and also the fact to have each vsti / wave file on separate tracks let you add effects and work in rack mode if you want without changing anything in the first "master " patch..?
Yes, it's true...i rarely use the rack mode.
And for the subpatch "ramp", i realize that i've never have a look in the audio/crossfaders patch...Thanks to get me in, and thanks to olivier.
Statistics: Posted by ethnix73 — 03 Mar 2010, 13:02
]]>2010-03-03T12:57:51+01:002010-03-03T12:57:51+01:00https://brainmodular.org/forums/viewtopic.php?t=1976&p=12213#p12213Statistics: Posted by 23fx23 — 03 Mar 2010, 12:57
2010-03-03T12:52:44+01:002010-03-03T12:52:44+01:00https://brainmodular.org/forums/viewtopic.php?t=1976&p=12211#p12211This ramp subpatch is just an adaptation of the selector from audio/crossfaders tab of Usine , not my work..
about the workspace choice , i understand your idea but this addon is at first a way to help mondombe to use his fcb and enter the Usine world I'm in contact with him by e-mail and i suppose this will be easier for him to have a ready made workspace..
Statistics: Posted by nay-seven — 03 Mar 2010, 12:52
]]>2010-03-03T12:24:09+01:002010-03-03T12:24:09+01:00https://brainmodular.org/forums/viewtopic.php?t=1976&p=12208#p12208 Layout is sweet and great work for the wiki page.
Great subpatch "ramp" for the the two samplers...
P.S: Just a little question: why do you choose the workspace format instead of patch? Couldn't it be easier to use in patch format, with subpatch for vsti and Expr 'with a little comment: put your vsti here)?
Statistics: Posted by ethnix73 — 03 Mar 2010, 12:24
]]>2010-03-03T11:42:16+01:002010-03-03T11:42:16+01:00https://brainmodular.org/forums/viewtopic.php?t=1976&p=12207#p12207 A simple workspace for live improvisation for the **FCB1010 midi foot switch controller**.
Let's you use it to record /play 3 midi tracks and 2 audio tracks.
Pedals 1 to record , 6 to play / mute and so...
No bank or presets used, just the 10 switches and the 2 expression pedals used.
]]>2010-03-03T12:52:44+01:002010-03-03T12:52:44+01:00https://brainmodular.org/forums/viewtopic.php?t=1976&p=12211#p12211This ramp subpatch is just an adaptation of the selector from audio/crossfaders tab of Usine , not my work..
