ArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2012-01-24T16:26:28+01:00 https://brainmodular.org/forums/app.php/feed/topic/1995 2012-01-24T16:26:28+01:00 2012-01-24T16:26:28+01:00 https://brainmodular.org/forums/viewtopic.php?t=1995&p=22414#p22414 <![CDATA[Matrix Pack official thread]]>
Statistics: Posted by artificial — 24 Jan 2012, 16:26
2012-01-24T11:28:08+01:00 2012-01-24T11:28:08+01:00 https://brainmodular.org/forums/viewtopic.php?t=1995&p=22411#p22411 <![CDATA[Matrix Pack official thread]]> Download
Statistics: Posted by nay-seven — 24 Jan 2012, 11:28
2012-01-24T11:11:17+01:00 2012-01-24T11:11:17+01:00 https://brainmodular.org/forums/viewtopic.php?t=1995&p=22410#p22410 <![CDATA[Matrix Pack official thread]]>
for a 4*4 you can achieve that by module
but mixing that with the exclu patch is tricky, because your click infos aren't flipped...
here is a try :
but the exclu is valid only by clicking on the left matrix, and the right one is just graphic infos result
hope it help
Statistics: Posted by martignasse — 24 Jan 2012, 11:11
2012-01-24T10:29:04+01:00 2012-01-24T10:29:04+01:00 https://brainmodular.org/forums/viewtopic.php?t=1995&p=22409#p22409 <![CDATA[Matrix Pack official thread]]>
well it would just need the graphical representation to be flipped...
i got a 4x4 matrix and i managed to get the result by using 4 "get row" modules ... so far this worked great, but I also need "exculsive mode (cells)" to work with the 4 "get row" modules! until now, i was not able to get it working rightly...
i'm going to have a look at the swap array module, thanks for the suggestion! :)
Statistics: Posted by artificial — 24 Jan 2012, 10:29
2012-01-24T08:51:43+01:00 2012-01-24T08:51:43+01:00 https://brainmodular.org/forums/viewtopic.php?t=1995&p=22408#p22408 <![CDATA[Matrix Pack official thread]]>
unfortunatly, there is no easy way to achieve that...
script is your friend for this type of task.
is it only the graphical representation you want flipped or the array data too ?
[edit] the swap array module turn it from 180 deg, making the 'new' 0 index in down right cell
Statistics: Posted by martignasse — 24 Jan 2012, 08:51
2012-01-23T23:05:54+01:00 2012-01-23T23:05:54+01:00 https://brainmodular.org/forums/viewtopic.php?t=1995&p=22407#p22407 <![CDATA[Matrix Pack official thread]]>
just a short question: is it possible to flip the order of the rows? this way index 0 would be the bottom left cell of the grid...
thanks in advance! :)
Statistics: Posted by artificial — 23 Jan 2012, 23:05
2012-01-23T21:44:00+01:00 2012-01-23T21:44:00+01:00 https://brainmodular.org/forums/viewtopic.php?t=1995&p=22406#p22406 <![CDATA[Matrix Pack official thread]]> that's cool
Statistics: Posted by 23fx23 — 23 Jan 2012, 21:44
2012-01-23T20:55:36+01:00 2012-01-23T20:55:36+01:00 https://brainmodular.org/forums/viewtopic.php?t=1995&p=22405#p22405 <![CDATA[Matrix Pack official thread]]>
i noticed a small thing: the reset value doesn't seem effective. here i can enter 1 or 0, nothing will change when pressing reset.
yop, good catch :)
it's a regression bug :rolleyes:
will be fixed in the next release
thanks
Statistics: Posted by martignasse — 23 Jan 2012, 20:55
2012-01-23T19:43:37+01:00 2012-01-23T19:43:37+01:00 https://brainmodular.org/forums/viewtopic.php?t=1995&p=22404#p22404 <![CDATA[Matrix Pack official thread]]> Statistics: Posted by 23fx23 — 23 Jan 2012, 19:43
2011-06-18T14:42:40+01:00 2011-06-18T14:42:40+01:00 https://brainmodular.org/forums/viewtopic.php?t=1995&p=19658#p19658 <![CDATA[Matrix Pack official thread]]> I ve another problem too.
when i put a patch with a matrix on the time line of the sequencer it doesn't memorize the contain of the cells.
could you have a look on that ?
thank
Statistics: Posted by joffo78 — 18 Jun 2011, 15:42
2011-06-17T13:11:01+01:00 2011-06-17T13:11:01+01:00 https://brainmodular.org/forums/viewtopic.php?t=1995&p=19651#p19651 <![CDATA[Matrix Pack official thread]]>
so i'll see that with him, hope i'll can achieve that
Statistics: Posted by martignasse — 17 Jun 2011, 14:11
2011-06-16T23:23:44+01:00 2011-06-16T23:23:44+01:00 https://brainmodular.org/forums/viewtopic.php?t=1995&p=19647#p19647 <![CDATA[Matrix Pack official thread]]> Statistics: Posted by joffo78 — 17 Jun 2011, 00:23
2011-06-16T09:55:05+01:00 2011-06-16T09:55:05+01:00 https://brainmodular.org/forums/viewtopic.php?t=1995&p=19641#p19641 <![CDATA[Matrix Pack official thread]]>
what do you mean by
Senso did it in the next version with xy pad
is this behaviour (fade time on the XYpad) exist in the 5.50.58 or is it for the next version ?
