ArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2010-02-04T21:54:12+01:00 https://brainmodular.org/forums/app.php/feed/topic/1872 2010-02-04T21:54:12+01:00 2010-02-04T21:54:12+01:00 https://brainmodular.org/forums/viewtopic.php?t=1872&p=11424#p11424 <![CDATA[How To?]]> Statistics: Posted by bsork — 04 Feb 2010, 21:54
2010-02-04T17:52:45+01:00 2010-02-04T17:52:45+01:00 https://brainmodular.org/forums/viewtopic.php?t=1872&p=11421#p11421 <![CDATA[How To?]]>
maybe check this
http://www.dokuwiki.org/namespaces
http://www.dokuwiki.org/plugin:nstoc
Statistics: Posted by nay-seven — 04 Feb 2010, 17:52
2010-02-04T13:37:30+01:00 2010-02-04T13:37:30+01:00 https://brainmodular.org/forums/viewtopic.php?t=1872&p=11418#p11418 <![CDATA[How To?]]> manual:modules:scripts:chmsg_transformer_advanced and manual:modules:patches:chmsg_transformer_advanced.
manual:modules:scripts and manual:modules:scripts contain only references elswhere that I'm not sure of how to interpret.
Where would I go to get rid of them? If you don't know, please don't spend much time on this issue!
Re 2), I have lots of references like that, but I was wondering whether there was a (simple) way of implementing an automatice redirect from one page to another. If not - an extra mouse click isn't really the end of the world either... :)
Statistics: Posted by bsork — 04 Feb 2010, 13:37
2010-02-04T12:44:06+01:00 2010-02-04T12:44:06+01:00 https://brainmodular.org/forums/viewtopic.php?t=1872&p=11417#p11417 <![CDATA[How To?]]>
2 _depending of where is your pages , but example of code to add here :
to add a link to the manual / the lesson 3 :
[[manual:lesson03]]
( check at the start of lesson 4 , there's this example )
Statistics: Posted by nay-seven — 04 Feb 2010, 12:44
2010-02-04T12:20:18+01:00 2010-02-04T12:20:18+01:00 https://brainmodular.org/forums/viewtopic.php?t=1872&p=11416#p11416 <![CDATA[How To?]]>
1) If an entry has been created that you for whatever reason want to delete: How to do that?
2) Is it possible to add a redirect from one page to another? For instance when there are several versions of patch but it's only necessary to have one common Wiki entry. The simple but not elegant solution is of course to just create links to the "main" entry, but a redirect would be more elegant. Of course that requires a means to access and edit without getting redirected....
Statistics: Posted by bsork — 04 Feb 2010, 12:20
maybe check this
[[manual:lesson03]]
