Statistics: Posted by Volumetric — 03 Jul 2011, 14:02
]]>2011-07-03T11:22:51+01:002011-07-03T11:22:51+01:00https://brainmodular.org/forums/viewtopic.php?t=1994&p=19874#p19874they have moved to the addon section... you can download them directly from Usine browser now;)
Statistics: Posted by nay-seven — 03 Jul 2011, 12:22
]]>2011-07-03T10:39:57+01:002011-07-03T10:39:57+01:00https://brainmodular.org/forums/viewtopic.php?t=1994&p=19872#p19872Statistics: Posted by Volumetric — 03 Jul 2011, 11:39
]]>2010-03-09T11:14:19+01:002010-03-09T11:14:19+01:00https://brainmodular.org/forums/viewtopic.php?t=1994&p=12455#p12455 Yes i'm sure that few little patchs are a door for spacial démocratization and experimentation in Usine.
I'm really happy if you enjoy it.
This is just a BEGINNINGS !
Best.
Statistics: Posted by multiphone — 09 Mar 2010, 11:14
]]>2010-03-09T01:33:30+01:002010-03-09T01:33:30+01:00https://brainmodular.org/forums/viewtopic.php?t=1994&p=12435#p12435First I need longer cables for my speakers and some way to raise them all off the ground (just a little sound system. Only 8x 1000 watt subwoofers and 6x 1600 watt tops ) And I have to replace the amps that were stolen...
Statistics: Posted by gurulogic — 09 Mar 2010, 01:33
Have to give a special thanks to this pack - looks like I'll be producing a 20 speaker installation for someone later in the year and this will be perfect for it!
Statistics: Posted by Clearscreen — 09 Mar 2010, 00:46
]]>2010-03-08T08:50:51+01:002010-03-08T08:50:51+01:00https://brainmodular.org/forums/viewtopic.php?t=1994&p=12408#p12408 Yes, i'm happy for the commubity and all the other user of Usine.
Best
Statistics: Posted by multiphone — 08 Mar 2010, 08:50
]]>2010-03-06T23:38:22+01:002010-03-06T23:38:22+01:00https://brainmodular.org/forums/viewtopic.php?t=1994&p=12362#p12362huge work guys !! many new white nights !
Statistics: Posted by nay-seven — 06 Mar 2010, 23:38
]]>2010-03-06T22:31:31+01:002010-03-06T22:31:31+01:00https://brainmodular.org/forums/viewtopic.php?t=1994&p=12356#p12356Statistics: Posted by 23fx23 — 06 Mar 2010, 22:31
]]>2010-03-06T12:05:46+01:002010-03-06T12:05:46+01:00https://brainmodular.org/forums/viewtopic.php?t=1994&p=12335#p12335 Matrix Pack by Martin Fleurent Contains a new matrix user module totally integrated in Usine. » more info
MIDI Utilities Pack by bSork The ultimate Midi manipulation pack. » more info
Surround Pack by Hervé Birolini All you need to create surround projects. » more info
Thanks to all the contributors: Martin Fleurent, bSork, Hervé Birolini.
Best.
Best