Statistics: Posted by martignasse — 16 Jun 2011, 10:55
2011-06-15T20:42:23+01:00 2011-06-15T20:42:23+01:00 https://brainmodular.org/forums/viewtopic.php?t=1995&p=19637#p19637 <![CDATA[Matrix Pack official thread]]>
i cant answer for now, i have things to check before.
i'll feedback soon.
Statistics: Posted by martignasse — 15 Jun 2011, 21:42
2011-06-14T07:30:04+01:00 2011-06-14T07:30:04+01:00 https://brainmodular.org/forums/viewtopic.php?t=1995&p=19615#p19615 <![CDATA[Matrix Pack official thread]]> i wonder if t's possible to have possibility of memorize matrix with conductor with time fade.
Senso did it in the next version with xy pad and it would be fantastic to do the same with matrix .
Statistics: Posted by joffo78 — 14 Jun 2011, 08:30
2011-03-19T02:24:01+01:00 2011-03-19T02:24:01+01:00 https://brainmodular.org/forums/viewtopic.php?t=1995&p=18727#p18727 <![CDATA[Matrix Pack official thread]]>
oups, long time ago :
ethnix73 wrote:
I don't know if it's script or matrix module related, but the exclu mode is not compatible with a preset manager martignasse....
yep, i know, the problem is at script level. as it is based on the last clicked cell, it's not working very well with the data provided by the preset manager.
not easy to solve, maybe by implementing these mode internally in the module.
It would be really great!
Statistics: Posted by ethnix73 — 19 Mar 2011, 02:24
2011-03-15T23:45:14+01:00 2011-03-15T23:45:14+01:00 https://brainmodular.org/forums/viewtopic.php?t=1995&p=18687#p18687 <![CDATA[Matrix Pack official thread]]> still interested by any updates ;) cheers martin
Statistics: Posted by 23fx23 — 15 Mar 2011, 23:45
2011-03-15T23:39:30+01:00 2011-03-15T23:39:30+01:00 https://brainmodular.org/forums/viewtopic.php?t=1995&p=18684#p18684 <![CDATA[Matrix Pack official thread]]>
any news on the perf/ multitouch update ;) ?
well, it's coming....slowly as i'm busy with other things too. but it's coming
Statistics: Posted by martignasse — 15 Mar 2011, 23:39
2011-03-15T23:36:00+01:00 2011-03-15T23:36:00+01:00 https://brainmodular.org/forums/viewtopic.php?t=1995&p=18683#p18683 <![CDATA[Matrix Pack official thread]]>
i know for the shift function, but on a touch screen .....hmm
why can't you create a layout value? Then could be adjustable by the user?
yep, simple like that :)
it's on my todo list now
Statistics: Posted by martignasse — 15 Mar 2011, 23:36
2011-03-15T22:47:50+01:00 2011-03-15T22:47:50+01:00 https://brainmodular.org/forums/viewtopic.php?t=1995&p=18681#p18681 <![CDATA[Matrix Pack official thread]]>
this constant isn't exposed to the user, thus not modifiable, but you have a shit mode where you can multiply it from 1 to 10 (in edit layout) , so, up to 500 pixel.
Statistics: Posted by senso — 15 Mar 2011, 22:47
2011-03-15T22:29:21+01:00 2011-03-15T22:29:21+01:00 https://brainmodular.org/forums/viewtopic.php?t=1995&p=18677#p18677 <![CDATA[Matrix Pack official thread]]> i know for the shift function, but on a touch screen .....:/
Statistics: Posted by nay-seven — 15 Mar 2011, 22:29
2011-03-15T22:17:27+01:00 2011-03-15T22:17:27+01:00 https://brainmodular.org/forums/viewtopic.php?t=1995&p=18675#p18675 <![CDATA[Matrix Pack official thread]]> ?
Statistics: Posted by 23fx23 — 15 Mar 2011, 22:17
2011-03-15T20:09:47+01:00 2011-03-15T20:09:47+01:00 https://brainmodular.org/forums/viewtopic.php?t=1995&p=18671#p18671 <![CDATA[Matrix Pack official thread]]> Statistics: Posted by martignasse — 15 Mar 2011, 20:09
2011-03-15T19:43:39+01:00 2011-03-15T19:43:39+01:00 https://brainmodular.org/forums/viewtopic.php?t=1995&p=18668#p18668 <![CDATA[Matrix Pack official thread]]> martignasse.
Thank you for your answer but i afraid it's a little bit to complicated for me (you patch examples are very complex).
May i ask you some questions in french forum ?
thanks
jof
Statistics: Posted by joffo78 — 15 Mar 2011, 19:43
2011-03-15T17:04:18+01:00 2011-03-15T17:04:18+01:00 https://brainmodular.org/forums/viewtopic.php?t=1995&p=18662#p18662 <![CDATA[Matrix Pack official thread]]>
_is there a way to add precision to the array values( here the last array to dispatch values can't reflect the precision chosen in the options)
well, absolutely not possible.
precision(nb of decimal digit) in usine is only a graphic thing. behind, values are always plain float.
the matrix and the array module (like you noticed) always deal with plain float values.
but maybe you want some sort of snapping, witch is different.
_it's seems that the precision ( this time when you change the value ) is not the same on all the height of the cells
in fader mode, the drag to change a cell value is a linear function, but not based on the cell height, it's a constant of 50. that is, 50 pixel to go from min value to max value.
Statistics: Posted by martignasse — 15 Mar 2011, 17:04
here is a try :
hope it help
yop, good catch :)
thanks
thank
what do you mean by
i'll feedback soon.
thanks
jof
