ArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArray
BrainModularBrainModular Users Forum2012-11-14T21:38:37+01:00https://brainmodular.org/forums/app.php/feed/topic/18862012-11-14T21:38:37+01:002012-11-14T21:38:37+01:00https://brainmodular.org/forums/viewtopic.php?t=1886&p=24805#p24805Yes, ipad sampler is similarly based, and gestural manipulation are interesting.
Statistics: Posted by r.erorr — 14 Nov 2012, 21:38
]]>2012-11-14T18:33:31+01:002012-11-14T18:33:31+01:00https://brainmodular.org/forums/viewtopic.php?t=1886&p=24804#p24804multiphone just send me this link,could be an inspiration source
Statistics: Posted by nay-seven — 14 Nov 2012, 18:33
Statistics: Posted by r.erorr — 14 Nov 2012, 13:16
]]>2012-11-14T08:30:51+01:002012-11-14T08:30:51+01:00https://brainmodular.org/forums/viewtopic.php?t=1886&p=24794#p24794poly and apply poly of the current patch setting module but maybe not doable....
Statistics: Posted by nay-seven — 14 Nov 2012, 08:30
]]>2012-11-14T04:29:42+01:002012-11-14T04:29:42+01:00https://brainmodular.org/forums/viewtopic.php?t=1886&p=24793#p24793 here smoother visual feedback, and edit markers button http://www.sensomusic.com/forums/upload ... s_EDIT.pat
Statistics: Posted by r.erorr — 14 Nov 2012, 04:29
]]>2012-11-14T00:43:53+01:002012-11-14T00:43:53+01:00https://brainmodular.org/forums/viewtopic.php?t=1886&p=24792#p24792 have you find a way when you add some markers..?
Statistics: Posted by nay-seven — 14 Nov 2012, 00:43
]]>2012-11-13T21:04:33+01:002012-11-13T21:04:33+01:00https://brainmodular.org/forums/viewtopic.php?t=1886&p=24791#p24791I thought it could be much comfortable for touchscreen http://www.sensomusic.com/forums/upload ... ver%5D.pat
Statistics: Posted by r.erorr — 13 Nov 2012, 21:04
]]>2010-03-09T07:15:09+01:002010-03-09T07:15:09+01:00https://brainmodular.org/forums/viewtopic.php?t=1886&p=12450#p12450 finaly what I wanted was not really to play a slice (from marker to marker) but rather trigger from marker to end.. i didn't express my idea very well. sorry but let see the patch and you will see.
cause I'm not sure to understand, in the last version I've uploaded , if you set marker 1 to 2 for the first switch , in reverse mode this will play marker 2 to 1..normal..?
Statistics: Posted by nay-seven — 08 Mar 2010, 23:23
]]>2010-03-08T22:21:46+01:002010-03-08T22:21:46+01:00https://brainmodular.org/forums/viewtopic.php?t=1886&p=12420#p12420 I worked on the patch (thanks for your begining idea ) and I have got now what I wished... cool!
However they are two things that I don't understand:
1- The reverse function dosen't work... For example what I want is when you press "3rev" sample is play from marker 3 to the begining. For now these functions always start from the end to the marker..,!;,;?
2- When I record stuff from input soundcard, there is always a small decay at the beginig of the sample... I play with asio4all. Normally there is no problem..?.
So except that, it work well... We can play with library sample or record a sample "on the fly". There are two differents way to trigger sample:
-with mouse (or finger): sample is play from marker to the end (or retrigger) -with midi keys: sample is play from the marker to the end, as long press
When you have play a pattern that you like, you can loop it on the second sampler (with midi learn, to have a great loop)!..
Can I send you the patch..? so If you have an idea (and time!) to correct the reverse button... and after that perhaps we can add it to the add-on, If you want.. Or maybe I can add it as "work in progress"... Let me know..
]]>2010-03-06T00:04:18+01:002010-03-06T00:04:18+01:00https://brainmodular.org/forums/viewtopic.php?t=1886&p=12295#p12295 It works well, however I want to work in "syncmod=playbutton".. I want each button to play when it press and stop when it release..
But thank you for this great begining... I will study it tomorrow in details because I want to really understand how it work.
