ArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2010-02-23T09:56:20+01:00 https://brainmodular.org/forums/app.php/feed/topic/1932 2010-02-23T09:56:20+01:00 2010-02-23T09:56:20+01:00 https://brainmodular.org/forums/viewtopic.php?t=1932&p=11862#p11862 <![CDATA[grasping the basics of OSC]]> ie: [171] OSC from 81.88.xx.xx : /Skins/09.Range_Fader.bmpPK (this is definately not me!) (xx is me not publishing the ip)
About localhost, I have it working within Usine and between Usine and Monomeserial but am having trouble between Usine and other local apps.. I will try some new things tomorrow.
Statistics: Posted by gurulogic — 23 Feb 2010, 09:56
2010-02-23T09:32:27+01:00 2010-02-23T09:32:27+01:00 https://brainmodular.org/forums/viewtopic.php?t=1932&p=11860#p11860 <![CDATA[grasping the basics of OSC]]> It's a 'classical' problem.
Just connect your computer to the network.
Statistics: Posted by senso — 23 Feb 2010, 09:32
2010-02-23T09:13:09+01:00 2010-02-23T09:13:09+01:00 https://brainmodular.org/forums/viewtopic.php?t=1932&p=11859#p11859 <![CDATA[grasping the basics of OSC]]>
Ok, so it seems there might be issues when trying to use OSC to communicate between two apps on the same computer?
I remember i made some OSC patching on XP with two usine v4 instance (one with audio OFF) with no problems.
- i just experimented one usine send OSC and the other receive (i mean, no bi-directional).
I am thinking it must not be hard at all now to make patches for the Monome in Usine! And even virtual Monome for Multi Touch cannot be that far off...]
you surely already noticed the monome OSC protocol page ;)
now, it's time to have fun
Statistics: Posted by martignasse — 23 Feb 2010, 09:13
2010-02-23T08:12:05+01:00 2010-02-23T08:12:05+01:00 https://brainmodular.org/forums/viewtopic.php?t=1932&p=11855#p11855 <![CDATA[grasping the basics of OSC]]> ..well, I'm at least having issues... Going over a network is so easy It seems you could broadcast random OSC to networks all over the world and start making other people's OSC setups go crazy!
I think for now I'll stick to fiddling with ideas for a simple Monome controlled patch in Usine...(Monome emulation is looking totally possible, but not much fun if there's OSC application issues on a localhost ip...)
Statistics: Posted by gurulogic — 23 Feb 2010, 08:12
2010-02-23T03:08:28+01:00 2010-02-23T03:08:28+01:00 https://brainmodular.org/forums/viewtopic.php?t=1932&p=11853#p11853 <![CDATA[grasping the basics of OSC]]>
I still get the error when loading the OSC send module but it seems to work anyways. (maybe an error message "OSC not active" might be usefull for noobs?) I hope at least someone else learns from my foolishness...
And usine can't send OSC to itself...
This was the very first thing I just tried and it works fine, so...?
I'm sure I will have some more questions yet...
[edit: hooray I am now receiving button presses from my Monome via Monomeserial. I am thinking it must not be hard at all now to make patches for the Monome in Usine! And even virtual Monome for Multi Touch cannot be that far off...]
Statistics: Posted by gurulogic — 23 Feb 2010, 03:08
2010-02-23T01:42:05+01:00 2010-02-23T01:42:05+01:00 https://brainmodular.org/forums/viewtopic.php?t=1932&p=11852#p11852 <![CDATA[grasping the basics of OSC]]> Statistics: Posted by Clearscreen — 23 Feb 2010, 01:42
2010-02-23T01:37:01+01:00 2010-02-23T01:37:01+01:00 https://brainmodular.org/forums/viewtopic.php?t=1932&p=11851#p11851 <![CDATA[grasping the basics of OSC]]> Statistics: Posted by 23fx23 — 23 Feb 2010, 01:37
2010-02-23T01:30:51+01:00 2010-02-23T01:30:51+01:00 https://brainmodular.org/forums/viewtopic.php?t=1932&p=11850#p11850 <![CDATA[grasping the basics of OSC]]>
"Turn your patch ON and verify that Usine sends OSC message when you change the faders value. The OSC send led of the Dashboard should blinking"
No blinking "led" no matter what I do, cannot get anything to happen between Monomeserial and Usine, iPhone and Usine or other computer running Usine and Usine, so I guess there is a problem after all...
I just checked and I have the exact same problem in Usine 4.2. Also just tried on my GF's 32 bit vista computer and the same error.
So I'm the only one it doesn't work for and I have 3 computers to try!? Am I missing a setting somewhere? Do I have to turn OSC ON in Usine settings somewhere?
Statistics: Posted by gurulogic — 23 Feb 2010, 01:30
2010-02-22T23:55:34+01:00 2010-02-22T23:55:34+01:00 https://brainmodular.org/forums/viewtopic.php?t=1932&p=11834#p11834 <![CDATA[grasping the basics of OSC]]> Statistics: Posted by ethnix73 — 22 Feb 2010, 23:55
2010-02-22T23:48:19+01:00 2010-02-22T23:48:19+01:00 https://brainmodular.org/forums/viewtopic.php?t=1932&p=11833#p11833 <![CDATA[grasping the basics of OSC]]> and it's work fine..
