ArrayArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2011-10-26T11:03:24+01:00 https://brainmodular.org/forums/app.php/feed/topic/1925 2011-10-26T11:03:24+01:00 2011-10-26T11:03:24+01:00 https://brainmodular.org/forums/viewtopic.php?t=1925&p=21700#p21700 <![CDATA[new SDK 5]]> Statistics: Posted by K8. — 26 Oct 2011, 12:03
2011-07-30T20:58:18+01:00 2011-07-30T20:58:18+01:00 https://brainmodular.org/forums/viewtopic.php?t=1925&p=20149#p20149 <![CDATA[new SDK 5]]>
yes all users modules (created with the SDK) are exported in the VST.
(another) good point for my consideration :p
can I ask if VST for mac would be on the roadmap?
Statistics: Posted by protofuse — 30 Jul 2011, 21:58
2011-07-30T18:56:55+01:00 2011-07-30T18:56:55+01:00 https://brainmodular.org/forums/viewtopic.php?t=1925&p=20144#p20144 <![CDATA[new SDK 5]]> Statistics: Posted by senso — 30 Jul 2011, 19:56
2011-07-30T18:55:07+01:00 2011-07-30T18:55:07+01:00 https://brainmodular.org/forums/viewtopic.php?t=1925&p=20143#p20143 <![CDATA[new SDK 5]]>
Can we use all the sdk if we intend to export as VST ?
I mean, would it work well ?
I guess yes, but I'd prefer to ask you about some limitations.
Statistics: Posted by protofuse — 30 Jul 2011, 19:55
2010-02-22T01:13:05+01:00 2010-02-22T01:13:05+01:00 https://brainmodular.org/forums/viewtopic.php?t=1925&p=11790#p11790 <![CDATA[new SDK 5]]>
Statistics: Posted by Clearscreen — 22 Feb 2010, 01:13
2010-02-21T13:47:23+01:00 2010-02-21T13:47:23+01:00 https://brainmodular.org/forums/viewtopic.php?t=1925&p=11779#p11779 <![CDATA[new SDK 5]]>
Hell yes.
Statistics: Posted by runagate — 21 Feb 2010, 13:47
2010-02-21T08:37:41+01:00 2010-02-21T08:37:41+01:00 https://brainmodular.org/forums/viewtopic.php?t=1925&p=11771#p11771 <![CDATA[new SDK 5]]> CPP SDK [5]
The new SDK by Martin Fleurent is available.
It's a major improvement
- multi-touch implementation
- many new functions
- easier to use
- better communication of user modules with Usine
The new manual is available.
improvements
- added a basic gui class to manage the client area (for mtControl and mtForm modules).
- added Multi touch mouse callbacks.
- added access to Usine ColorSet.
- added query system to ask the user about optionnal parameters.
- added access to Usine core events data manipulation functions.
- added access to Usine core Audio files manipulation functions.
- added access to Usine core Audio Math util functions.
- added access to Usine Files dialog for opening or saving a file.
- added access to Usine internal paths.
- added access to Usine trace functions to log infos in the console.
- added a matrix module.
- added two user module example (TestSoundFile and TestQuery).
changes
- global refactoring and reorganisation of source code.
- split 'UsineDefinition.h' in several files (names should be explicit),
but you only have to include the 'UserDefinition.h' file.
- changed SDK files folder name from 'include' to 'SDK'.
- 'TUserModule' width and height are now protected, use getter and setter to manipulate them.
- changed 'TUserModule::SetMasterInfo( pMasterInfo )' to 'TUserModule::Init(pMasterInfo, pModuleInfo)'.
- changed 'TModuleInfo::Color' to 'TModuleInfo::ModuleColor' for names consistency.
- changed 'TUserModule::AddLineLayoutBoolean()' to 'TUserModule::AddLayoutLineBoolean()' for names consistency.
- changed 'TUserModule::AddLineLayoutInteger()' to 'TUserModule::AddLayoutLineInteger()' for names consistency.
- renamed UserPrototypeExample to TestControls.
- deleted the deprecated DrawPadExample.
Statistics: Posted by senso — 21 Feb 2010, 08:37
Hell yes.
- easier to use
improvements
changes
