+01:002010-03-06T18:24:12+01:00https://brainmodular.org/forums/viewtopic.php?t=1998&p=12348#p12348Statistics: Posted by Floego — 06 Mar 2010, 18:24
]]>2010-03-06T17:57:59+01:002010-03-06T17:57:59+01:00https://brainmodular.org/forums/viewtopic.php?t=1998&p=12347#p12347 Just backup the following files
]]>2010-03-06T17:51:11+01:002010-03-06T17:51:11+01:00https://brainmodular.org/forums/viewtopic.php?t=1998&p=12346#p12346 Thanks for this new version!.
I need help on upgrading from v5.08 to v5.10. This new version is a lot bigger in size than the previous one, so I would like to know if I need to upgrade every folder inside usine standalone or not?. What are the upgradable modules?. Do I need to backup something inside the usine folder prior to upgrading?.
]]>2010-03-06T17:30:16+01:002010-03-06T17:30:16+01:00https://brainmodular.org/forums/viewtopic.php?t=1998&p=12345#p12345[5.10] Important improvements especially a new Video Tracker module more efficient and an off-line help system. The off-line help is included in the package but can be easily upgraded independently of the main program.
improvements - new Video Tracker Module using DirectShow layer. More efficient. - color inlets have now a different color - 'OFF-line' wiki/help system - new Option 'Conductor isolate' in patches and sub-patches. To isolate parameters from a conductor recall.
fixed bugs - lines, steps, switches and curve modules give an error and won't load when choosing 128 faders - the position of the ball in XY module is not stored in the conductor - logical operators now work with array's - preset Isolate enabled for a sub-patches does not save - the aux input of the additional Input module doesn't work - few other details
]]>2010-03-08T02:46:18+01:002010-03-08T02:46:18+01:00https://brainmodular.org/forums/viewtopic.php?t=1998&p=12402#p12402Statistics: Posted by grego mondo — 08 Mar 2010, 02:46