]]>2010-03-05T23:36:03+01:002010-03-05T23:36:03+01:00https://brainmodular.org/forums/viewtopic.php?t=1886&p=12292#p12292i've just add a little addon , as a first try to your question ( was more easy than a screenshot ) check it and tell me if it can help to begin something : you move your markers as you want , switch 1 will play marker 1 to 2 , switch 2 play markers 3 to 4 and so..
( you can also use button in place of switches..)
addons/others/NS_4_Markers_Player
Statistics: Posted by nay-seven — 05 Mar 2010, 23:36
]]>2010-03-05T21:57:34+01:002010-03-05T21:57:34+01:00https://brainmodular.org/forums/viewtopic.php?t=1886&p=12287#p12287 I've try to do the heliouk6's patch, but for me it doesn't work... and also it's not really what i'm thinking about...
What i want it's simply a wave file slice with markers... and each part can be trigger with a play button (play as long as press)...
Roughly it can look like this:
"hs": reading in english it's ok for me but writing is too difficult.. so all appologies for mistakes.."hs"
]]>2010-03-05T20:52:57+01:002010-03-05T20:52:57+01:00https://brainmodular.org/forums/viewtopic.php?t=1886&p=12283#p12283I also have another way to play specific slices from a loop in the sampler if anyone wants to try... This divides a loop exactly by the number of steps.
Fom the output of your step module, use an A*B, B=100 divided by number of steps, and then from the A*B outlet, an A-B, B=100 divided by number of steps. From the A-B outlet you connect to both the Start Pos and Pos inputs. This only works for me in Bar Sync modes with a max record time set to 2x the desired playback length but it works well.
So when do we all compare our beat loop reslicers?
Statistics: Posted by gurulogic — 05 Mar 2010, 20:52
Statistics: Posted by nay-seven — 05 Mar 2010, 18:54
]]>2010-03-05T16:18:11+01:002010-03-05T16:18:11+01:00https://brainmodular.org/forums/viewtopic.php?t=1886&p=12275#p12275 I want to make a similar patch and i've got the same problem.... and i don't understand really what is the solution. I've not found the Compilation_Utils_1, where can I download it, please..?
Statistics: Posted by nay-seven — 11 Feb 2010, 20:06
]]>2010-02-11T19:52:17+01:002010-02-11T19:52:17+01:00https://brainmodular.org/forums/viewtopic.php?t=1886&p=11529#p11529is there a way to make the uploaded image (from uploader menu)appears here? or do i pass through image hosting?
Statistics: Posted by héliouk 6 — 11 Feb 2010, 19:52
]]>2010-02-11T16:21:13+01:002010-02-11T16:21:13+01:00https://brainmodular.org/forums/viewtopic.php?t=1886&p=11518#p11518can't you get the position of the second marker ( something like 38,5) and make a stop play when pos. is > 38,5 ?
Statistics: Posted by grego mondo — 11 Feb 2010, 16:21
]]>2010-02-10T23:23:10+01:002010-02-10T23:23:10+01:00https://brainmodular.org/forums/viewtopic.php?t=1886&p=11505#p11505named : 1sample_4_position to play_button
Statistics: Posted by nay-seven — 10 Feb 2010, 23:23
]]>2010-02-10T23:10:20+01:002010-02-10T23:10:20+01:00https://brainmodular.org/forums/viewtopic.php?t=1886&p=11503#p11503Statistics: Posted by héliouk 6 — 10 Feb 2010, 23:10
Statistics: Posted by nay-seven — 10 Feb 2010, 22:35
]]>2010-02-10T21:57:20+01:002010-02-10T21:57:20+01:00https://brainmodular.org/forums/viewtopic.php?t=1886&p=11496#p11496it must be simple...i want to play the marker i want ,only this one. how ? thanks a lot...
Statistics: Posted by héliouk 6 — 10 Feb 2010, 21:57
]]>BrainModularBrainModular Users Forum2012-11-14T21:38:37+01:00https://brainmodular.org/forums/app.php/feed/topic/18862012-11-14T21:38:37+01:002012-11-14T21:38:37+01:00https://brainmodular.org/forums/viewtopic.php?t=1886&p=24805#p24805Yes, ipad sampler is similarly based, and gestural manipulation are interesting.
]]>2010-02-10T22:35:01+01:002010-02-10T22:35:01+01:00https://brainmodular.org/forums/viewtopic.php?t=1886&p=11499#p11499