Statistics: Posted by nay-seven — 22 Feb 2010, 23:48
2010-02-22T23:36:50+01:00 2010-02-22T23:36:50+01:00 https://brainmodular.org/forums/viewtopic.php?t=1932&p=11831#p11831 <![CDATA[grasping the basics of OSC]]> Statistics: Posted by ethnix73 — 22 Feb 2010, 23:36
2010-02-22T23:10:48+01:00 2010-02-22T23:10:48+01:00 https://brainmodular.org/forums/viewtopic.php?t=1932&p=11830#p11830 <![CDATA[grasping the basics of OSC]]> AFAIK, that should always be 127.0.0.1, right? Or is Usine only able to communicate OSC via another computer?
I'll try between two computers and see what happens....
Statistics: Posted by gurulogic — 22 Feb 2010, 23:10
2010-02-22T21:21:35+01:00 2010-02-22T21:21:35+01:00 https://brainmodular.org/forums/viewtopic.php?t=1932&p=11826#p11826 <![CDATA[grasping the basics of OSC]]> And usine can't send OSC to itself.
check your router and your network configuration
a good IP looks like 192.168.1.1
Statistics: Posted by senso — 22 Feb 2010, 21:21
2010-02-22T20:34:17+01:00 2010-02-22T20:34:17+01:00 https://brainmodular.org/forums/viewtopic.php?t=1932&p=11825#p11825 <![CDATA[grasping the basics of OSC]]> Statistics: Posted by ethnix73 — 22 Feb 2010, 20:34
2010-02-22T18:56:53+01:00 2010-02-22T18:56:53+01:00 https://brainmodular.org/forums/viewtopic.php?t=1932&p=11823#p11823 <![CDATA[grasping the basics of OSC]]> Statistics: Posted by gurulogic — 22 Feb 2010, 18:56
2010-02-22T18:39:24+01:00 2010-02-22T18:39:24+01:00 https://brainmodular.org/forums/viewtopic.php?t=1932&p=11822#p11822 <![CDATA[grasping the basics of OSC]]> ok, now to scratch my head and wonder...
Statistics: Posted by gurulogic — 22 Feb 2010, 18:39
2010-02-22T18:36:15+01:00 2010-02-22T18:36:15+01:00 https://brainmodular.org/forums/viewtopic.php?t=1932&p=11821#p11821 <![CDATA[grasping the basics of OSC]]> I can't think of anything in my system that would cause network issues.
Also I use Molar VSTI in Usine with no problems and it is communicating via OSC.
Statistics: Posted by gurulogic — 22 Feb 2010, 18:36
2010-02-22T18:29:48+01:00 2010-02-22T18:29:48+01:00 https://brainmodular.org/forums/viewtopic.php?t=1932&p=11820#p11820 <![CDATA[grasping the basics of OSC]]> and check if the Usine.exe is executed as administrator too (right click on the exe, compatibility tab, execute as administrator) .
But it really smell like a firewall denied access...
Statistics: Posted by martignasse — 22 Feb 2010, 18:29
2010-02-22T18:22:24+01:00 2010-02-22T18:22:24+01:00 https://brainmodular.org/forums/viewtopic.php?t=1932&p=11818#p11818 <![CDATA[grasping the basics of OSC]]>
The fact is the error message you have is explicit : Socket permission denied.
Normally, OSC in Usine is pretty straight forward, just turn on and go...
Eventually, the firewall ask you if let Usine go through the network, with the option to make a permanent permission.
Statistics: Posted by martignasse — 22 Feb 2010, 18:22
2010-02-22T17:50:07+01:00 2010-02-22T17:50:07+01:00 https://brainmodular.org/forums/viewtopic.php?t=1932&p=11817#p11817 <![CDATA[grasping the basics of OSC]]>
Another example I am trying is I have an OSC monitor application running and it is capturing button presses from my Monome, so I am seeing for example an address of /256/press, type .iii tag and values for data 1, 2 and 3 with each press.
If the OSC receive module in Usine were working for me, I should be able to set the address as either /256 or 256/press and the ip to 127.0.0.1 and receive messages on data 1, 2 and 3 right?
Statistics: Posted by gurulogic — 22 Feb 2010, 17:50
2010-02-22T17:30:01+01:00 2010-02-22T17:30:01+01:00 https://brainmodular.org/forums/viewtopic.php?t=1932&p=11816#p11816 <![CDATA[grasping the basics of OSC]]>
Trouble is is that adding an OSC send module immediately gives the error: Send failed: Socket permission denied, and the OSC Send does not seem to work.
Maybe a problem with firewall permission ?
Make sure Usine is allowed by the firewall, if any.
Hope it help
Statistics: Posted by martignasse — 22 Feb 2010, 17:30
2010-02-22T16:49:10+01:00 2010-02-22T16:49:10+01:00 https://brainmodular.org/forums/viewtopic.php?t=1932&p=11814#p11814 <![CDATA[grasping the basics of OSC]]> I figure a simple exercise should be usine an OSC Send module and a OSC Receive module to communicate one message across the local loopback ip, 127.0.0.1.
Any suggestions on the best way to get started?
Edit:
Setup > OSC setup > OSC Active is a really good place to start! :|
Statistics: Posted by gurulogic — 22 Feb 2010, 16:49
Hope it help
Edit:
