ArrayArrayArrayArray BrainModular BrainModular Users Forum 2010-03-03T18:40:06+01:00 https://brainmodular.org/forums/app.php/feed/topic/1973 2010-03-03T18:40:06+01:00 2010-03-03T18:40:06+01:00 https://brainmodular.org/forums/viewtopic.php?t=1973&p=12219#p12219 <![CDATA[grain sampler speed]]> I think this would be a very usefull little patch for the addons section?
Nobody should have to be a genius ;) just to get a simple tempo synced loop recorder/player ...
Something like this maybe...?
Now we just need a "slice" mode for time stretching percussive material...?
Edit:
Cool! So many undocumented uses for Usine! I now have a sweet beat loop slicer..hopefully soon to be an addon to share...
Statistics: Posted by gurulogic — 03 Mar 2010, 18:40
2010-03-03T12:55:41+01:00 2010-03-03T12:55:41+01:00 https://brainmodular.org/forums/viewtopic.php?t=1973&p=12212#p12212 <![CDATA[grain sampler speed]]>
The "rec" switch is quantize to quantize cycle
P.S: To test, i've changed the tempo from 160 to 100, with quantize cycle buttons and multiplevar modules
edit: in the first A/B module, b=100.
Statistics: Posted by ethnix73 — 03 Mar 2010, 12:55
2010-03-03T12:38:22+01:00 2010-03-03T12:38:22+01:00 https://brainmodular.org/forums/viewtopic.php?t=1973&p=12210#p12210 <![CDATA[grain sampler speed]]>
I think it's absolutly normal, as tempo and speed are different. Working on this to give a little example. I will try to post a screenshot this evening. The main idea might be:
if "rec" is on, memorize original tempo, and set grain sampler speed to 100%.
if tempo is changing, compare original tempo to new, to adapt grain sampler speed in %.
This idea might work if you pass straight from a bpm to another.
Statistics: Posted by ethnix73 — 03 Mar 2010, 12:38
2010-03-03T00:20:04+01:00 2010-03-03T00:20:04+01:00 https://brainmodular.org/forums/viewtopic.php?t=1973&p=12196#p12196 <![CDATA[grain sampler speed]]>
Right now I have a MasterSync tempo out going to the speed in on the Grain Sampler, but this only works properly when I start a project at exactly 100bpm.
The idea is that the bar synced loop always records into the sampler at original speed and pitch and then stays nicely in sync as I change tempo.
Ideas?
Statistics: Posted by gurulogic — 03 Mar 2010, 00:20
Edit:
Ideas?
